Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 05-24-2014, 11:47 AM   #1
Alexbn921
Senior Member
Alexbn921's Avatar
Default Reed 204 1/2 Restore 1910's
I picked this 100 year old Reed 204 1/2 up the other day. Planning on restoring it to its original glory. It has fixed jaws and a 3 bolt base. Weight 72 lbs.
Alexbn921 is offline   Reply With Quote
Old 05-24-2014, 12:26 PM   #2
jakemac
Senior Member
jakemac's Avatar
Default Re: Reed 204 1/2 Restore 1910's
I have the same vise (missing the swivel base). I'm looking forward to seeing pictures of the restoration.
__________________
Quote:
Originally Posted by Fretters
You're a muppet Jake.
Jake's Projects thread here.
How I modified my HF 26" box here
No job is complete until you've been to the hardware store 3 times and bleed on it ................ twice.
jakemac is offline   Reply With Quote
Old 05-24-2014, 12:33 PM   #3
drivesitfar
Senior Member
drivesitfar's Avatar
except for a bent swivel pin it looks like it's done and ready to use. always looking forward to seeing what magic you can do to an old vise. any color picked or red white and blue lettering again which i think you might have done to one of your wiltons.
drivesitfar is offline   Reply With Quote
Old 05-24-2014, 12:38 PM   #4
zkling
Senior Member
Congrats, you Wilton restore was awesome. What are your plans for the handle on this one? Now you need the matching Reed 104.5.
__________________
"Working in my garage is like playing advanced Tetris... something always has to move to get to the next tool." - PelicanPines
"I'd rather have 1 or 2 quality tools, than a drawer full of crap." - crewchief888
zkling is offline   Reply With Quote
Old 05-24-2014, 02:38 PM   #5
Alexbn921
Senior Member
Alexbn921's Avatar
Thanks Guys.
THe plan is to paint it black with white letters. Less showpiece and more vintage throwback. Could not get it apart. The end was mushroomed and the bottom screw it stuck good. Took out the file and dremel to clearance it. Took awhile but the slide is out and I'm going to hit it with the flapper wheel now that I can put a straight edge on it. There is no moving the bottom nut. Tried lube and heat. Bolted a piece of angle iron in my other vise and it just bent the hell out of it.
Old 05-27-2014, 02:57 PM   #6
Alexbn921
Senior Member
Alexbn921's Avatar
Fixed up the end so it is perfectly flat and moves like butter.
Prepped for painting. Cleaned vise with alcohol and blasted with the air hose. Classic semigloss black.
Old 05-27-2014, 04:17 PM   #7
zkling
Senior Member
Does that vise have a stop collar for when opening? Or is it just cross drilled and pinned after those two shims?
Looking good.
__________________
Old 05-27-2014, 04:44 PM   #8
Alexbn921
Senior Member
Alexbn921's Avatar
Only the pin. Its an older design.
Old 05-27-2014, 04:46 PM   #9
zkling
Senior Member
Quote:
Hum, interesting. Thanks for the info. I look forward to seeing it completed
__________________
Old 06-15-2014, 08:36 PM   #10
Alexbn921
Senior Member
Alexbn921's Avatar
Final finished up the Reed. Classic black with white letters. The handle is really long, 3+ inches longer then my Wilton 400S. The pin setup was kind of a pain to get the pre-load just rite. Don't know if I'm going to keep it. Too nice to mount outside and no room in the shop.
Jaws are in good shape too.
Old 06-15-2014, 09:11 PM   #11
1982fxr
Senior Member
1982fxr's Avatar
how did you go about straightening that lock down handle?
1982fxr is offline   Reply With Quote
Old 06-15-2014, 09:25 PM   #12
Alexbn921
Senior Member
Alexbn921's Avatar
Got it near perfect.
Here is how I did it on my Wilton. Line up the bend and use a breaker bar or box end wrench. Work it a little bit at a time until its strait.
Old 06-15-2014, 11:27 PM   #13
oldldh
Senior Member
oldldh's Avatar
Ya Dun Gud, Bubba!!!
__________________
It's my fantasy...I can make it as big as I want...
Young men have fantasies...Old men have delusions...
I speak three languages fluently---English, Sarcasm, and Profanity...
oldldh is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
