Norseman drill Garage Journal group buy
PT Doc
Patrick and I have been contacted numerous times since the last Norseman group buy asking to offer the deal again. You asked for it and here are the final details of this Norseman deal:
No limits on specific items; buy what you want as much as you want. ALL Norseman items are available to you. No restrictions.
If you want a Norseman item that is not listed, call Patrick or email him with part numbers and he will get pricing for you.
Pricing is good through July 7, 2014. This deal begins on Monday June 23, 2014.
These bits are proudly manufactured in the USA!
Patrick's information:
Patrick Cook
ISC
704-219-2113
800-970-8438
[email protected]
www.iscsupplies.com
Shipping prices:
Since high shipping prices really irritate me, I asked for him to take that into consideration. Here are the shipping costs:
$1-199.99: $8.00 Shipping! Lower 48 stated only. Outside of lower 48: shipping will be Patrick's actual cost.
Above $200.00: FREE SHIPPING! Lower 48 stated only. Outside of lower 48: shipping will be Patrick's actual cost.
Free with the first 10 orders:
One bottle of Norseman Ultra Lube High Performance Cutting Tool Lubricant, 4oz
http://iscsupplies.com/index.php/no...formance-cutting-tool-lubricant-16oz-btl.html
Norseman Catalog: (click on this link but give it time to download-its a large PDF so give it time to download-could take a few minutes based on connection speed)
http://norsemandrill.com/pdf/prdCATNor.pdf
Here is pricing on the sets that were requested during the last group buy:
66490 75.00
66850 89.00
23560 68.00
01931 78.00
43550 175.00
66820 86.00
66480 87.00
93840 235.00
58510 40.00
87859 270.00
87652 49.00
68400 135.00
61680 465.00
69280 317.00
29571 268.00
19669 77.00
19649 112.00
19639 112.00
19629 115.00
19619 128.00
19609 125.00
57920 105.00
44170 84.00
43520 62.00
44150 84.00
Links to above listed sets:
The links below were put together by danielzig so that those that are unfamiliar with some sets can at them this way.
Norseman 66490 - $75.00
29 Piece Stub Length Fractional Drill Bit Set with Metal Case
http://www.fastenal.com/web/product...pcode=&filterByStore=&filterByVendingMachine=
Norseman 66850 - $89.00
26Pc A-Z 135[DEG] Split Point Magnum Super Premium B&G HSS Machine Drill Set
Norseman 23560 - $68.00
60 Piece #1 - #60 Hi-Moly 135[DEG] Split Pt Black & Gold Mechanics Drill Set
Norseman 01931 - $78.00
Step Drills, Type 78-AG, Ultra Bit™, Multi-Diameter, Step Drill 3-Flats on Shank, 1/8 - 1-1/8"
http://www.ebay.com/itm/Norseman-Uni...-/171193847518
Norseman 43550 -$175.00
115 Piece 1/16"-1/2", #1-#60, Ltr A-Z HSS 118[DEG] Bright Fin. Jobber Drill Set
Norseman 66820 - $86.00
29 Piece 1/16"-1/2" x 64ths w/3-Flats Hi-Moly 135[DEG] Split Pt Mech. Drill Set
Norseman 66480 -$87.00
29 Piece 1/16" - 1/2" x 64ths Hi-Moly 135[DEG] Split Pt B/G Mechanics Drill Set
Norseman 93840 -$235.00
115 Piece 1/16"-1/2", #1-#60, Ltr A-Z Hi-Moly 135[DEG] Split Pt Job. Drill Set
Norseman 58510 - $40.00
10 Piece 5 Drills, 5 Bolt Extractors Hi-Carbon Steel Screw/Bolt Extractor Set
Norseman 87859 - $270.00
29Pc Ultra Dex 1/16" - 1/2" x 64th 135[DEG] Split Pt Hi-Moly Left Hand Drill Set
Norseman 87652 - $49.00
13 Piece 1/16" - 1/4" x 64ths Hi-Moly 135[DEG] Split Pt Lft Hnd Jobber Drill Set
Norseman 68400 - $135.00
29 Piece 1/16"-1/2" x 64 ths Cobalt 135[DEG] Split Pt Gold Fin. Jobber Drill Set
Norseman 61680 - $465.00
Norseman Tap & Die Set, Tap Type: Hand, Pipe (Straight Flute), Tap Type: Hand, Pipe (Straight Flute), Die Shape: Hex
https://www.motionindustries.com/mo...ding+Tools>Tap+Sets+&+Die+Sets>Tap+&+Die+Sets
Norseman 69280- $317.00
115 Piece All In One Cobalt 135[DEG] Split Point Gold Finish Jobber Drill Set
Norseman 29571- $268.00
8Pc 9/16" to 1" x 1/2" Shank 135[DEG] Split Pt M42 Cobalt Type 130-D Silver & Demming
I am really happy that Patrick was willing to put this offer together for us Garage Journal members. Thanks
ishiboo
Oshkosh, WI
Thinking about a general purpose set for metalwork... relatively infrequent use but I'd like something that lasts. I'm considering 68400 or 66480, any thoughts?
P
PT Doc
Unless you are drilling very hard steel, the cobalt set might be overkill. The other set is mechanics length and this is about 1" shorter for a 1/2" bit. If you have the ability to sharpen the bits then the non cobalt set you itemized would be great. You will likely get more holes out of the cobalt prior to needing to sharpen. The black gold bits are pretty darn good but so is cobalt. I believe these cobalt bits are m42 and this means they are 8% cobalt. Many other brands use m35 and this is 5% cobalt. Increased cobalt coincides with increased hardness but maybe also some increased brittleness. Hope this helps.
johndeereman
WILL COUNTY IL
Thanks for the reply pt doc
fastenal is seriously starting to piss me off or as i say fastensome they never have what i need when i need it and they are extremely over priced. Even though they are right around the corner i'm not a cheapskate when it comes to tools but when i can save some money it helps.
P
PT Doc
Fastenal is not for your average DIY guy. Their pricing is nuts. But if you need a double cut cylindrical carbide burr, they will have at 3 times the cost of an online supplier. For me, they are just too expensive. When enco has 30% off and free shipping! that is the time to stock up.
For those looking at these bits, please click on the Fastenal links and you will see some nutty pricing from them.
P
PT Doc
I too wondered what hi molybdenum was before I bought these.
This is from norseman marketing info.
Magnum™ Drills & Super Premium Cutting Tools
Welcome to the world of Magnum Super Premium twist drills. This page will provide you with the opportunity to review the many features and benefits of Magnum drills and to learn why they are the finest tools available for most drilling applications. These heavy duty drills are recommended for use in tough metal drilling applications and work hardening grades of stainless steel.
Why Choose Magnum™?
Substantially longer cutting life - The nitro-carburized flute has an increased Rockwell hardness.
Cuts harder materials - The flatter point takes a smaller chip. More torque is directed to a smaller area. This allows drilling into materials with hardness of over 30 on the Rockwell "C" scale.
Stops drill walking - The split point design gives accurate starting without the use of a center punch.
Holds tighter hole size - The split point design is self centering. This limits the normal oversize drilling characteristics.
Outstanding quality appearance - The rich amber gold color sets it apart from commodity cutting tools.
Runs cooler, uses less torque - 135° point takes a smaller chip resulting in less heat. Friction is reduced by amber gold surface treatment.
Stops chuck slippage - Flats on drill shanks allow easy positive chuck grip.
(Flats are machined only on Mechanics Length drill bits & Silver & Deming drill bits, not on jobber length drill bits.)
Magnum™ Vs. Cobalt
The Magnum™ drills will substantially outperform cobalt drills in work hardening stainless steel applications. This performance advantage is the result of construction differences between the two types of drills. Cobalt drills, manufactured to Type J NAS 907 specs, have a very thick web. This web is necessary to limit breakage of the brittle cobalt steel. Magnum drills are made of special hi-moly tool steel, which is much tougher than cobalt steel. The web on a Magnum drill can be thinned considerably due to the toughness of the steel. (See Illustration A)
A Magnum drill with its thin web will penetrate the work hardening stainless fast enough to continually cut beneath the chip which is hardening from deformation. This means the drill is cutting softer steel.
The cobalt drill, with its thick web, cannot be fed at a fast enough rate to cut beneath the area which is hardening. As a result the cobalt drill is continually drilling into hardened steel.
sharkytm
Pocasset, MA
Does anyone know if Norseman sells a selection of tap-sized drills only? I see plenty of drill/tap sets, but I'm well setup on taps. I'd like to be able to order a set of tap-sized drills (#36, 29, 25, 21, 7, F, 5/16, U & 27/64 for NC, and #33, 29, 25, 21, 3, 1, Q, 25/64 & 29/64 for NF, and maybe 2.05, 2.50, 2.90, 3.30, 4.20, 5.00, 6.70, 8.50 & 10.20 for metric)
Or should I just buy a 10-pack of each size, which seems like more than I'd need?
P
PT Doc
27 bits for a full set. I would guess that if huot does not make an index, then a pre made kit would not be available. try calling Norseman and asking. they are super great to deal with.
P
PT Doc
Here are some numbers for Norseman:
1-800-328-4655 (Personally Answered)
1-800-328-4654 (Electronically Answered)
Local Phone:*@#$651-227-8911
Fax:*@#$651-227-1793
They could be helpful with specific questions about drill bit material, applications, drill bit length...
P
PT Doc
Keep in mind, many of the sets are available in screw machine, mechanics and jobber length. Using a 1/2" but as an example:
screw machine: 4" length
mechanics: 5"
jobber: 6"
Please keep in mind that the difference in lengths will be smaller for smaller diameter bits since they are already shorter. I would guess that it is proportional to the standard jobber length. Clear as mud?
czgunner
WY
I've got a somewhat cheap MAC labeled HSS bits. They are okay at best, but dull quickly.
As an auto tech, what set do you recommend?
P
PT Doc
66820 would be great. Comes in solid plastic case and should be plenty if you want a 29 piece fractional set.
P
PT Doc
This deal begins tomorrow. Contact Patrick via phone if you want to get things taken care of quickly.
First 10 orders get Norseman cutting fluid. Free shipping over $200 for the lower 48.
Buckgnarly
VT
Anyone know if they have a left hand set somewhere between the 13 piece and full set? I want bigger than 1/4 but don't want to pay 200+ for the big set.
P
PT Doc
This deal begins today. The Norseman PDF catatalog that I linked to is quite so give it maybe 30 seconds.
Patrick is super nice and will try to answer your questions about sets but realize that he does not know everything. Calling nOrseman could be a good idea since they know their product well. And they are very nice as well.
Stock up for the first time or buy what you didn't last time. These bits are damn nice.
P
PT Doc
They make 6 sets for left hand.
8,12,13,15,17 and 29.
15 piece is 87854
17 piece is 87853
P
PT Doc
Here is pricing on their carbide burr sets:
19669- 77.00
19649- 112.00
19639- 112.00
19629- 115.00
19619- 128.00
19609- 125.00
Made in the USA!
ezover
3rd rock from the sun
do you have links to the carbide burr sets?
i sure most of you know already patrick is great to deal with i have 5 sets from him already.
neonlazer
Lafayette, LA
Don't..need...more...bits...but for giggles..
I endorse these two sets as very nice. :)
#43520
#44150
P
PT Doc
I would look at the pdf to see exactly what is in each set. the burrs have interesting part numbers with different shank diameters, tool diameters and end cutting or not.
P
PT Doc
While I appreciate you running this again, I'm still lost on which ones to get. :willy_nil
If you need precise drilling in your drill press get the screw machine length. I got the first 3 sets in the original post. They are short but that makes them more rigid. If that's not important then get jobber length drills. Get the black gold bits. At these prices it's a no brainier. They are incredible cutters.
Fractional is super handy to have. If you are drilling and tapping them the A to Z and 1-60 sets are handy to have. If you want all three, you can get them in a big 115 piece set or in 3separate sets to make it a bit more convenient.
Hope this helps.
P
PT Doc
To clarify on the various lengths offered in the drill bits:
when I was looking into what length to get, I used the 1/2" as the point of comparison. I think the results were as follows:
jobber length 6" long
mechanics length 5"
screw machine 4"
For increased rigidity and likely a hole that ends up where you want it, the screw machine length are recommended. Reading up on various machining forums helped me decide this. Having some jobber length drills are needed if you need deeper hole drilling capabilities. But having started with the screw machine and following with the jobber allows me to get better hole placement.
These options along with different drill materials, point angles, shank diameters and storage case types makes the combinations quite high. But its nice to have options. :)
