Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 11-18-2008, 10:41 PM   #1
brad d
Senior Member
Default Best way to drill 2" hole in concrete wall?
i need to drill the foundation of my house to tap in power for the garage... Its 9" thick.. what is the best bit to use and i do have a hammer drill.
Thanks
__________________
My 35x40 garage project http://www.garagejournal.com/forum/s...ad.php?t=11572
brad d is offline   Reply With Quote
Old 11-18-2008, 10:44 PM   #2
Uncle Buck
Default Re: Best way to drill 2" hole in concrete wall?
Carbide bit core drill, likely quite high I suggest renting it.
Uncle Buck is offline   Reply With Quote
Old 11-19-2008, 12:01 AM   #3
Junkman
Senior Member
Junkman's Avatar
You will need a core bit, and then part way through, you will need to break out part of the core that has already been drilled. The core bit will only drill about 3" deep, so you will need to do this a few times. I have a Milwaukee 1 1/2" hammer drill with core bits up to 6". They are extremely expensive, and if there is rebar in the foundation, it will kill the bit in short order. For this reason, I never loan the hole drills. I will loan the tool with demo bits, but when it comes to holes, I tell them to hire someone with the equipment. There is a local company that does most of the commercial work in this area, and a 2" hole takes them very little time to drill. By the time you have the check written, it is done.
__________________
Philosopher Emeritus Of Garage Journal
Men wake up as good-looking as they went to bed.
Women somehow deteriorate during the night.
Never argue with an idiot. He'll drag you down to his level, then beat you with experience.
Junkman is offline   Reply With Quote
Old 11-19-2008, 12:14 AM   #4
nissan_crawler
Senior Member
nissan_crawler's Avatar
That's odd, I was getting ready to ask the same question. How feasible is it to drill holes around the perimeter with my 1/2" sds and then chip out the core with a rock chisel or such?
I'm going through my slab for my washer/sink drain int he garage.
__________________
If guns cause crime, all mine are defective. Ted Nugent
"A man with a gun is a citizen. A man without a gun is a subject. " John Lott
"Taking my gun away because I might shoot someone is like cutting my tongue out because I might yell `Fire!' in a crowded theater." Peter Venetoklis
nissan_crawler is offline   Reply With Quote
Old 11-19-2008, 12:21 AM   #5
Junkman
Senior Member
Junkman's Avatar
It would take me about 10 - 15 minutes with my Milwaukee hammer drill to do this job. It also depends on the concrete. If it is green, it goes faster. If your foundation is like my high strength concrete, it is going to take longer. It also depends on how large the stone was in your mix. If they used small stone, it goes faster than if they used 3/4" / 1" stone. Too many variables to make a call on this type of job without knowing the details...
__________________
Old 11-19-2008, 07:36 AM   #6
diiulio
I agree with the above posters, I would rent a core drill, but you could hire a local guy to drill it and he'd probably charge you $150-200. Usually you could call a concrete guy or even a fence installation company and they may give you a decent price. Fence installers sometimes have to core all their holes for posts when set in existing concrete, so they have the equipment and knowledge plus they might be slow since winter is hitting, at least here anyway. If you do rent a drill, I would get one that you have to dill a few holes and use concrete anchors/red heads to bolt it on. There are some bases that are vacuum, but only work well when drilling down. Drilling 9" deep shouldn't take too long. It will take you longer setting up and cleaning up the water/slurry from the area then the actual drilling. Even if there is rebar, it isn't a big deal for the core bit.
You could drill a series of holes with a hammer drill and then chip it out, but that would take longer and if you have rebar in the wall, then it will make it more difficult, plus you will have to torch out the rebar.
diiulio is offline   Reply With Quote
Old 11-19-2008, 07:57 AM   #7
Chief
Senior Member
Chief's Avatar
Quote:
Originally Posted by diiulio View Post
Fence installers sometimes have to core all their holes for posts when set in existing concrete, so they have the equipment and knowledge plus they might be slow since winter is hitting, at least here anyway. .
I like this idea. When I had my fence installed, the installers easily ripped through the concrete. I will say though, mine was not nine inches thick
Good Luck
__________________
Hank
68 Camaro
Chief is offline   Reply With Quote
Old 11-19-2008, 08:28 AM   #8
Mattlt
Senior Member
Mattlt's Avatar
I just put a ~6" hole in my poured basement wall a few weeks ago. Installing an outdoor wood boiler, so I had to run some insulated wall pipe through.
I used a rotary hammer drill to drill a couple of holes, then hit it with a demolition hammer - basically a small jackhammer. Had the hole made in about 15 minutes. $60 from the rental place (the rental guy is a buddy of mine so he gave me a deal)
After running the pipe, I grouted everything up with some mortar.
Oh, and remember to start the hole larger than you think you'll need, as the hole tends to work it's way inward when you start chipping away at it.
Mattlt is online now   Reply With Quote
Old 11-19-2008, 08:43 AM   #9
jmack
Senior Member
I'd try dynamite first.
jmack is offline   Reply With Quote
Old 11-19-2008, 10:25 AM   #10
JMURiz
Senior Member
JMURiz's Avatar
I used a core drill bit for my dual 3" holes...rented them...even that was $$ but well worth it. My basement wall was a good 10" with rocks and cured since 1940.
__________________
Nathan
22'x24' detached garage *Outside complete, working on interior*
Various cars and motorcycles to be stored inside.
JMURiz is offline   Reply With Quote
Old 11-19-2008, 10:41 AM   #11
sberry
Senior Member
sberry's Avatar
You could consider re-design where it left the building thru the sill, then use an LB to turn it down to the underground?
sberry is offline   Reply With Quote
Old 11-19-2008, 01:36 PM   #12
kbs2244
Senior Member
I had to do two 4 1/2 holes through 10 inches of 30 year old wall with rebar.
HD didn't want to rent for the job because the hole was over 3 inches.
Local rental house didn't care. Gave me 2 core bits "just in case."
Good thing because I used one per hole.
They charged me a sharpeng fee on the bits, but that was all explained up front.
Do have something sturdy to stand on so you are up high enough to get you weight behind the drill.
Like Junkman said, you go in as far as you can, back out and bust it out, and go in again.
It is loud, dusty, and very tiring.
kbs2244 is offline   Reply With Quote
Old 11-19-2008, 04:31 PM   #13
rwhite692
Senior Member
rwhite692's Avatar
Yep, core drill is what you need.
I was able to borrow a core drill w/diamond cutting edge on it (looks like a really long, deep hole saw, w/no pilot) from the guy in my area who builds pools/spas.
The drill itself is powered by a small 2-cycle engine and has a water hose hookup to keep the bit wet. Cutting wet makes all the difference in the world!
Went through 12" of reinforced concrete as if I was drilling through wood.
__________________
My 24x36 detached garage project:
http://www.garagejournal.com/forum/s...ad.php?t=16310
rwhite692 is offline   Reply With Quote
Old 11-19-2008, 05:11 PM   #14
Torque1st
Senior Member
Torque1st's Avatar
Diamonds are a man's best friend...
Torque1st is offline   Reply With Quote
Old 11-19-2008, 06:03 PM   #15
Buckled
Senior Member
Diamond Coring is the way to go. Most rental houses will have a hand held coring motor that you can attach a hose to. The water will keep the dust down and will help to cool the bit also. Most core bits are 17" long so you'll be able to core it in one shot. Check with a local United Rentals or Sunbelt, they usually have a pretty good selection of this type of equipment. Hammer drilling with a carbide tipped core bit is very dusty, slow, and loud. It also won't make a very clean hole. Check out something like this:
http://www.us.hilti.com/holus/module...jsp?OID=-12758
Buckled is offline   Reply With Quote
Old 11-19-2008, 06:49 PM   #16
tigmusky
Senior Member
tigmusky's Avatar
1} drilling a bunch of 1/2" holes and then chiping it out by hammer and cheisel or some roto-hammers drills have a hammer only with a chipper bit or automotive type air hammer will work.
2} dry core bits run about $ 50. to $100. and they fit on your big 9" grinder this works well, a little loud and dusty. to keep the dust down use a vac or a squrit bottle of water this will help keep the bit cool too.
good luck Daye
tigmusky is offline   Reply With Quote
Old 11-19-2008, 07:03 PM   #17
Aceman
Senior Member
I completely agree. Diamond core first choice, Rotohammer with carbide core bit second choice.
Aceman is offline   Reply With Quote
Old 11-19-2008, 08:48 PM   #18
kbs2244
Senior Member
Now that he reminded me of it, I like sbrry27's idea.
Easy to get through the wall. and keeps the opening above grade (possible water problems).
Old 11-19-2008, 10:45 PM   #19
jtrace
Senior Member
Exactly what Buck said I worked in a rental store for 16 years all you need is a hand held core drill 4" is the biggest you could go with the machine we had it was a 110 volt with a garden hose hook up the bit will cost you more than the drill to rent diamond bits are expensive..
John
jtrace is offline   Reply With Quote
Old 11-19-2008, 11:09 PM   #20
nissan_crawler
Senior Member
Quote:
John
how much did that run?
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
