Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 11-27-2008, 11:36 PM   #1
kartracer55
Senior Member
kartracer55's Avatar
Default Thoughts on Snap On PH50E air hammer?
Any thoughts on this item? I have a chance to buy a used one in good working order for 60$ with a few bits in the case. Go for it? Anybody actually have this model or know how much it originally sold for? It seems to be in great shape.
TIA
Jim
__________________
Add yourself to the official Garage Junkies map!
http://www.frappr.com/garagejunkies
kartracer55 is offline   Reply With Quote
Old 11-27-2008, 11:47 PM   #2
krusty the clown
Senior Member
krusty the clown's Avatar
Default Re: Thoughts on Snap On PH50E air hammer?
it's the older model of the ph3050 i believe. definatly worth $60.
__________________
DEGENERATE Main Entry: 1de·gen·er·ate
Pronunciation: \di-ˈjen-rət, -ˈje-nə-, dē-\
Date: 15th century
1 a : having declined or become less specialized (as in nature, character, structure, or function) from an ancestral or former state b : having sunk to a condition below that which is normal to a type; especially : having sunk to a lower and usually corrupt and vicious state c : degraded 2
krusty the clown is offline   Reply With Quote
Old 11-27-2008, 11:52 PM   #3
kartracer55
Senior Member
Thanks. Is it a good hitter? A lot of the shorter barrel air hammers don't have any cajones....
__________________
Old 11-28-2008, 11:11 AM   #4
GDA
Senior Member
GDA's Avatar
I dont have that exact model but I will tell you once you have an air hammer you sure will be glad to have it around. They sure make some tasks, that used to be difficult or stubborn, easy.
GDA is offline   Reply With Quote
Old 11-28-2008, 11:18 AM   #5
caper
Senior Member
caper's Avatar
Send a message via MSN to caper
I have one,its been a workhorse over the years.It broke the flutter dic inside a year or two ago and it was a bear to get the part.Snappy dealers wanted to send it for flat rate repair for around 100 bucks,all i wanted was the ten dollar disc to fix it myself.Finally found a dealer who got me one and its up and running again.Had to order one for a newer model but it fit perfectly.Its a good strong hitter,sometimes to strong,I had to buy a cheapy for doing buck rivets cuz the snappy was to much gun.
__________________
Quote:
Originally Posted by mrholeshot View Post
Takes about two minutes once you have the shaft in hand.
caper is offline   Reply With Quote
Old 11-28-2008, 01:59 PM   #6
Charles (in GA)
Senior Member
Charles (in GA)'s Avatar
Quote:
Air hammers and Pneumatic Rivet Guns are NOT the same thing. A rivet gun is very controllable and will drive/buck rivets such as aircraft rivets easily They are rated by their power, 2X, 3X, 4X are most common, but they go up to 9X which we use at work for removing frozen/stuck pieces on airplanes.
Air hammers hit very rapidly and are generally not very controllable, much more of the all or nothing type.
One bargain for someone, is this, don't know anything about it, but I'll bet it is great for knocking out ball joints, cutting the heads off of steel drums, or splitting muffler pipes. For the money, its a no lose situation, esp if you combine it with other items to keep the shipping reasonable.
http://www.surpluscenter.com/item.as...5&catname=misc
Charles
Charles (in GA) is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
