Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 12-20-2008, 12:41 PM   #1
mw_98
Junior Member
Default snowblower drip pan
OK, so I have lived in the northeast all my live without a snowblower but with my new 50 x 60 driveway I finally broke down and bought a snowblower just in time to clear 8 inches off the drive yesterday. Now I need a way to keep the snowblower from dripping all over my nice epoxy floor as the snow that I couldn't brush off melts. Has anyone seen a drip pan that a snowblower can be rolled into so as not to make a mess all over the floor?
I considered a piece of carpet but I'm afraid that would just be a wet mess.
Any ideas?
mw_98 is offline   Reply With Quote
Old 12-20-2008, 12:52 PM   #2
gerryw
Senior Member
Default Re: snowblower drip pan
Off the top of my head.
how about picking up a used compact pick-up truck bedliner for $50 and cutting it to size?
Or one of those (formed)mats for the back of a SUV?
a used kids splash pool?
a plywood tray lined with pond rubber liner?
gerry
gerryw is online now   Reply With Quote
Old 12-20-2008, 01:22 PM   #3
kbs2244
Senior Member
Since snowblowers are a real PIA to move around in a garage, years ago I made a plywood platform with casters for mine.
Makes it real easy to put into a tight spot.
Last year I tacked some old carpet to the platform for this reason.
Seems to work OK but I still get some runoff.
One trick I use that works pretty well is to park the snowblower by the door that is open about 8 inchs and then let a fan blow on it.
It dosn't need to be a big fan.
I use a 6 inch "personal desk fan from the drug store.
As the snow melts the fan blows the moisture out the door.
kbs2244 is offline   Reply With Quote
Old 12-20-2008, 01:24 PM   #4
mtwaterguy
Senior Member
How about a metal drip pan that was originally designed to lay under a vehicle to catch oil. They have a raised lip around the edge to keep the moisture in and wouldn't be effected by heat from a cooling engine.
mtwaterguy is offline   Reply With Quote
Old 12-20-2008, 01:46 PM   #5
jettago
Senior Member
jettago's Avatar
Try this place...
http://www.mcmaster.com/
Search part# 4206T1 - Polyethylene Drip Pan 3 1/2 Gallon Capacity 36"L x 24"W x 1 1/2"H
jettago is offline   Reply With Quote
Old 12-20-2008, 01:50 PM   #6
krusty the clown
Senior Member
krusty the clown's Avatar
i think i would just mop it up after it melted.......but then again a don't have an epoxy floor. and i'm a tightwad!
__________________
DEGENERATE Main Entry: 1de·gen·er·ate
Pronunciation: \di-ˈjen-rət, -ˈje-nə-, dē-\
Date: 15th century
1 a : having declined or become less specialized (as in nature, character, structure, or function) from an ancestral or former state b : having sunk to a condition below that which is normal to a type; especially : having sunk to a lower and usually corrupt and vicious state c : degraded 2
krusty the clown is offline   Reply With Quote
Old 12-20-2008, 01:53 PM   #7
mw_98
Junior Member
I knew you guys would have some great ideas! That Polyethylene Drip Pan from McMaster is what I had in mind but it's not quite large enough. It needs to be about 36x36.
Old 12-20-2008, 01:54 PM   #8
6t7gto
Senior Member
6t7gto's Avatar
I put mine on a board so it doesn't leave rust marks on the floor.
I don't worry about the melting snow.
david
6t7gto is offline   Reply With Quote
Old 12-20-2008, 02:12 PM   #9
boiler7904
Senior Member
boiler7904's Avatar
If you don't have the right equipment, hire a local sheet metal shop to fab up exactly what you need.
__________________
2004 Ford Escape XLT
2012 Ford Fusion Sport
1997 2 car garage in progress
Quote:
Originally Posted by bmwpower View Post
Oh, and it's BMWPower. I do have powerful BM's but wouldn't want everyone to know all my secrets.
boiler7904 is offline   Reply With Quote
Old 12-20-2008, 02:24 PM   #10
Tom2
Senior Member
This is something Id like to build as well. Right now I just keep the snowblower in the shed. Otherwise it would make a huge puddle in the garage every time..
Id like to get a snowthrower attchmt for my tractor and park it in the garage..That would require a pretty big container though. The bedliner idea is a good one..
Tom2 is offline   Reply With Quote
Old 12-20-2008, 04:58 PM   #11
RWD
I have seen a plastic pan that is used under a clothes washer that might work. I believe the pan is used on second floor laundry rooms where a leak might be a problem. Check out the local home centers.
RWD is offline   Reply With Quote
Old 12-20-2008, 05:50 PM   #12
SteveU
Senior Member
SteveU's Avatar
They make plastic trays for boots that have a raised lip around the outside.
SteveU is offline   Reply With Quote
Old 12-20-2008, 08:03 PM   #13
toyman
Junior Member
walmart has metal drip pan for under a car, Think they are about 3' by 4.5'
toyman is offline   Reply With Quote
Old 12-20-2008, 09:56 PM   #14
stinkythings.com
Bakeries use large baking trays, cookie sheets about 24x36 inches. I have seen these on Craigs list from bakeries going out of business ot you can find some new ones if you google bakery suppliers. I am on Long Island, we have a restaraunt wholsaler called RESTARAUNT DEPOT. i Know they have them. I am sure there is a local rest supply company that wil have them.
__________________
Automotive & Custom Air Fresheners
http://Stinkythings.com
Life Stinks...We Can Help!!!
stinkythings.com is offline   Reply With Quote
Old 12-20-2008, 09:59 PM   #15
stinkythings.com
You could also try a local air conditioning duct maker. They can make an exact size real cheap for you.They make sheet metal pans all of the time, I just had an idea, I know they make a pan out of sheet metal for under a washing machine so it has to be at least 36x36, try home deopt ,lowes or a good plumbing supply.
__________________
Old 12-20-2008, 10:01 PM   #16
nissan_crawler
Senior Member
nissan_crawler's Avatar
I take it you guys don't park your vehicles in the garage?
__________________
If guns cause crime, all mine are defective. Ted Nugent
"A man with a gun is a citizen. A man without a gun is a subject. " John Lott
"Taking my gun away because I might shoot someone is like cutting my tongue out because I might yell `Fire!' in a crowded theater." Peter Venetoklis
nissan_crawler is offline   Reply With Quote
Old 12-21-2008, 09:13 AM   #17
mw_98
Junior Member
Thanks for all the great ideas. I hope to get to Lowe's today and see what they have to go under washing machines.
Do I park vehicles my garage? Lets see, in my garage I have a 2007 Accord. Chevy Avalanche, Honda S2000, my 19ft SeaRay boat, my Harley and now my snowblower ( only in the winter ).
Of course the 26x28 part of my garage that holds the daily drivers has floor drains to catch the stuff melting off the cars. The other side of my garage where the toys are kept ( and the snowblower ) is 16 x 38 and does not have a drain and is epoxy coated.
Old 12-21-2008, 10:11 AM   #18
Stephenw
Senior Member
Stephenw's Avatar
The relatively clean water from the snow and ice melting off my snow blower is a minor issue. The sand, salt, and big chunks of snow and ice coming off the vehicles are another matter.
Stephenw is offline   Reply With Quote
Old 12-21-2008, 10:29 AM   #19
mw_98
Junior Member
Not sure why I didn't find this on my first search but this 36" x 36" mat is made by Ariens specifically for snowblowers. They say it will hold two quarts of water, it should keep the mess contained and prevent rust spots on the floor.
http://www.snowblowersdirect.com/ima...oducts_id=2292
Old 12-21-2008, 01:56 PM   #20
Kevin54
Senior Member
Kevin54's Avatar
Quote:
Ditto. They look like a large cookie sheet. The last time I bought one was something like $11.00. They keep them in the automotive department.
Kevin54 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
