Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#961 |
Senior Member
The 2-ply gloves?
#962 |
Junior Member
Harbor Freight make a great living knocking off USA designed and manufactured tools and are too lazy to ever actually improve or innovate anything. At least some of the budget tool distributors sell funky new designs and commission new products. Don't be complaining about losing jobs overseas if all you worry about is saving a few dollars on tools which may or may not hold up for more than occasional use.
#963 | |
Senior Member
Quote:
please.... didn't we have enough of this in this thread. |
#964 |
Senior Member
Leave it to the new guy to stir the pot .
#965 | |
Junior Member
Quote:
Back to pass/fail. Has anybody bought the pintle hitch reciever mount and pintle hitch hook from here? I'm in the process of buying an old military trailer that has a pintle hitch on it. Still undecided to go with the traditional hook or the ball mount combo. Here are the links: Pintle Mount: http://www.harborfreight.com/cpi/cta...emnumber=95407 5 Ton Pintle Hook: http://www.harborfreight.com/cpi/cta...emnumber=95408 Pintle Hook with 2" Ball: http://www.harborfreight.com/cpi/cta...emnumber=96198 |
#966 |
Senior Member
This past weekend I bought the 1/4" drive ratcheting torque wrench so I could do the transmission bands on my wifes Exploder. Worked like a champ, with a really good "break" point when you reach torque.
Build quality was a little rough, finish wise, but for 20 bucks, not bad. |
#967 |
Senior Member
Harbor Freight 20 ton press. Epic fail. Broke the first time I used it where the bottle jack meets the frame. Also tons of play in the horizontal moving part.
#968 | |
Senior Member
Quote:
I have the 20 ton H frame item 32879 and it has performed like a champ. What was odd, IMO, is that it did not come with a handle for the jack (nor is there one pictured). I upgraded from the 12 ton A frame item 1667 which I overloaded on pressing a wheel bearing out and the ring up top which holds in the jack broke causing the bottle jack to launch outward (thankfully away from me). |
#969 |
Senior Member
3/8" Heavy Duty Composite Ratchet ITEM 66313-2VGA
I have had this ratchet for about 6 months and I really like it! Only issue is the selector is backwards from every other ratchet I have. Overall MAJOR PASS Digital Scale ITEM 95364-6VGA I bought this to weight racecar parts. Goes up to 11 lbs. MAJOR PASS 6-1/2" Wire Strippers with Pressure Adjustment ITEM 66690 They look just like the Matco stripper but these are a POS. Returned them. MAJOR FAIL 1/8" Air Micro Die Grinder ITEM 47869 Works pretty good. PASS I'll add others as I think of them. |
#970 | ||||
Senior Member
Quote:
ok where's the review ..............
__________________
Quote:
Quote:
Quote:
#971 | |
Senior Member
Quote:
#972 | ||
Quote:
Quote:
#973 | |
Senior Member
Quote:
#974 | |
Senior Member
Quote:
#975 | |
Senior Member
Quote:
#976 | |
Senior Member
Quote:
Bojo non marring pry-bar set(one of manny): $15.95 Made in USA ![]() HF copy: $6.99 Made in China ![]() Anyone have a pass fail review of these??? Chris Last edited by Shadowdog500; 03-16-2010 at 10:48 PM. |
#977 | |
Senior Member
Quote:
HF also had those Bojo bars, or ones that look exactly like them too. They were a little more expensive than the yellow ones. |
#978 |
Senior Member
+1 on those composite ratchets. I have the 1/2" an 1/4" versions and I love them. Light and the fine tooth feature is awesome. A buddy of mine that works on heavy equipment has collected Mac, Matco and Cornwell ratchets over the years and hes told me that now the HF composites are his standard go to ratchets. Very good tool for the money.
#979 |
Junior Member
Thanks A29, I ended up getting the 2" ball version and it looks pretty stout. They didn't have the mounting plate in stock so I had to get it at Tractor Supply. Same piece but about $45 more, both made in China. Oh well.
#980 |
Senior Member
http://www.harborfreight.com/cpi/cta...emnumber=95621
ITEM 95621-6VGA - 132lb. capacity roller stand I picked three of them up on sale last friday at the sidewalk sale for 11.99 ea. I needed something for infeed/outfeed support on my table saw for work I was doing with some longer pieces. I was able to assemble all three in about 10 minutes, and they did the job well. I went with these instead of the 19.99 tripod stand due to the fact that I needed to be abl.e to easily store them. They are all hanging on my wall storage system on one hook right now out of the way. Definite PASS. |
| Tags |
| harbor freight |
| Thread Tools | |
| Display Modes | |
