Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 03-18-2010, 12:36 AM   #981
Dust
Senior Member
Dust's Avatar
Send a message via AIM to Dust
Default Re: The Harbor Freight PASS/FAIL Thread...
Has anyone tried the jumpstarter listed in this month's ad? Just the basic yellow one without a compressor or light, I think it's fifty bucks. Don't have the ad in front of me.
Also, does HF have a good battery charger? I don't need the heavy duty wheeled one, a simple self-contained electronic unit will do. It'd just be used for maintaining battery voltage when flashing modules and keeping some batteries topped off.
Dust is offline   Reply With Quote
Old 03-18-2010, 02:18 AM   #982
Shocker
Senior Member
Quote:
Originally Posted by Shadowdog500 View Post
I assume you are upset because HF sels a cheap copy of your "Made in USA" non marring Pry bar set!
Bojo non marring pry-bar set(one of manny): $15.95 Made in USA
HF copy: $6.99 Made in China
Anyone have a pass fail review of these???
Chris
I have the HF yellow ones. Got them on sale for about $4.00. Worked great for removing interior door panels to replace a window motor.
Shocker is offline   Reply With Quote
Old 03-18-2010, 05:31 AM   #983
larry4406
Senior Member
Quote:
I used my wife's teflon coated burger flipper for that!
larry4406 is offline   Reply With Quote
Old 03-19-2010, 07:26 AM   #984
yiranhu
I have the yellow jumpstarter. I used it to go to auction yards to start cars I want to test. Works okay. Had difficulty starting only 1 car... but i think may also has something to do with that car's starter...
50 is not a good price for it. I bought it during a sidewalk sale for 25 after 20% off...
yiranhu is offline   Reply With Quote
Old 03-22-2010, 01:39 PM   #985
stricht8
Senior Member
Quote:
Now that is both funny and a great idea!
stricht8 is offline   Reply With Quote
Old 03-22-2010, 07:12 PM   #986
hpw
Senior Member
Searched and didn't see this....has anyone used it and if so, how did it perform? I'm wanting to spray some single stage automotive paint through this.
http://www.harborfreight.com/cpi/cta...emnumber=95810
http://images.harborfreight.com/cpi/...5899/95810.gif
hpw is offline   Reply With Quote
Old 03-24-2010, 12:13 PM   #987
r6100mph
I'm thinking about this motorcycle lift:
http://www.harborfreight.com/cpi/cta...emnumber=66247
It's a US General Made, which I believe is fairly decent, I have their large tool box and love it.
Wondering if anyone has had experience w/ this electric lift.
$380, but with 20% coupon, and tax - out the door for around $320
Thanks!
r6100mph is offline   Reply With Quote
Old 03-24-2010, 12:26 PM   #988
Skin
Senior Member
Thanks!
http://www.garagejournal.com/forum/s...ad.php?t=59065
Skin is offline   Reply With Quote
Old 03-24-2010, 01:23 PM   #989
r6100mph
Sweet! Thanks for the heads up!
Old 04-04-2010, 09:54 AM   #990
jj63
Junior Member
Quote:
Originally Posted by cortez View Post
Harbor Freight's Lug nut Torque Multiplier (33 times gear reduction!!!) gets my PASS vote as it saved my wife's butt ( well to tell the truth it was a kind Samaritan that changed her tire during the dangerous rush hour here in Chicago). The lug nuts would not get off using the breaker bar I leave in her car.
Luckily she remembered the new torque lug multiplier I had got for such a situation ( after getting new tires, which were probably machined torqued to 125 foot pounds, which become 200 or so foot pounds due to friction and rusting!!! [ my brother who is an engineer said that a 125 pound machine torqued lug nut would need considerably more to take off as friction and corrosion would factor in the loosening power needed to remove the lug nut and breaking the stud may result]).
He recommended the HF torque multiplier as it had the capability to remove the nut with out breaking the stud as it turned the nut ever so slowly and thus safely. He said that torque multipliers were usually in the cost range of 3 to 7 hundred dollars but if the HF model worked only a few times it was monetarily justified.
It cost only 23 dollars and on sale it is only 19 dollars and change. A tow truck would have charged around 80 dollars in rush hour traffic and of course it would have been much delayed due to traffic.
So the cost to risk benefit was excellent for a "Prima Dona" in distress.
Just broke one of these. First the bar bent and then the casing cracked. I eventually used an 18" breaker bar to remove lug nut.
jj63 is offline   Reply With Quote
Old 04-04-2010, 10:13 AM   #991
raflomo
Junior Member
raflomo's Avatar
6 Ton Jack stands...3 out of 4 PASS...1...ah well lets say FAIL...
My brother had his little honda up on 4 of them removing the tranny and went loose loosen a bolt and one of the stands just bent ond dropped the car.Luckily he got out as it started to drop.So to say the least he got them all out from under the car and is not using them again.
raflomo is offline   Reply With Quote
Old 04-04-2010, 10:32 AM   #992
Indy_500
Senior Member
Indy_500's Avatar
My whole toolbox is pretty much harbor freight (including the tool box) here's my list:
-US General 13 drawer tool box = pass
-magnetic tray = pass
-about a dozen of the free flashlights = pass (I USE THEM ALL THE TIME THEY'RE AWESOME!!!)
-65 piece socket set = pass
-22 piece wrench set = pass
-4 piece adjustable wrench set = pass
-6 piece pliers set = pass
-4 piece pry bar set = pass
-10 piece chisel/punch set = pass
-bolt cutters = pass
-rubber mallet = pass
-heat gun = pass
-holesaw kit = pass/fail
-drill-bit set = fail
-6 piece screwdriver set = pass
-tape measure = pass
-2 piece telescoping magnet set = pass
-tons of electrical tape = pass
-3 piece allen wrench in SAE and Metric and the Star heads (fold-out) = pass
and that's my list!
soon i'll get some nicer ratchets but the sockets will do just fine. and my next addition will be the box you stack on top of it with, then hopefully an air compressor with TONS of air tools and a welder. and some more deep-welled sockets and the sockets with the head heads and star heads.
__________________
99 GMC Sierra Classic 1500 Z71
05 Polaris XC SP 500
Indy_500 is offline   Reply With Quote
Old 04-04-2010, 10:33 AM   #993
Danglerb
Senior Member
Danglerb's Avatar
Details, picts etc. I'm having a hard time imagining how a jackstand fails under a 10% load. Did he take them back, and is HF doing anything about it?
Danglerb is offline   Reply With Quote
Old 04-04-2010, 10:36 AM   #994
Danglerb
Senior Member
Danglerb's Avatar
Electrical stuff I avoid at HF, risk/bargain isn't so good. OTOH those starter things are just a trickle charger and a motorcycle battery, so maybe hard to mess up. Typical complaint with that "type" of device is that the battery needs replacing too soon.
Old 04-04-2010, 10:40 AM   #995
Indy_500
Senior Member
Indy_500's Avatar
i also try to avoid electrical and air items from harbor freight. i can do with a few electrical items though. air tools, the only thing i'd buy for them is attachments, i will go elsewhere for air tools.
__________________
Old 04-04-2010, 10:52 AM   #996
Scout Driver
Senior Member
Scout Driver's Avatar
PASS on the "free with a coupon" LED flashlite.
Scott
__________________
WTB: International Harvester tools. (the automotive mechanic's style tools made by Wright) Also looking for other IH items of interest.
Scout Driver is offline   Reply With Quote
Old 04-04-2010, 12:57 PM   #997
jj63
Junior Member
I'm a different poster. The quote should have had the other posters name.
Sorry about that chief.
Old 04-04-2010, 01:01 PM   #998
jj63
Junior Member
Quote:
Originally Posted by U5512 View Post
3/8" drive 17" breaker bar....PASS....broke loose the crank bolt with ease
http://www.harborfreight.com/cpi/cta...emnumber=37391
Fail. I broke it the 1st time out. The 3/8" head sheared right off.
Old 04-04-2010, 01:03 PM   #999
SCscoutguy
Senior Member
SCscoutguy's Avatar
Quote:
I have had one for maybe three years and used the piss out of it and it has not failed yet. I even had a proto breaker bar break on me and I had to go and find my HF bar to finish the job.
SCscoutguy is offline   Reply With Quote
Old 04-04-2010, 02:29 PM   #1000
fxt
Senior Member
usually if a stand bends it because it isn't properly set. say it might of tipped one way when the weight of the car was on it. then that force caused it to bend.
the reason i say this is bc all your weight on a stand is vertical, so it should collapse downward before it bends
fxt is offline   Reply With Quote
Reply
Tags
harbor freight
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
