#1 |
Senior Member
I just picked this up off of Craigslist. The retail is a little over $1k. I got this one for $50. The guy said or best offer, and I usually take advantage of that, but I just couldn't this time. I'm getting soft. The leads are there as is the power cord. Everything appears to be in good shape, just a little dusty. I'll probably clean it all up and repaint. But for now, I'd like some more info on it. If anyone has any experience with them, I'd like to hear it. It seems like a nice piece of equipment, but it may be junk, I really don't know. It is a "LENCOSPOT DUO-SPOT" Mark II L-4000. It appears to have 230V 30A input. The power cord, which appears original, is 10/3.
#2 |
Senior Member
Is that like a 'stitch' welder? For spot welding on sheet metal where you can't access the other side with the 'tong' type?
#3 | |
Senior Member
Quote:
#4 |
Senior Member
Cool! Nice find!
#5 |
Senior Member
Great score! This looks like the type that allows you to manually line up contacts, not limited by jaw depth, only lead length. I'm still agonizinge over picking up the Hoabart Beta Mig 250 I found locally for $850.
__________________
There's nothing heat and pressure can't overcome. |
#6 |
Senior Member
#7 |
Director of Bands
Neat toy! I wouldn't worry about repainting it.. seems pretty nice as it is!
#8 |
Senior Member
Maybe open it up and blow it out first, visually check it over. 220 30amp could make quite a show if something is wonky inside.
#9 |
Senior Member
How do you line them up with each other? I'm thinking a small pilot hole or something.
__________________
http://photoshow.comcast.net/watch/Ed4pS5Af In the beginning, the Patriot is a scarce man, a brave man, a hated man and scorned man. When his cause succeeds, however,the timid join him, for then it costs nothing to be a Patriot. |
#10 |
Senior Member
Sorry I haven't updated this guys, I've been busy.
I cleaned the welder up today. It has 50 feet of 10/3 on it!!! Everything appears to be in great shape, it is just missing a small screw that holds one of the plastic handles on the lead, no big deal. I opened it up, blew it out, and then cleaned it out with electrical contact cleaner. Everything looks pretty mint inside. I plugged it in and it powers up. I haven't tried to spot anything yet, but I'll probably try that tomorrow. I'm VERY pleased. This should make my restorations much more accurate and easy. Some pics... 50' cord ![]() Dusty interior ![]() ![]() ![]() Cleaned... ![]() ![]() ![]()
#11 | ||
Senior Member
Quote:
Quote:
#12 |
Senior Member
Is the wire in space some kind of unused wiring option?
I'm curious about exactly how its used, post more when you can. |
#13 | ||
Senior Member
Quote:
Quote:
#14 |
Senior Member
Is that one of those machines that when you hit the switch the electrode wires fly up into the air and it erases your credit cards in your wallet ??....H |
#15 |
Junior Member
have you got to use it yet ? just pick up the exact machine for free. just curious you don't have to line the tips up right ,you can do two spots as long as they are touching the same panel from what i read.
#16 |
Junior Member
Fifty dollars, free??? You guys are killing me. Hi I have been searching for one of these units . As I understand you use the handles and can weld 2 spots at the same time, although there is only a trigger on one of the handles. I think you could use just the one handle for a single weld also. You do not have to put the tips facing each other, they each make a independent weld. I have been fightning about which type to buy. I work on small sports cars so I was thinking that something like this would be way more flexible than the clamp type units. These are pretty expensive, I just saw two similar types used from SnapOn go on ebay for about $900 ea with shipping. Please do me a favor and send the next great deal you find my way....
Nice to be here. Mike |
| Thread Tools | |
| Display Modes | |
