Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 12-31-2008, 12:28 AM   #1
zuspiel
Senior Member
zuspiel's Avatar
Post PB Swiss Tools Review
A few months ago, somebody posted about a set of small PB Swiss picks which perked my interest. So I decided to check out their tools. I've lived in Switzerland for 15 years, making it even more interesting.
PB Swiss has been around for 130 years. They should know a bit about manufacturing tools and the prices are actually pretty good. They mostly make screwdrivers in all possible variations, insert bits, Allen keys, and some other stuff. You can find their wares on Amazon or at their US distributor Count On Tools. The latter is quite a bit more expensive. You can order a print catalog for free here or download one in PDF form here.
Let's start with the set of mini picks mentioned above. They work well and I haven't broken one in the two months I've had them, which is a first for me (Amazon, $15).
The radiator hose picks (Amazon, $16) work equally well. These are full size and not mini. The handle is their 'multicraft handle' which I like best of all the ones they make. It's a hard handle with a slight texture that's really comfy. Nothing fancy, but it works well. They also make a similarly shaped soft handle (SwissGrip) which I haven't tried, yet.
Next is a set of what they call 'detach wrenches' (Amazon, $18). No clue why you would call that a wrench... Pops off trim clips and other fasteners like a charm, though.
Here, you can also see one of the special PB Swiss features: Each tool has a unique serial number that they can track all the way back to the original batch of steel that entered the factory.
The tips are nice and thin. They fit under almost anything and don't tear up the trim.
I've always wanted a T-handle for the small insert bits for places where more torque is called for. This one (Count On Tools, $38) fits the bill. Very strong magnet holds the bits in place and there is hardly any "wiggle". The price is a bit of a joke, though: It's listed in the print catalog for 34 Swiss Franks which is quite a bit less than $38... Still nice, though.
Well made, spins freely, but doesn't have any fancy internal retainers. The grip is held on by C-clips:
One side of the handle has a screw cap, so it can hold up to 5 regular size bits.
Now we get to one of jewels of their tool collection: the insert bits. I needed some power bits and couldn't resist these. They really have thought about the whole bit business. All their bits are color coded: One overall color for the type of bit and a colored ring for the size.
First, here are some metric hex and Torx bits (Amazon, $20, pic on the website is wrong).
Here is another set (Amazon, $22, pic is wrong) in a bit holder with a belt clip.
If you have the holder clipped to your belt and you open it, the bits always end up perpendicular to the belt, making it easy to pull them out. There are gears in the holder that ensure this is always the case.
Finally, unless you're color blind, you're able to tell the difference between a phillips and a pozi bit from a mile off. Plus, they just are so damn pretty. No clue yet how well the finish will hold up. The color is not painted on, though. More like a metal finish similar to black oxidized (w/o the rust).
Some of you might have noticed a certain obsessiveness in my tool organization. It always bothered me how the screwdrivers wobbled around on the peg board... These holders solve that problem nicely. However, they aren't that cheap (Count On Tools, $12-17).
The black loops are made of rubber and springs are used as spacers. For bulkier handles, you can just pop out a loop or even take out the spring. In my case, it was best to only remove a couple of loops, leaving the springs in place.
They come in three different lengths. I got the medium (above) and large (below) sizes. Might have to order one or two more to put on my tool cart. I'm really happy with how they hold the stuff.
The holders also don't seem to mind holding screwdrivers from north of the border
Now, the big question is always how well the tools will hold up. In the tools I brought from Europe, I found this:
It's a 4mm slotted screwdriver which is at least 15-20 years old. I think I found it in my parents attic. Must have been a leftover from a contractor. The handle is the PB standard handle. It has been well used...
However, looking at the tip, it's in great shape! Yes, there's a tiny bit of peeling chrome, but you can hardly tell by eye. The actual tip (black) looks pretty much like in the catalog. The angle on the corner is a feature. They say it moves the pressure point on the screw away from the very edge, reducing the damage to the screw head.
The bottom line: I think PB Swiss is a good alternative with decent prices. The stuff seems well made and some things are quite innovative. Check them out (especially the stuff on Amazon which is downright cheap for the quality).
Other comments:
Autoace might be able to add something here about another PB Swiss tool
Stuey, you hereby have my permission to re-post this on toolguyd.com, if you like. Both complete and in parts.
I'm sure that, as usual, I haven't covered everything here...
__________________
Quote:
Originally Posted by forceyoda View Post
When it comes to buying tools I never "need" any of them... unless I am talking to my wife.
zuspiel is offline   Reply With Quote
Old 12-31-2008, 12:33 AM   #2
Bolster
Senior Member
Bolster's Avatar
Default Re: PB Swiss Tools Review
Great timing for a review, I just received my PB catalog and was looking through it, wondering if their stuff was worth the francs (or euros, whatever they're using now). Thanks!
__________________
Delmar O'Donnell Bolster, GoPhD.
A bona fide Soggy Bottom Boy.
Looking for Protos with pebble fields (1950s-60s vintage) & cross-hatched Duro Chrome sockets, PM me if you have spares...
Bolster is offline   Reply With Quote
Old 12-31-2008, 12:53 AM   #3
bchee
Senior Member
bchee's Avatar
another great review and picts. thanks
bchee is offline   Reply With Quote
Old 12-31-2008, 07:35 AM   #4
pirana
Senior Member
I just got some metric hex bit drivers & a punch & chisel from them a few weeks ago. A couple of things were out of stock which they (Count on Tools) said they'd ship to me sometime in january with no extra shipping charge. Quality stuff i.m.o.
pirana is offline   Reply With Quote
Old 12-31-2008, 07:38 AM   #5
Fedwrench
Senior Member
Fedwrench's Avatar
Excellent write up and pictures!! thanks for sharing. It seems like they have some unique items.
__________________
It's not the tools in the toolbox, it's the mechanic who knows how to use them that matters.
Fedwrench is offline   Reply With Quote
Old 12-31-2008, 08:44 AM   #6
terabyte
Senior Member
terabyte's Avatar
very nice review... nice presentation ...
thanks a bunch dude
terabyte is offline   Reply With Quote
Old 12-31-2008, 09:06 AM   #7
garfunkle24
Senior Member
garfunkle24's Avatar
Send a message via MSN to garfunkle24
Thanks a lot Zuspiel! I've been waiting for your write-up on the PB stuff ever since I saw them in your pics in "Let's see your toolbox". Great stuff!
__________________
g24
garfunkle24 is offline   Reply With Quote
Old 12-31-2008, 11:09 AM   #8
autoace
Senior Member
autoace's Avatar
Zuspiel sent me some PB Swiss tools for X-mas, I'll be posting pics and a mini review. I was impressed with the quality, and had to test them out immediately. I then checked the web site and found a bunch of stuff for future purchase. I would initially put the quality, at or above Hazet and Wiha.
I am going to buy some of their hard handled screwdrivers, torx drivers, their version of the turbo T-handle, and some more bits for starters. Their black hex key set caught my eye.
Looks like a good company, that has quality of materials and workmanship, at the top of their list. I like the fact, they still make traditional hard handle, and not all soft grip.
The tools don't come cheap, so Harbor Freight thumpers, run for cover!
PB Swiss=
autoace is offline   Reply With Quote
Old 12-31-2008, 11:20 AM   #9
Stuey
Senior Member
Stuey's Avatar
Zuspiel,
Great pics, and great review! I now want to pick up some bits. It almost seems like a waste though since I never use Pozis or Torx. Maybe I'll look into buying bits separately.
I also want one of those T-handled bits.
The hardest part about buying PB Tools screwdrivers is the handle selection. Multicraft, or Swiss Grip!
Thanks also for the permission to repost, but I'd still ask again before doing so.
__________________
ToolGuyd Blog
I am a toolaholic.
Stuey is offline   Reply With Quote
Old 12-31-2008, 01:41 PM   #10
Vinko
Senior Member
Great review. I've been eyeing the mini-pick set, and now am thinking, what the hell, the radiator and trim picks look good too.
Vinko is offline   Reply With Quote
Old 12-31-2008, 04:16 PM   #11
chammyman
Senior Member
a while back frank, myself and a few others commente don how we all had these tools and they were all in good nick (apart from 1 of mine) and all were at least 20 years old.
Good gear and worth buying
chammyman is offline   Reply With Quote
Old 12-31-2008, 10:47 PM   #12
Bolster
Senior Member
Bolster's Avatar
Aside from Amazon, what sources are y'all using to find & buy PB Swiss Tools?
__________________
Old 01-01-2009, 12:20 AM   #13
zuspiel
Senior Member
zuspiel's Avatar
Thanks everybody! I like reading reviews so I don't mind sharing...
Quote:
Damn, I wanted to get you the T-handle since I saw you were looking for one. When I checked further, it seemed you were more after a 3/8" or 1/2" square drive one...
The allen keys do look really nice. I'd love to have the set with the Swiss flag on them. However, they only make metric ones and, honestly, I don't use my hex keys enough...
Quote:
I'm curious about the SwissGrip (soft) ones myself (I don't have one). However, I think the multicraft handles are really comfy.
Quote:
I don't think you'd be disappointed with either of the other sets. Also because the prices on Amazon are really good for these sets.
Quote:
Only the Count On Tools link I gave above. They have everything and their clearance section might be worth checking out. Beware of the $10 flat rate shipping, though. It only makes sense if you order more stuff at once.
Also, check out their clearance section here.
__________________
Old 01-01-2009, 02:48 AM   #14
autoace
Senior Member
autoace's Avatar
The nice thing about PB Swiss, Hazet, Wiha, Wright,etc..., is they offer super high quality, and they are NOT Snap-on. It's nice to have specific, high end brands in the mix. Although some of Snap-ons' tools are awesome, and necessary; it's refreshing to indulge in something different, and still have ultimate quality.
Old 01-01-2009, 02:54 AM   #15
Merkava_4
Senior Member
Merkava_4's Avatar
You need to get over your grudge with Snap-on dude ... find the dealer you hate and go loot his truck.
Merkava_4 is online now   Reply With Quote
Old 01-01-2009, 03:08 AM   #16
autoace
Senior Member
autoace's Avatar
Quote:
That's the thing, I am over it. I have discovered other tool brands that are as good or better(with some things) than Snap-on. Snap-on is king in some areas, but not all. It's too boring having all Snap-on tools anyway.
Alot of us get stuck with one woman, that can be a bitch. Why settle for one tool brand, that can be a warranty/service bitch??? The garage is my domain, no place to be, one brand exclusive.
Old 01-01-2009, 03:09 AM   #17
Stuey
Senior Member
Stuey's Avatar
As far as I know, Count On Tools and Small Parts are the only US distributors. I have not yet ordered from Count On, but my correspondences with one of their representatives gave me a positive impression of them.
Small Parts offers free shipping on $25+ orders via Amazon, and their prices are a bit better on a lot of products. They don't carry the full product line, and are slow to reorder. I haven't seen the T handle in stock at all - everytime I check, it just says "unavailable."
Quote:
I'm still trying to figure out what I like! I have the pick set and Insider w/ multicraft handle, and a screwdriver set with the swiss grip handle. I just need to find the time to do a head to head comparison. So far, they both seem to feel great!
__________________
ToolGuyd Blog
I am a toolaholic.
Old 01-01-2009, 03:19 AM   #18
Merkava_4
Senior Member
Merkava_4's Avatar
If you use the tool correctly within its intended design parameters, and it breaks, there shouldn't be a problem with getting it warranted.
Old 01-01-2009, 03:23 AM   #19
autoace
Senior Member
autoace's Avatar
But there is! I don't buy tools "that break" often from them. I don't break much, for tools, but still.......
Old 01-01-2009, 09:21 AM   #20
eschoendorff
Director of Bands
eschoendorff's Avatar
Well this is just great! I have been wanting to try some PB tools ever since John Gardner posted about them on mark KW's Inside Tools.
Thanks, man, you are gonna cost me money!!!!
__________________
When you die, I want your tools.
Quote:
Originally Posted by Moose-LandTran View Post
Why bother? Natural selection will take care of them. If it doesn't, a 12-gauge can take care of the unnatural selection...
eschoendorff is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
