Go Back   The Garage Journal Board > The Tools > Vintage Tool Discussion
Reply
Thread Tools Display Modes
Old 12-31-2008, 09:58 AM   #1
Ryan
Administrator
Ryan's Avatar
Default Vintage Air Compressors
Okay, so the article isn't really vintage but seeing as it's New Year's Eve, we're sitting here wondering where the time has gone. It's hard to believe that 1998 was...
Ryan is offline   Reply With Quote
Old 01-01-2009, 05:18 PM   #2
Ramblur
Senior Member
Default Re: Vintage Air Compressors
This ones still sitting in my old shop in Ohio. Vintage,means I'm afraid to plug
it in...
The gas station I worked in as a kid still had the original
1938 vintage air compressor.A very rythmic low rpm chug sound not irratating
at all. We pulled the valves and cleaned them about once a year.It finally
died about ten years ago. The replacement died about a month after the
warranty ran out...
Ramblur is offline   Reply With Quote
Old 01-01-2009, 05:30 PM   #3
Ryan
Administrator
Ryan's Avatar
Wow... That thing is nuts.
Old 01-01-2009, 06:04 PM   #4
67pete300
Senior Member
67pete300's Avatar
This is mine:
Not quite as vintage as the others.
Also have this one:
A little less vintage yet.
67pete300 is offline   Reply With Quote
Old 01-01-2009, 07:45 PM   #5
Charles (in GA)
Senior Member
Charles (in GA)'s Avatar
This is a 1973, give or take a year. I have the original manual and parts list, but no date, no receipt, so I cannot remember for sure which year I got it. Craftsman 1hp, 12 gal tank, 100 psi. I added the handy box and double pole 30 amp motor rated switch (set up for 120V but can be converted to 240V so I used a double pole switch in case it ever gets changed over.) Its been holding 100 psi for months now. Use it only occasionally now that I have a stationary shop compressor. 6.4 cfm @ 40 psi, 5.4 cfm @ 90 psi, it came without the belt guard, an option at the time, before they found out that stupid people used air compressors. I never had any little fingers around it so I didn't worry.
Charles.
File Type: jpg Craftsman_one_horse_twelve_gallon_compressor.jpg (67.9 KB, 1660 views)
Charles (in GA) is offline   Reply With Quote
Old 01-01-2009, 08:50 PM   #6
bgarrett
Senior Member
bgarrett's Avatar
You cant get any more 'vintage' than this
http://www.jalopyjournal.com/forum/s...th#post2746000
bgarrett is offline   Reply With Quote
Old 01-02-2009, 11:24 AM   #7
MAK
A few years ago my dad gave me his old Kellogg American air compressor from back when he was doing a lot of home autobody work and painting.
It hadn't been used in about 20 years and is really old. Plate on the side of the tank says 1945... It's one heavy-duty monster. I think it's about an 80 gal tank.
I replaced the pressure switch, put on a new air filter, put new oil in the pump, ran a 220v line in my garage and fired it up. Has been running like a champ ever since.
MAK is offline   Reply With Quote
Old 01-02-2009, 01:12 PM   #8
67pete300
Senior Member
67pete300's Avatar
Oddly enough, I have the chance to pick this up today for $100:
See the ad here:
http://washingtondc.craigslist.org/n...977248066.html
He has replaced the motor with a 1 hp 115/220 VAC unit currently set up for 220.
He says it leaks down over time. Repair parts are available at Grainger.
I would have to run 220 to the garage (I'd probably need another circuit anyway if I left it at 115 because of the current draw.) But it would be a big step up from those other smaller units I posted earlier. And could be a fun rebuild project too.
Good deal? Or not so much?
Old 01-02-2009, 06:52 PM   #9
ironroad 9c1
ironroad 9c1's Avatar
has a date of 1964 on the tank, pump is a 2 stage type 30 IR/ 220v
ironroad 9c1 is offline   Reply With Quote
Old 01-02-2009, 08:57 PM   #10
Mellotron
Senior Member
Mellotron's Avatar
Quote:
Haha what's the vintage on that bottle of Southern Comfort?
__________________
"Its pretty simple - penetrate the garage through a hole. Install your drip loop and some form of strain relief. " - Rinny Tin Tin
Mellotron is offline   Reply With Quote
Old 01-02-2009, 09:05 PM   #11
67pete300
Senior Member
67pete300's Avatar
That's Jim Beam, I believe.
Old 01-03-2009, 07:21 PM   #12
Firefyter-Emt
Senior Member
Firefyter-Emt's Avatar
Mine is an old Devilblis with a big old 220V motor in it (Repulsion Induction)
Oh, and when I mean big.... that's a 60 gallon tank!
Firefyter-Emt is offline   Reply With Quote
Old 01-04-2009, 09:02 AM   #13
kartracer55
Senior Member
kartracer55's Avatar
I guess old tanks are safe?!
__________________
Add yourself to the official Garage Junkies map!
http://www.frappr.com/garagejunkies
kartracer55 is offline   Reply With Quote
Old 01-04-2009, 09:54 AM   #14
Firefyter-Emt
Senior Member
IHMO, you will never see an old tank "explode". You will have leaks for a long time that start being bigger leaks to the point that you stop using the compressor before it explodes. The tank will rot out and begin to leak from the most rotted area a little at a time as the rot gets worse and worse.
Old 01-07-2009, 01:12 PM   #15
Pete D.
Pete D.'s Avatar
Oldie but a good compressor had a gas engine on it when I got it. I think it was from the army. Sorry pics to big
Pete D. is offline   Reply With Quote
Old 01-07-2009, 01:23 PM   #16
Pete D.
Pete D.'s Avatar
Made the pictures a little smaller.
Old 01-18-2009, 07:23 PM   #17
Tuneup
Junior Member
Quote:
it in...
warranty ran out...
WOW! That is definately an old piece. Like some kind of ancient scuba gear !!
Tuneup is offline   Reply With Quote
Old 02-14-2009, 08:29 PM   #18
DHS
Senior Member
DHS's Avatar
I just thought I would post a picture of a air compressor that I have in my shed. I love this thing it is not the fastest but it has a nice quiet chug.
__________________
Quote:
Originally Posted by expatriated View Post
Ethanol sucks. And I'm tired of all this whining over the environment. If they made one, I'd buy a car that ran on baby seals.
DHS is offline   Reply With Quote
Old 02-14-2009, 08:43 PM   #19
goodfellow
Senior Member
goodfellow's Avatar
Quote:
Originally Posted by davidhsimmons View Post
Hello I am new here, Im 25yrs old but I have a soft spot for old vintage tools. I just thought I would post a picture of a air compressor that I have in my shed. I love this thing it is not the fastest but it has a nice quiet chug.
Wow -- that is an antique!! What's the date of manufacture? I'm guessing around 1915-1920.
Incredible that something that old can still function well.
__________________
"...The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants..." Thomas Jefferson
goodfellow is offline   Reply With Quote
Old 02-14-2009, 08:54 PM   #20
DHS
Senior Member
DHS's Avatar
I believe its like a 1926. The electric motor that is on it is a little under powered and I would like to put another on it. I also have a Sibley and Ware camelback drill that is about 10' tall that is not operational yet but hopefully soon I will get back to it.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
