Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 01-12-2009, 06:16 PM   #1
khein66
Junior Member
Question What materials to use for the garage ceiling?
What would be a good alternative to sheetrock for the garage ceiling? I'm using 1/2" plywood (cabinet stock on one side) for the walls, which works great. I'm looking for something lowbuck, but decent looking for the ceiling.
Thanks.
khein66 is offline   Reply With Quote
Old 01-12-2009, 09:32 PM   #2
Lloydthumper
Senior Member
Default Re: What materials to use for the garage ceiling?
In my opinion sheet rock is the cheapest and best looking. The only ones did with ply wood I have seen that looked ok had 2" strips that covered all of the joints. Plywood bows and warps so the joints look bad after. Metal looks ok depending on how the rest of the garage is but it is expensive. either leave it unfinished or sheet rock is my opinion.
Lloydthumper is offline   Reply With Quote
Old 01-12-2009, 10:18 PM   #3
monstergarage87
Senior Member
monstergarage87's Avatar
I used corrugated tin on mine. Got it at lowes, not sure if your local lowes would have it though but you can check by where they have roofing or lumber. It was $14 for 30"x8' sheets and $19 for 30"x12' sheets. Not horribly expensive but still more than sheetrock. Im using it since i plan to do a lot of fab work in that area so i want something that will hold up to the abuse and its an older barn too so it fits.
monstergarage87 is offline   Reply With Quote
Old 01-12-2009, 11:55 PM   #4
lh4x4
Senior Member
lh4x4's Avatar
It's not low buck, but I went with 1x8x8 knotty pine car siding. It is a one man job to install. I wanted something sturdy to hang 50 bicycles from. Plus it looks good.
lh4x4 is offline   Reply With Quote
Old 01-13-2009, 01:31 AM   #5
Torque1st
Senior Member
Torque1st's Avatar
Remember the installed cost and maintenance!
Sheet metal type materials go up and you are done with them. No other maintenance or painting is required. Sheet rock requires mudding the joints, finishing, and painting, sometimes often. Galvanized sheet like pictured above is OK and there are many other pre-coated sheet metal products available. There are even reflective faced insulating materials available that can work on high ceilings out of harms way.
Torque1st is offline   Reply With Quote
Old 01-13-2009, 10:51 AM   #6
JMURiz
Senior Member
JMURiz's Avatar
Quote:
That's what I plan on doing, how do all the seams look, or can you even see them? I was curious as they have a seam every 2' or so...
Looks great to me from the pics.
__________________
Nathan
22'x24' detached garage *Outside complete, working on interior*
Various cars and motorcycles to be stored inside.
JMURiz is offline   Reply With Quote
Old 01-13-2009, 01:46 PM   #7
PurdueSD
Senior Member
PurdueSD's Avatar
Ive got white metal up... and highly recommend.
It really reflects light well and goes up quick with no stinking sanding or painting. If you decide to go with metal. Get the cheapest paint available. Some suppliers even offer 2nds that are much cheaper. I did my whole shop ceiling (`1700 sq/ft) in about 2 days for about 1300 bucks
http://i92.photobucket.com/albums/l2...egarage003.jpg
__________________
My Truck Shop Build thread... (SOLD)
http://www.garagejournal.com/forum/s...ead.php?t=9671
Help me brainstorm the new shop!
http://www.garagejournal.com/forum/s...d.php?t=338743
PurdueSD is offline   Reply With Quote
Old 01-13-2009, 02:04 PM   #8
tfi racing
Senior Member
tfi racing's Avatar
I'm considering white metal siding/roofing as well for the ceiling,I don't feel like taping and mudding or paying to have it done.How does it hold up to the weight of the insulation,I'm thinking of going with blown insulation in the attic.
tfi racing is online now   Reply With Quote
Old 01-13-2009, 02:37 PM   #9
BigChevy80
Senior Member
BigChevy80's Avatar
Send a message via AIM to BigChevy80
I used 1/2" OSB on the walls and 7/16" OSB on the ceilings in my garage. I'm thinking of painting the ceiling white to reflect a little light.
__________________
Tony
Bloomington, IL
BigChevy80 is offline   Reply With Quote
Old 01-13-2009, 05:53 PM   #10
monstergarage87
Senior Member
When i did the walls you cant see them but since i did the ceiling by myself, the ridges arent lined up so it kind of breaks up the pattern a little and you can see a little bit of a seam. But this is definitely a 2 person job with the larger sheets because the they like to fold over ontop of you when your screwing them up.
Old 01-13-2009, 06:14 PM   #11
comp1892
Junior Member
comp1892's Avatar
I am most likely going to finish my ceiling with steel also.
PurdueSD,
Is there a j-channel type trim around the perimeter of your ceiling?
Did you finish the ceiling before the walls, or does it matter which goes up first?
Thanks,
Chris
comp1892 is offline   Reply With Quote
Old 01-13-2009, 07:23 PM   #12
PurdueSD
Senior Member
PurdueSD's Avatar
Quote:
I plan to insulate with blown in also. The steel is screwed about every 4 foot one direction and every 2 foot the other. Its very solid, the weight from insulation wont be a problem.
Quote:
PurdueSD,
Thanks,
Chris
Yes there is J channel. I put the ceiling up before the walls. Only reason being i wanted to get the steel off the floor and hadn't bought the wall sheets at that point. In a perfect world i would probly do the walls first, then the ceiling so the J covers the top of the sheets to hide any gaps from cutting on the wrong side of a line on accident. But either way is acceptable. Its not like drywall where you need to do the ceiling first.
__________________
Old 01-14-2009, 01:03 AM   #13
Torque1st
Senior Member
Torque1st's Avatar
If you use blown-in insulation and sheet metal consider the vapor barrier. The sheet metal has to be better than sheet rock tho. I never figured out how blown-in insulation provided a vapor barrier.
Old 01-15-2009, 09:58 PM   #14
sparky1562
Senior Member
sparky1562's Avatar
Where did you buy it from? I think I might go this route. What size sheets did you use?
__________________
Herb
BSEE Purdue 1986
sparky1562 is offline   Reply With Quote
Old 01-15-2009, 11:40 PM   #15
PurdueSD
Senior Member
PurdueSD's Avatar
I purchased the sheets cut to my specified length. 3ft wide by whatever length you need. I had some 14', 16' and 20'. For the 20s i took 3 of us to hang them. I purchased them from a local co-op, but you can get them at any building supply, even home cheapo stocks standard length.
__________________
Old 01-16-2009, 12:27 AM   #16
Gary S
Senior Member
I used 1" foil faced board. It is lightweight enough that you can lift it in place with one hand, and strong enough to hold your insulation in place. The 1" thick foil insulation board is R6.5. Above the R6.5 board I have R19 fiberglass blankets, and on top of the R19 blankets, I have loose cellulose insulation blown in for a R40 ceiling.
The foil ceiling reflects both heat and light down to your work area, and with 10 foot ceilings, I won't be bumping it to tear the foil.
This morning the outdoor temp was -44 and my garage was at +20 with no heat added. Just the insulation is giving me a 60 degree rise over outdoor temps.
Gary S is offline   Reply With Quote
Old 01-16-2009, 01:30 AM   #17
TheShrine
Senior Member
TheShrine's Avatar
Mine's a little different but I guess corrugated is corrugated.....
I used unmarked OSB trimmed in cedar as well....
TheShrine is offline   Reply With Quote
Old 01-16-2009, 06:59 PM   #18
Burl
Senior Member
Burl's Avatar
Where did you get this board? This is exactly what I am looking for, something with good insulation properties and is lightweight. Is it a certain brand name? Thanks.
Burl is offline   Reply With Quote
Old 01-17-2009, 09:37 AM   #19
Bencrx91
Bencrx91's Avatar
If you have the $ ... This ceiling would be functional, maintenance free and very lighted:
__________________
Ben
Bencrx91 is offline   Reply With Quote
Old 04-22-2009, 01:24 PM   #20
lbrowne
Senior Member
Figured I'd bring this one back to ask, if you put OSB on the ceiling do you need to put strapping on the trusses?
I've seen/heard of people screwing the osb right to the truss.
lbrowne is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
