Go Back   The Garage Journal Board > The Tools > Fabrication & Techniques
Reply
Thread Tools Display Modes
Old 01-12-2009, 11:44 PM   #1
ilya
Default Spray can storage rack
I'm looking to add a spray can storage rack to my service cart / work bench. I found this product on Griot's garage:
http://www.griotsgarage.com/product/...ay+can+rack.do
The design of this rack seems to be quite simple, but unfortunately I neither have a sheet metal brake nor a scroll saw. I was wondering if anyone can recommend a simpler DIY design for a can rack that doesn't require any power tools apart from a power drill.
ilya is offline   Reply With Quote
Old 01-13-2009, 12:08 AM   #2
nissan_crawler
Senior Member
nissan_crawler's Avatar
Default Re: Spray can storage rack
Search.
http://www.garagejournal.com/forum/s...light=can+rack
__________________
If guns cause crime, all mine are defective. Ted Nugent
"A man with a gun is a citizen. A man without a gun is a subject. " John Lott
"Taking my gun away because I might shoot someone is like cutting my tongue out because I might yell `Fire!' in a crowded theater." Peter Venetoklis
nissan_crawler is offline   Reply With Quote
Old 01-13-2009, 01:35 PM   #3
kbs2244
Senior Member
Check out the kitchen spice racks at Wally's
kbs2244 is offline   Reply With Quote
Old 01-13-2009, 08:43 PM   #4
e-tek
Senior Member
e-tek's Avatar
Frame it out of 1x4's - perfect size. Lots have been shown here before.
e-tek is offline   Reply With Quote
Old 01-13-2009, 09:09 PM   #5
Brad54
Senior Member
Brad54's Avatar
I copied it.
If you have a drill, a vise and two pieces of angle iron, you can make it yourself with a sheet of Home Depot metal.
Lay out the bottom, the side (upright), the top with the holes, and rather than a flange that goes flat against the wall, make a short down-standing flange that goes over the side of the tool box (just like the add-on cabinets that hang on the tool box).
Drill the holes with a hole saw.
Mark the bend lines.
Put two pieces of angle iron in the vise, close the vise, and make the bends.
Paint it red, and away you go.
The HD metal was a little thin, so I took a small strip and made little ties going from top piece to bottom piece, and pop-riveted them in, so the bottom of the rack wouldn't sag with the weight of the cans.
I also drilled a hole just slightly undersize for a piece of 1/2-inch hard metal fuel line (next to the can hole on the end), and use it for the little red straws.
If someone can post a pic for me, I'll shoot one tomorrow.
-Brad
Brad54 is offline   Reply With Quote
Old 01-13-2009, 10:01 PM   #6
ilya
Brad,
Your approach sounds exactly like what I had in mind! I'll have to get some angle iron stock, but I do have a bench vise and a drill.
Old 01-13-2009, 10:08 PM   #7
autoist
Senior Member
autoist's Avatar
Are you kidding me?!? $20.oo for a thin piece of metal bent a couple of times with 6 holes drilled in it?
__________________
Tony
http://www.theAutoist.com
autoist is offline   Reply With Quote
Old 01-14-2009, 12:51 PM   #8
russlaferrera
Senior Member
This came to me just now. Use an aluminum house gutter. You cut the gutter the length you need. Then cut the bottom making a "L" with a retractable knife. You will need 2 pieces to make 1. This will make a "U" shape. You now have to male end caps. Make them out of wood or pop rivet extra gutter material.
House gutter is cheap, this is easy to do, and it's pre painted white or brown.
russlaferrera is offline   Reply With Quote
Old 01-22-2009, 01:36 AM   #9
sctattooer
Senior Member
sctattooer's Avatar
I went to Home Depot, closet storage dept., and bought 2 of the vinyl shoe racks that hang on the wall. 9 bucks, works awesome, and looks cool too. The clear vinyl lets you see the labels, and fits the spray cans perfectly. If you dont need space for 24 cans, simply snip it down with scissors.
__________________
Quote:
Originally Posted by ZRX61 View Post
Some people really shouldn't handle anything sharper than a cupcake :)
sctattooer is offline   Reply With Quote
Old 01-22-2009, 06:58 AM   #10
Kevin54
Senior Member
Kevin54's Avatar
Go to WallyWorld and they have basically the same thing in the automotive section. I can't remember the brand name, but they are either black or dark gray, and along with that, they also sell other garage storage items along with panels of metal pegboard. At our Wally it was in the same aisle as the Rustoleum garage floor epoxy.
Kevin54 is offline   Reply With Quote
Old 01-22-2009, 10:12 AM   #11
Bob Paulin
FWIW....
I buy several cans of name-brand spray paint (Krylon, Dupli-Color, etc.) when it becomes available for 99 cents-per-can at my nearby liquidation/salvage store.
It used to be that if the cans stayed around too long before use, the nozzles would clog - no matter how much I shook the cans.
I figured out that the solids and sediment went to the bottom of the can surrounding the tube, came up the tube, and clogged the nozzle.
I now store all my rattle can paints on their sides so the solids gather on the side - not at the tip of the tube.
I have also copied an idea I saw somewhere and built a rattle can shaker out of an old $5.00 saber saw I found at a garage sale.
Bob Paulin is offline   Reply With Quote
Old 01-22-2009, 11:31 AM   #12
MOPARHOUND!
Senior Member
MOPARHOUND!'s Avatar
Cool Re: Spray can storage rack
Quote:
Originally Posted by Bob Paulin View Post
FWIW....
Great tip on storing spray cans on their sides.
I'll have to toy around with the saber saw idea. Got a pic?
Another trick I learned on one of the Dodge boards, is to set the can in a bucket of hot (not boiling, of course ) tap water prior to use for about 10 minutes. The paint flows much better.
__________________
"I guess it depends on how much you enjoy getting electrocuted." -spongerich
MOPARHOUND! is offline   Reply With Quote
Old 01-22-2009, 03:44 PM   #13
Vinko
Senior Member
Durham makes something like this too.
Vinko is offline   Reply With Quote
Old 01-22-2009, 04:34 PM   #14
bmwpower
bmwpower's Avatar
Send a message via AIM to bmwpower Send a message via Yahoo to bmwpower
http://www.amazon.com/Racor-Spray-Ra.../dp/B000AXXCVQ
Would cost me more than that in time to build it.
__________________
bmwcca 147895 | 99 m3 | 90 535i | 89 325is | 04 sienna le awd | 88 f250 4x4
my garage build | my wanted list
bmwpower is offline   Reply With Quote
Old 01-22-2009, 07:35 PM   #15
Hardware
Senior Member
Hardware's Avatar
I bought these aluminum ones
http://cgi.ebay.com/ebaymotors/TRAIL...QQcmdZViewItem
Hardware is offline   Reply With Quote
Old 01-22-2009, 07:52 PM   #16
bmwpower
bmwpower's Avatar
Quote:
Originally Posted by Hardware View Post
I like those. I need to find one that mounts on the side of a Lista SC.
__________________
Old 01-23-2009, 12:56 AM   #17
Brad54
Senior Member
Brad54's Avatar
FWIW....
Taking that a step further: get yourself a plastic milk crate, set it on its side on a shelf, and stack the spray cans in it. One of my favorite garage tips.
The sediment settles along the entire length of the can so it's quicker and easier to mix. It's also very, very much easier to find the color you're looking for, as it's usually on the top of the can.
I only keep WD40, brake clean, Eastwood's PRE cleaner, spray lithium, etc. in my can rack.
-Brad
__________________
I'm not arguing: I'm explaining why you're wrong. YOU are the one who's arguing.
Old 01-23-2009, 09:55 AM   #18
JB740i
Senior Member
I made one out of a half sheet of 3/4" plywood and screwed it to the wall. Had 4 shelves or so.
Copied someone elses design on here.
JB740i is offline   Reply With Quote
Old 01-23-2009, 10:08 AM   #19
sirswank
my rack used to be the inside of an old refrigerator door i had screwed to the wall.
this time around i will adopt the "store on their side" method.
sirswank is offline   Reply With Quote
Old 01-23-2009, 08:52 PM   #20
Hardware
Senior Member
Hardware's Avatar
i like the milk crate idea for the paints
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
