Go Back   The Garage Journal Board > The Garage > Flooring
Reply
Thread Tools Display Modes
Old 01-26-2009, 10:02 AM   #1
bochnak
Senior Member
Default Cleaning up adhesive from peel and stick tiles
My basement has peel and stick tiles that I want to replace with ceramic, except for one small area that will become a little utility room/shop.
What is the best method for removing the adhesive? Id prefer a no fume method since its winter and have small children. Im assuming I wont have to worry about it in areas were I will lay ceramic. I plan to epoxy the utility room.
bochnak is offline   Reply With Quote
Old 01-26-2009, 02:04 PM   #2
kartracer23
Senior Member
kartracer23's Avatar
Default Re: Cleaning up adhesive from peel and stick tiles
I'll assume it's on a concrete slab? When I removed mine, I just used hot water and about 10 kinds of scrapers. Long handle to get the worst off, then down on my hands and knees with paint scrapers to get the remainder. Had to keep them sharp becasue the concrete really dulls them.
Okay...I'll be honest. I paid a 15 year old kid 5 bucks an hour to remove it. But he used water and scrapers.
kartracer23 is offline   Reply With Quote
Old 01-26-2009, 06:09 PM   #3
'the epoxy floor guy'
Senior Member
'the epoxy floor guy''s Avatar
I'm afraid KartRacer is right.
The two ways I know of are:
#1 Strong Back - Weak Mind Lots of scrapers and Ambition.
#2 Solvent based 'adhesive' removers.
IF the glue is HARD and not pliable it will come off EASIER with a razor scraper. If you have a Harbor Freight you can get some 5" ones for a couple bucks.
IF the glue is GOOEY, You need a DOUBLE dose of Ambition.
Start with Stiff blade, Ram the glue until hands hurt,
Then get down on your knees until your knees and back hurt.
Repeat.
I would NOT recommend trying to HEAT the glue it will be SOFT and more Gooey.
Good Luck.
GLUE SUCKS!
PS.
IF you are going to GRIND the floor for Epoxy (I would HIGHLY recommend) you can use the grinder.
Apply a generous supply of Silica Sand OVER the glue. It will get the glue to Ball up. IF you do NOT add the sand you will heat the glue up. It will stick to the cup wheel, and you will work for twenty minutes without making ANY progress.
Tip: when taking off glue, Start in a spot as Clear as possible. Using a circular "sanding" motion. swoop into the glue about HALF of the cup size. By taking SMALL bites you will get done faster. Running the grinder over the already cleared surface will "clean" the glue from the cup.
IF you have a choice on cups pick the one with the LEAST number of segments. ALSO like I posted before a Long/Short segment design seems to work the best. DO NOT EVEN BOTHER IF THEY ONLY HAVE "Rowed" segments. Meaning a Single or Double row. You will do more harm than good.
We Offer Cup Wheels that will work "OK" for glue. I also RENT a SPECIAL PCD cup wheel for a 7" set up. It is VERY FAST at removing coatings. BUT you need to be hauling but when you do, it will tear up the floor if you don't move quick.
__________________
Professionally Installed http://amazinggaragefloors.com
'the epoxy floor guy' is offline   Reply With Quote
Old 01-26-2009, 06:15 PM   #4
mulepackin
Senior Member
mulepackin's Avatar
I have seen flooring scrapers that were like a slide hammer. You might check with your rental outlets, or flooring dealers to see if they have such a beast available. Also the electric kicker type are available. Takes a little of the agony out of that job. It is still a lot of elbow grease otherwise.
__________________
There's nothing heat and pressure can't overcome.
mulepackin is offline   Reply With Quote
Old 01-26-2009, 11:07 PM   #5
roger55
Senior Member
roger55's Avatar
Use a citrus based adhesive remover like this one:
http://www.shop.citrusdepot.net/prod...1&productId=19
roger55 is offline   Reply With Quote
Old 01-28-2009, 11:06 AM   #6
bochnak
Senior Member
I will rent a tool to help removing the tiles. My dad rented one a while back with good results. I guess it has a vibrating blade (side to side or whatever) and lifts them pretty well. I’ve also heard dry ice works well (This Old House article).
I will give the citrus cleaner a try first.
Old 01-29-2009, 01:33 AM   #7
Floorguy
Senior Member
Floorguy's Avatar
I have done a couple of floors with my shotblaster and it did rather well. Maybe a rental center around might have one. I have a 69 chevelle. See aviatar.
Best of luck.
Floorguy is offline   Reply With Quote
Old 01-29-2009, 07:07 AM   #8
bochnak
Senior Member
Quote:
Best of luck.
You ever hang out at the chevelle site? My user name is the same.
Old 01-30-2009, 01:40 AM   #9
Floorguy
Senior Member
Floorguy's Avatar
Which site do you hang at? I used to hit a bunch during the restoration but since then I don't. Give me a site andI will check it out. Chevy Diehard here. Also have a 65 Impala SS convertible that I am working on as money allows.
Old 02-20-2009, 02:49 PM   #10
bochnak
Senior Member
http://www.chevelles.com/
Sorry for the late response
Old 02-25-2009, 09:50 PM   #11
Floorman01
Junior Member
You will want to get as much of the residue off as most mortars dont stick to the glue.I have used Methyl Hydrate for this but the fumes are terrible.I have also used a citrus solution that works well it just takes longer.How bad is the residue?If it is just the residue from the peel and stick tiles a good scraping should do.
Floorman01 is offline   Reply With Quote
Old 02-26-2009, 06:52 AM   #12
bochnak
Senior Member
Quote:
Yes, they are peel and stick tiles. I did not remove them yet, so I don't know how bad the residue is. The tiles are delaminating/popping up in many areas, so it may not be that bad.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
