Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 01-26-2009, 08:40 PM   #1
pattenp
Senior Member
pattenp's Avatar
Default Fix for a 18' wide sagging garage door
I have an 18 X 8 garage door that when opened you could see that the top panel sagged in the middle even with having a 4 inch wide stiffing strip. Over time the top panel kept the bow and when the door was shut there was about a inch gap between the center of the top panel and the top weather strip. I know the easy way to take care of the problem would be to bow the weather strip to close the gap but I have this thing about stuff being visually straight. So my solution was to create a tension truss so to speak using a 3/32 cable. The cable is connected at both ends of the stiffening strip and then held out at the center by a short piece of metal channel. I put in a turn buckle to tighten the cable across the top of the door to keep the door flat when closed. It works well, so I just wanted to share this others who may have this same issue with a wide door.
pattenp is offline   Reply With Quote
Old 01-26-2009, 08:48 PM   #2
rinker1
Senior Member
rinker1's Avatar
Default Re: Fix for a 18' wide sagging garage door
Great idea, that's a common problem with wide doors, I've even seen it in 16 ft wide doors.
__________________
2001 F150 Supercrew-5.4 Spark plug launcher
My Build:
http://www.garagejournal.com/forum/s...ad.php?t=22058
rinker1 is offline   Reply With Quote
Old 01-26-2009, 09:21 PM   #3
krooser
Senior Member
krooser's Avatar
I had an 18X8 built for my new garage in 1975. the door was of a wood-composite construction. I lived there for about 8 years and never noticed any problems.
But your solution seems to be the correct answer.
krooser is offline   Reply With Quote
Old 04-14-2012, 06:58 PM   #4
dannykester
Junior Member
Genius! I hope you don't mind if I copy.
Danny
dannykester is offline   Reply With Quote
Old 04-14-2012, 07:48 PM   #5
lilredex
Senior Member
The miracles of triangles. Have a newer 17 Ft. door and it is OK for now, but that is the best method for correction of the sagging problem.
I have a couple of wooden tool shed doors that have bowed out at the bottom and no longer close flush. Was thinking of running a 1 X 3/8" (spring) bar diagonally with a 2 X 2 piece under it, close to the top, then pulling it in at the bottom with a carriage bolt (to pull the bottom in).
Had toyed with an idea such as your method, but it won't work in my case.
Thanks for sharing.
lilredex is offline   Reply With Quote
Old 04-15-2012, 01:33 AM   #6
AndyL
Senior Member
Interesting - how many teks in that truss? Is the flange mounted correctly down to the door skin?
I've seen some minimal bow in glazed 9100's before, but that's a bit excessive...
AndyL is offline   Reply With Quote
Old 04-15-2012, 09:08 AM   #7
upndown
Senior Member
Good thinking pattenp!! curious to see how that works for you. The Foamcore door with a glazed top always had a sag to it.. just not noticeable with a ceiling hung operator because with the door closed the operator arm would push the top section tight against the header. good luck!
upndown is offline   Reply With Quote
Old 04-15-2012, 09:36 AM   #8
Mr onetwo
Senior Member
Mr onetwo's Avatar
What a great idea!I have a 16' WD 8500 with no windows and it has about a 3/4" bow after 3 years.I just switched to a 3800 opener and the gap is very evident.I will be trying this fix for sure! Thanks very much for the tip!
Mr onetwo is offline   Reply With Quote
Old 04-15-2012, 10:13 AM   #9
Morrisman
Senior Member
Could you not fit some sort of 'ramp' or ledge device fastened to the roof so that when the door is open it slides into the ramp and is held up?
Morrisman is offline   Reply With Quote
Old 04-15-2012, 12:24 PM   #10
Steevo
Senior Member
Steevo's Avatar
I think it's funny to see this "idea" being used on a modern metal door.
This is how garage doors were made for fifty years or more, when they made them of wood.
__________________
My Workbench Build Thread
My Idaho Shop Build Thread
"I'd rather laugh with the sinners than cry with the saints, the sinners are much more fun" - Billy Joel
Steevo is offline   Reply With Quote
Old 04-19-2012, 05:51 PM   #11
n2ocamaro
Senior Member
n2ocamaro's Avatar
Since I have been working on my garage and being up on a ladder a lot, I noticed my 16' door sags in the middle. Putting this on my to-do list. Seems like the more work I do, the more problems I find!
__________________
Darrell P.
my 24x20 remodel in progress
n2ocamaro is offline   Reply With Quote
Old 04-20-2012, 10:37 PM   #12
bowmard
Sixteen foot garage door headers will sag over time. I've seen it on several garages built by local garage builders. I personally wouldn't have a 16 foot because of the sag problem The two new garages I had built over the years have 7' x 9' doors. A coworker built a new garage, and he wanted the 16' door. Knowing of the sag problem, for the header build-up, instead of using the normal 1/2" plywood spacer between the two 2x12 header planks he built up a fabricated (welded) truss from 1/2 steel bar stock. I believe it was 1/2" x 2". Careful attention was paid to weld sequencing so that distortion was minimal, if any at all. He then built up the header on the floor and called an army of friends over to help lift it in place. That garage is over 20 years old and the door header does not sag at all.
bowmard is offline   Reply With Quote
Old 05-22-2012, 01:07 PM   #13
pattenp
Senior Member
pattenp's Avatar
The problem I had was not a sagging header, it was the top door panel had a bow in it. My 18' header is made up of two 20" LVL beams with a story above, no sag what so ever.
Oh.. and my cable truss to flatten out the door when closed is still doing it's job very well.
Old 05-23-2012, 08:09 AM   #14
Big-Foot
Senior Member
Big-Foot's Avatar
Nice job! I like the sensor location..
__________________
Regards - Randy
http://www.GT-Forty.com
Big-Foot is offline   Reply With Quote
Old 05-23-2012, 01:43 PM   #15
pattenp
Senior Member
pattenp's Avatar
The sensor was to prevent the door from being opened when I had a car on the lift. The sensor is now long gone because the door has been converted to high-lift.
Old 05-23-2012, 02:11 PM   #16
Big-Foot
Senior Member
Big-Foot's Avatar
Quote:
Good idea and will be swiped by me for my shop door on the lift side..
__________________
Regards - Randy
Old 05-23-2012, 03:03 PM   #17
pattenp
Senior Member
pattenp's Avatar
Here where I got the sensor. http://www.walkeremd.com/Banner-Engi...Fcyb7QodCwTl2g
Old 05-23-2012, 04:13 PM   #18
Big-Foot
Senior Member
Big-Foot's Avatar
Thanks... Might be a way to use the original closing sensors for this task as well.. Run the outputs through a flip-flop and trigger a relay? Been away from the tech bench for a while, but I think I would be able to cook something up...
__________________
Regards - Randy
Old 05-27-2012, 01:48 PM   #19
TC-Tex
Junior Member
Genius!!! I'm going to do this today!
TC-Tex is offline   Reply With Quote
Old 04-17-2016, 08:22 PM   #20
patrickoneal
You're the man pattenp. I was having exactly the same issue with my 16' door. I've attached a photo that shows a little more detail on the C-channel, I'm not sure if you did it the exact same way. I used an aluminum channel from lowes that was labeled as fitting the edge of 3/4" plywood. It barely fit around a bolt head that was right in the way, but it was the biggest they had at the store.
I drilled a 1/2" hole all the way through the channel, and then cut it right in the center of the hole to make an indentation for the cable to set in. The overall length is about 8" from the end to the bottom of the indentation. This proved to be a good idea when I initially turned the turnbuckle the wrong direction and it came loose. I was able to put it back together and stretch it over onto the channel.
Before I did this, I could see light coming through a ~1/2" gap at the center of the door, extending several feet in either direction. Now it's nice and tight all the way across.
A couple of questions:
1. Have you had to periodically tighten yours up over the years?
2. I had to crank down pretty good on the turnbuckle to pull the warp out. Have your fasteners held up? I used #12 self drilling screws long enough to go through both sides of the reinforcing strip to attach the cable ends and the c-channel, but I worry a little about the shear strength where I screwed down the cables.
Thanks again.
patrickoneal is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
