Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 02-02-2009, 12:53 PM   #1
Wardrum
57 Bel Air LS-7
Default Show me your trailer winch
I want to install about a 6,000# to 9,000# capacity winch on my trailer and have a couple of questions about how to mount it and power it. Should I mount it on the deck or elevate it 8" to 10" or so? I would like to be able to remove it so I can keep it out of the weather. What is the best way to do that? And finally, how should I power it? Would it be best to mount a battery on the trailer for the winch or just use long jumper cables to the truck battery? I have room on the tongue for a tool box to put the battery in if needed. Any suggestions (and pics) would be appreciated.
__________________
1957 Bel Air 2dr hardtop
AME GT Sport chassis
LS-7
T-56
Wardrum is offline   Reply With Quote
Old 02-02-2009, 01:39 PM   #2
IHI
Default Re: Show me your trailer winch
Holy cow, why such a heavy winch?? open trailer i assume since your concerned about the weather??
Here's the one in my 28' enclosed just in case....actually used it recently after tearing the top of the engine off to winch car back into's it's house
With my 20' open trailer i have a truck tool box mounted on the front of the trailer, then mounted that trailers winch inside the truck style tool box, along with the deep cycle battery, and relay's/hand controller. Then i just mounted a roller fairlead to the truck tool box where i wanted the cable to come through....not much weather at all gets in there, rain nor blowing snow..not enough to be concerned with anyhow, been like this for 8 years and everything still works just fine.
Just run bracing between trailer floor joists to tie everything together for winch mounts, ground battery to trailer frame so everything works right.
If you want to make this removeable, which i contemplated for a little bit, get a reciever hitch, and fab that under the deck, then you'll just have to make a mount for the winch to sit on/bolt to that will sldie into the reciever in the trailer. Put the handcontroller and battery leads on quick connects and your done.
IHI is offline   Reply With Quote
Old 02-02-2009, 02:13 PM   #3
nissan_crawler
Senior Member
nissan_crawler's Avatar
__________________
If guns cause crime, all mine are defective. Ted Nugent
"A man with a gun is a citizen. A man without a gun is a subject. " John Lott
"Taking my gun away because I might shoot someone is like cutting my tongue out because I might yell `Fire!' in a crowded theater." Peter Venetoklis
nissan_crawler is offline   Reply With Quote
Old 02-02-2009, 02:16 PM   #4
tfi racing
Senior Member
tfi racing's Avatar
I agree,that's a pretty heavy winch,but if some is good,more is better!
You will want to mount a battery on the trailer,the truck battery won't likely keep up especially with the potential voltage drop because of the cable length,you will need to run a charging circuit from the truck,its nice to have a fresh battery and charging voltage when using the winch.Its a good idea to mount it all in a tongue box,to protect it from the elements and from "walking" away on you.I only have a #2500 lb winch and battery in my enclosed trailer,it pulls my 2900lb race car in effortlessly,I would suggest at least a #4000ish for an open trailer,the ramps are usually a lot steeper.
tfi racing is offline   Reply With Quote
Old 02-02-2009, 02:44 PM   #5
sammerdog
Don't know why you want to see my trailer winch, but here ya go....
http://i384.photobucket.com/albums/o...er_trash-1.jpg
sammerdog is offline   Reply With Quote
Old 02-02-2009, 02:57 PM   #6
nissan_crawler
Senior Member
Dictionary, use it.
__________________
Old 02-02-2009, 03:08 PM   #7
rsanter
Senior Member
rsanter's Avatar
I would either mount it to a reciever that you weld to the trailer (that way it could be removed for storage) or mount it in an enclosure on the front of the trailer.
by the way, if anyone is interested, I have a 10,000lb winch for sale. it came off an electric tow truck setup
bob
__________________
my wife says that I have never met a tool I havent liked. people on the other hand......
rsanter is offline   Reply With Quote
Old 02-02-2009, 08:04 PM   #8
Wardrum
57 Bel Air LS-7
Quote:
Yep, open trailer (duh, should have said that ).
I mostly pull dead cars onto the trailer but once in a while an old farm tractor. The tractors can get pretty heavy (8,000# +) so I thought it would be nice to have a little extra winch capacity.
__________________
LS-7
T-56
Old 02-02-2009, 08:11 PM   #9
Wardrum
57 Bel Air LS-7
Quote:
Originally Posted by nissan_crawler View Post
Crawler, please explain the functions of the controls in the red box. TIA.
By the way, is that an old ammo box? Very cool.
__________________
LS-7
T-56
Old 02-02-2009, 08:19 PM   #10
nissan_crawler
Senior Member
Yes, it's an ammo box.
Rotary switch is the battery disconnect, obviously. I got one from a marine place, so it has a 300 amp capacity for heavy pulls.
The switch with the green light is for the little light in the panel (and loading lights I have yet to install on the trailer), helps to see at night.
One red switch is hooked to a circuit breaker, and goes from the positive wire on the trailer harness to the trailer battery to charge it.
The other red switch is trailer hazard lights. If I have to leave the trailer on the road at night for some reason, I can turn on the flashers so people don't hit it.
__________________
Old 02-02-2009, 08:25 PM   #11
nissan_crawler
Senior Member
I had a post in free parking about all my trailer mods, but it seems to be gone?
__________________
Old 02-02-2009, 09:15 PM   #12
OldCarGuy
Senior Member
OldCarGuy's Avatar
A 4,500 pound capacity winch I added in my enclosed trailer nose. I bolted it to a 12" I beam. Making for a better cable angle when winching in a dead car or equipment. I also made the wood cabinets. And mounted the bicycle rack.
View of winch that I mounted on my tilt-bed trailer. Also the spare tire mount and tool box that I added...
I mounted the winch on an I-beam high enough for the cable to clear the trailer bed when tilted.
Here is how I winched my 6,000 pound shaper on my tilt bed trailer.
__________________
Read About:
My "Class Act" Car Hauler's===> Structural Failure
OldCarGuy's New Toy Shop Complex
OldCarGuy is offline   Reply With Quote
Old 02-02-2009, 09:41 PM   #13
mad57
Senior Member
mad57's Avatar
i bought a harbor freight special 10,000lbs winch i welded a 2in receiver (male) end on the included base plate drilled it for hitch pin, then welded a 2in female end on my trailer , i take it off when need to keep it out of the weather, i use my jump pack to power it works great for the dead cars about 2 on/offs then it goes low. been working for yrs good luck mike.
__________________
Work to live not live to work.
Iam also vice president of my car club: Wickedridesnj.com check it out!!!!
mad57 is offline   Reply With Quote
Old 02-05-2009, 12:57 PM   #14
Wardrum
57 Bel Air LS-7
Crawler, thanks for the explanation. Making the trailer hazard lights operable when the trailer is disconnected is an excellent idea.
__________________
LS-7
T-56
Old 02-05-2009, 01:09 PM   #15
Wardrum
57 Bel Air LS-7
Quote:
What make, model and capacity is the winch on your tilt-bed trailer? I'm amazed at some of the machinery you haul; that must be an excellent winch to pull those pieces onto your trailer.
By the way, how is your new trailer holding up?
__________________
LS-7
T-56
Old 02-05-2009, 05:29 PM   #16
kvom
Senior Member
A pulley arrangement will multiply your pulling power if you decide to go with a smaller winch.
__________________
'02 F350 PSD - tow pig
'97 Jeep TJ offroad buggy
'00 Jeep TJ street legal crawler
'08 Kia Sprint5 - for getting around
'12 Chrysler 200 - wife's grocery getter
kvom is offline   Reply With Quote
Old 02-05-2009, 07:28 PM   #17
OldCarGuy
Senior Member
OldCarGuy's Avatar
The winch is a Dayton 5AA17 from Graingers. Single cable pull rating is 3,000 pounds. When you double the cables using a pulley itsí capacity goes to 4,500 pounds.
http://www.grainger.com/Grainger/items/5AA17
The new trailer is fantastic and so far the paint is holding up very well too. The then sales manager at Loadtrail gave me a free axle upgrade to 14,000 pounds from the previous 10,400. Now Iím not worried about some of the heavier loads I put on it.
__________________
Read About:
Old 02-05-2009, 07:34 PM   #18
V8nuts
Junior Member
V8nuts's Avatar
that is great....lol lol lol
V8nuts is offline   Reply With Quote
Old 02-05-2009, 11:53 PM   #19
HOTFR8
HOTFR8's Avatar
Location: Castlemaine, Victoria. The Hot Rod Centre of Australia.
I still have a handwinch in my enclosed car trailer. Many times I have considered an electric winch but have just never needed it. Most Items I winch in with no problems. Most times I just drive in and use it to hold the car with the floor tie downs in place.
I would like to know how I could make my hazard lights work with out the tow vehicle hooked up. That is a great idea.
__________________
1966 (Aussie) XP Falcon Sedan, 1923 T Roadster, 1948 F4 Truck, Home Built Teardrop Camper, 1969 International 4 X 4 truck (Classic),
84 x 30 Colorbond Shed with Showroom, Workshop, Car storage and Office.
www.streetrod.com.au
The Beast Runs>http://www.garagejournal.com/forum/s...0871&showall=1
Sheddwellers>http://www.garagejournal.com/forum/s...0063&showall=1
The International> http://www.garagejournal.com/forum/showthread.php?t=32307&showall=1
"V8's are Great, But Six inlines Just Fine" - CUMMINS Advertising.
HOTFR8 is offline   Reply With Quote
Old 02-06-2009, 12:04 AM   #20
nissan_crawler
Senior Member
Well, there are two ways.
The easy one is to just wire them in with battery-switch-flasher-lights. The issue here is if you hit the switch with the tow vehicle hooked up, you're backfeeding things.
The way I did it...involves diodes, but prevents any stupidity.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
