Go Back   The Garage Journal Board > The Garage > Free Parking
Reply
Thread Tools Display Modes
Old 02-26-2009, 05:07 PM   #1
tonyvlx
Senior Member
Default How to tell if i have a Bad Brake Master Cylinder??
93 Toyota Camry
With the car running the brake pedal goes straight to the floor when pressed. I checked for leaks and found nothing. I checked fluid and it was a bit low, so i topped it up and with the car running again pressing the pedal, same thing. Oddly enough the fluid is at the full level. Would u guys think its the master cylinder??? Any help would be appreciated. Thanks
tonyvlx is offline   Reply With Quote
Old 02-26-2009, 05:09 PM   #2
krusty the clown
Senior Member
krusty the clown's Avatar
Default Re: How to tell if i have a Bad Brake Master Cylinder??
what does it do with the engine off?
__________________
DEGENERATE Main Entry: 1de·gen·er·ate
Pronunciation: \di-ˈjen-rət, -ˈje-nə-, dē-\
Date: 15th century
1 a : having declined or become less specialized (as in nature, character, structure, or function) from an ancestral or former state b : having sunk to a condition below that which is normal to a type; especially : having sunk to a lower and usually corrupt and vicious state c : degraded 2
krusty the clown is offline   Reply With Quote
Old 02-26-2009, 05:23 PM   #3
tonyvlx
Senior Member
with the engine off, the pedal still goes straight to the floor but it is much more stiffer while pressing it.
Old 02-26-2009, 05:24 PM   #4
krusty the clown
Senior Member
then yes it sounds like your master cyl is bad.
__________________
Date: 15th century
Old 02-26-2009, 05:55 PM   #5
Merkava_4
Make sure there's no air in the system. A scratched Banjo washer ended up costing me $35.00 in diagnostic fees; that's not bad though because all the other shops in town wanted $95 for an inspection and to bleed brakes.
Merkava_4 is offline   Reply With Quote
Old 02-26-2009, 08:19 PM   #6
Junkman
Senior Member
Junkman's Avatar
The best test that I know of to determine if a master cylinder is bad, is to put plugs in each of the outlets, and step on the brake pedal. If the master cylinder is defective, the pedal will sink to the floor. If it is good, it will be rock hard. You can purchase the plugs at the auto parts store.
__________________
Philosopher Emeritus Of Garage Journal
Men wake up as good-looking as they went to bed.
Women somehow deteriorate during the night.
Never argue with an idiot. He'll drag you down to his level, then beat you with experience.
Junkman is offline   Reply With Quote
Old 02-26-2009, 08:27 PM   #7
mmg440
Senior Member
mmg440's Avatar
If this is a new problem and no leaks odds of air is slim. I would say master. If you or someone had recently had the brake hydraulic system open for any reason then you could have air in lines or a caliper and or wheel cyl.
Have someone pump the pedal and look carefully to make sure you don't have any leaks before deciding to replace the master and if you end up replacing the master then make sure you bench bead before installing, then rebleed the entire system
__________________
Matt G
mmg440 is offline   Reply With Quote
Old 02-26-2009, 10:38 PM   #8
autoace
Senior Member
autoace's Avatar
Start by bleeding the system (if all four will bleed) sometimes a failed master will lose half the circuit entirely. See if it does bleed, if the pedal feels normal again? A balooning brake hose can give you a bad pedal, a leaking wheel cylinder(if it has rear drums) can leak and suck in air if faulty. Look for leaks and bleed, then give us more info...
autoace is offline   Reply With Quote
Old 02-26-2009, 11:24 PM   #9
Merkava_4
I'm wondering if the pedal started sinking all of a sudden or AFTER having brake work done.
Old 02-27-2009, 12:08 AM   #10
Nealcrenshaw
Senior Member
Nealcrenshaw's Avatar
Follow what junkman suggested, good way to to judge master cyl.
__________________
"....Give me neither poverty nor riches"
Nealcrenshaw is offline   Reply With Quote
Old 03-03-2009, 01:21 PM   #11
headwrench
quick test. hit the pedal as in a panic stop. the pedal could be firm. now push the pedal nice and easy. it will probably go to the floor. what happens when you hit the pedal hard, the quick movement of fluid will expand the rubber cup seal in the master cylinder and prevent the fluid from by-passing, thus holding pedal firm. when pushing pedal slow, the fluid just moves past the seal cup. that was a long way of saying what has already been said, bad master cylinder.
headwrench is offline   Reply With Quote
Old 03-03-2009, 01:34 PM   #12
jerk_chicken
Check the steel brake lines for rust in that vintage. I had a corolla from that area and there was no detectable leak and I even changed the MC, but the pedal was still really low. Finally took it to a shop and they said the lines were rusted in places, but we were all dumbfounded over why it didn't show. Even they had to look close. Lines replaced for $100 and good as new.
jerk_chicken is offline   Reply With Quote
Old 04-16-2011, 12:56 AM   #13
clarkandrew45
Junior Member
Hey everyone and an apology for puttin this thread up. Supposed to be, im planning to start a new thread in other discussions but im afraid no one will pay attention onto it. until i came to this one. I badly need some sort of help. So guys please pay attention to this. Any help will be highly appreciated. So, this morning I changed over my stock front brake lines to Goodridge Braided lines.Taking the old ones off and replacing them with the new ones was no hassle,in fact it was piss easy! Now my problem is this (sorry to re-hash and old chestnut) when I proceed to bleed the Master Cylinder I'm not getting any resistance in the lever.It just pulls straight to the bar. I been bleeding for over a hour without any success,the amount of brake fluid in the resovoir hasn't changed one bit. Could my master cylinder be damaged?
My brakes were fine yesterday,but today I can't get' em to work! This is really giving me the shits as I don't have a car my R6 is my only mode of transport,look like I'm walking to work tomorrow!!
clarkandrew45 is offline   Reply With Quote
Old 04-16-2011, 08:11 AM   #14
bgott
Senior Member
Any time you bleed a system with a used master cylinder you want to make sure you don't stroke the master cylinder through it's whole length of travel. The reason is that crap and rust builds up on the inner walls where the piston seals don't normally wipe. When you run the piston through a full stroke you drive the seals over and through this stuff and it tears them up. As Junkman stated above, you need to disconnect the lines on the master and plug 'em and test it that way. You might have just drained the prime out of the master, fill it up and while the lines are off, plug the ports with your thumbs and have a helper stroke the cylinder through a few times. It's messy but it works.
bgott is offline   Reply With Quote
Old 04-16-2011, 09:05 AM   #15
mrbreezeet1
Senior Member
mrbreezeet1's Avatar
Location: Moundsville, WV, 15 miles South Of Wheeling WV
Re the OP, I would pull all 4 wheels and just make sure everything is/looks OK.
Also, I have seen a few cars with a bad wheel bearing and the caliper piston was pushing the rotor about an inch or more, and letting the pedal go to the floor.
Thanks,
Tony
mrbreezeet1 is offline   Reply With Quote
Old 11-02-2011, 02:04 PM   #16
TheBigDog
Junior Member
does anybody know how to get the resevoir off the master cylinder
TheBigDog is offline   Reply With Quote
Old 11-02-2011, 04:18 PM   #17
Moose-LandTran
Senior Member
Moose-LandTran's Avatar
Send a message via AIM to Moose-LandTran Send a message via MSN to Moose-LandTran
Quote:
Usually has a screw of roll pin through a plastic tab from the reservoir, you remove it then pull the reservoir up out from the master cylinder.
__________________
Quote:
Originally Posted by cosmik binturong
I lived in a forest, I could always go punch a Moose or something.
Moose-LandTran is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
