Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 03-05-2009, 08:13 PM   #1
70redbee
Senior Member
70redbee's Avatar
Default Homemade Air Dryer
Has anyone ever made a homemade refrigerated air dryer? The prices of these things is out of site,maybe I can build one out of spare parts.
70redbee is offline   Reply With Quote
Old 03-05-2009, 08:49 PM   #2
rickairmedic
Senior Member
rickairmedic's Avatar
Default Re: Homemade Air Dryer
I realise its Horrible Fleight but this one seems like a good deal .
http://www.harborfreight.com/cpi/cta...emnumber=40211
Rick
rickairmedic is offline   Reply With Quote
Old 03-05-2009, 09:56 PM   #3
DGC15
If your only going to use it occasionally then you can make one out of a bucket and a roll of copper tubing. Put two bulkhead fittings in the bucket, one at the top and one at the bottom. Connect the coil of tubing to them inside the bucket. Air in at the top and out at the bottom. Put a drip leg on the outlet to collect the water. Fill the bucket with water and a lot of ice. Keep it filled with ice and you are good to go.
DGC15 is offline   Reply With Quote
Old 03-05-2009, 10:25 PM   #4
The Muffin Man
Senior Member
The Muffin Man's Avatar
Quote:
I've used a similar concept to make an air conditioner for a cabin. Works like a charm on those hot and humid nights .
The Muffin Man is offline   Reply With Quote
Old 03-06-2009, 10:09 AM   #5
twostory
Senior Member
Rick
With the 20% coupon, that would only be $288 plus tax. I get a 20% coupon every week via email from HF.
twostory is offline   Reply With Quote
Old 03-06-2009, 12:23 PM   #6
yhprum
Senior Member
I havent tried this myself just yet, but will. Google Franz-o-nator and read the threads that come up on another forum.
I am going to make one up from threaded fittings.
Steve
yhprum is offline   Reply With Quote
Old 03-06-2009, 04:45 PM   #7
Stephenw
Senior Member
Stephenw's Avatar
I have the Harbor Freight refrigerated air dryer.
There are two methods used in industry to dry compressed air. One is a refrigerated air dryer. The other is a dessicant air dryer.
As far as the "franzinator" thing goes, I just don't buy into the idea. The only moisture removed would be from the cooling effect of the air moving along the walls of the pipe. If it really worked as claimed, there would be commercial versions with a similar design available.
Stephenw is offline   Reply With Quote
Old 03-06-2009, 04:46 PM   #8
twostory
Senior Member
Quote:
So how do you like the HF refridgerator dryer?
Would you recommend it?
Thanks in advance.
Old 03-06-2009, 07:32 PM   #9
Stephenw
Senior Member
Stephenw's Avatar
Thanks in advance.
It works and appears well made. Mine hasn't seen a lot of use. I bought it, tried it out, and then moved to a new house. I haven't got it set up yet at my new house.
Old 03-07-2009, 02:40 AM   #10
zulueta
Junior Member
Its always have a good feeling of DIY specially if you really have the knowledge.
A little more research will be a big start/help on that project.
So keep researching!...
Good luck!
zulueta is offline   Reply With Quote
Old 03-07-2009, 09:10 AM   #11
e-tek
Senior Member
e-tek's Avatar
I have a dessicant air dryer and think it's great. I filled mine about a year ago with pellets and have done a lot of sand blasting, primed and painted a car and used it alot with perfect results. I was going to change the pellets last week but it was till full! So it's cost effective as well!
e-tek is offline   Reply With Quote
Old 03-08-2009, 11:39 AM   #12
buening
Senior Member
There is the Motorguard filter and people use toilet paper rolls instead of the motorguard filters. Haven't heard of anyone making a dryer though.
__________________
1970 Mach 1
1970 Mustang Fastback
2003 Mustang
2005 F150 FX4
Licensed Professional Engineer, PE (Civil)
Licensed Structural Engineer, SE
buening is offline   Reply With Quote
Old 03-08-2009, 10:02 PM   #13
Identaltech
Senior Member
Identaltech's Avatar
go with a dessicant dryer.
works better than refrigerated dryers.
uses no power, no need to have running will not in use.
allways ready.
Identaltech is offline   Reply With Quote
Old 03-08-2009, 10:05 PM   #14
Identaltech
Senior Member
Quote:
we have units out for 10 years and dessicant is still good.
what type are you using that you need to refill?
How are you regenerating the dessicant?
Old 03-08-2009, 10:21 PM   #15
383astro
Senior Member
I bought a used Speedaire refrigerated dryer because I could not find a cost effective dessicant dryer. I couldnt find a dessicant dryer that would handle my compressor cheap enough. My compressor/pump makes 34.8 CFM at 125 PSI. My speedaire will take the moisture out of 35 CFM max. I bought it off ebay for 367.00 plus 40.00 shipping and works like a charm. There are a couple of speedaires on ebay depending on your needs.
383astro is offline   Reply With Quote
Old 03-08-2009, 11:08 PM   #16
senlow
Senior Member
senlow's Avatar
You should not need to change the dessicant. If it has turned from blue to pink, it has absorbed all the moisture that it can. To rejuvinate the dessicant, just spread it on a cookie sheet and place in an oven at 200-250 degrees. This will drive out the moisture. This may take several hours depending upon the amount of dessicant that is in the oven. I find that it helps to open the oven door ocasionally to release the moisture from the oven. You will know that the process is complete when the dessicant has turned bright blue. Pour it back into the dryer and you are back in business.
senlow is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
