Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 03-08-2009, 01:24 PM   #1
xroad
Senior Member
Default Hydraulic Jack Release Valve
I can always lower my car SLOWLY with all hydraulic jacks I have owned in the past. My new (cheap ass) $60 Harbor Freight 3 ton jack literally drops the car down when I release the valve. It is what it is ..... or is there something I can do about it? I am not doing it right?
xroad is offline   Reply With Quote
Old 03-08-2009, 01:43 PM   #2
Uncle Buck
Default Re: Hydraulic Jack Release Valve
Quote:
Return it to them and swap it for another one.
Uncle Buck is offline   Reply With Quote
Old 03-08-2009, 02:03 PM   #3
Nova72
Senior Member
Send a message via AIM to Nova72
mines doing the same thing... so i will keep track of this thread.
Nova72 is offline   Reply With Quote
Old 03-08-2009, 02:11 PM   #4
Uncle Buck
I bet you guys will find HF easy to work with as far as returns go, unless the jacks are 10 years old or something like that.
Old 03-08-2009, 08:44 PM   #5
xroad
Senior Member
Quote:
They are trying to sell me extended warrenty, beyond the 3 months manufacturer warrenty.
Are they changing their policy? You mean they use to exchange even after (or around) a year?
Old 03-08-2009, 08:47 PM   #6
xroad
Senior Member
Quote:
I was hoping it may need a break in period. I guess it did not break in for your jack?
Old 03-08-2009, 08:52 PM   #7
xroad
Senior Member
Do you think it may just be the design, or quality assurance problem?
Old 03-08-2009, 11:37 PM   #8
Uncle Buck
Got me, I have not a clue. AllI know is if you just bought it and it is acting up, take it back and swap it. When they give you the new replacement try it out in the parking lot before you leave to make it is good before driveing all the way home to find out you have another clunker or something like that.
Old 03-08-2009, 11:40 PM   #9
Uncle Buck
I have never had to exchange a jack with them. I just figured so much of their stuff comes back they better have a preatty liberal replacement policy.
However, if you are past some date and they only want a few bucks to extend their lousy warranty I say give them a few bucks and get the replacement. That would seem far cheaper than buying another jack to me.
Old 03-09-2009, 12:33 AM   #10
nissan_crawler
Senior Member
nissan_crawler's Avatar
first off, show a good pic of the design. On one we had, I was able to take a pipe fitting, weld a restrictor inside of it, and put it back together. The way the jack was set up, it only affected the return. It worked great, you could open the valve and just let it do it's thing. My 2.5 ton long frame HF jack works great with no mods.
__________________
If guns cause crime, all mine are defective. Ted Nugent
"A man with a gun is a citizen. A man without a gun is a subject. " John Lott
"Taking my gun away because I might shoot someone is like cutting my tongue out because I might yell `Fire!' in a crowded theater." Peter Venetoklis
nissan_crawler is offline   Reply With Quote
Old 03-09-2009, 10:21 AM   #11
xroad
Senior Member
Quote:
Thanks. Unfortunately, that is way over my head. I can go as far unscrew and screw back something. Maybe a half ass job on copper pipe soldering.
I'll be hauling it back to HF for an exchange. I hope it is not poor design. That means I'll get another one that works the same way.
Old 03-09-2009, 02:36 PM   #12
Nova72
Senior Member
i cant say i have used the jack a ton. but if it the lift is high, and the jack is supporting a lot of weight, it is worse. lower levels and less weight it does better. i cant say bleeding it helped much.
Old 03-13-2009, 01:00 AM   #13
xroad
Senior Member
Returned the jack to HF. Got a replacement, same model. Worked a lot better. So much for six sigma at the factory It still comes down pretty fast if I am not careful, but I can certainly meter the release much better.
Pet theory #1: The release valve thread needs a break-in to smooth out the thread to avoid a sudden snap open and doing an overshoot to wide open of the valve.
Pet theory #2: The thread can be of finer pitch to get more turns per valve opening. Now, it feels like full close to full open within 10 degree of rotaton!
Looks like the factory saved the money on grease. I greased the whole jack, every place I can find and reach. It felt MUCH better. I hope this jack last. I really like it.
Made a saddle pad from a hockey puck. Shaved one side to a dome. Place it dome side down on the metal saddle tray to allow self alignment if the bottom of the car is not parallel plane to the jack's saddle tray.
Old 03-13-2009, 08:37 AM   #14
xroad
Senior Member
Better yet as Nissan_crawler said ... reduce the port size to get the fluid flow rate down so it does not matter if the valve is full open. I like this idea better.
The exploded diagram that comes with the jack manual shows a ball bearing at the release valve seal. Am I reading it right? Are all seals design the same way? I think I'll retreive my other old leaky jack and do a disection to see what is behind that valve.
Old 05-01-2009, 06:25 PM   #15
Hiball
Senior Member
Hiball's Avatar
Searching thru some old posts to try and help people with hydraulic problems, First off Yes it is very common for taiwan and some american made jacks to use a ball bearing and a seat for the release, And yes they are very hard to control the release but thats the nature of the beast. On the more expensive jacks they primarily use needle valves which are much easier to control the exit of fluid thus let your vehicle down easier. I wish i could tell you a easy fix but there really isnt one. Just be carefull.
After thinking about it for a bit, The only real fix i could think (and its not too easy) would be to unscrew the release rod, use a magnet to pull the ball, If the ball is considerably smaller than the opening (really shouldnt be) you could find a bigger ball that would slide in/out easy... DONT get it stuck cuz then you have bigger problems.... After finding the correct ball size, find some hand held ball reamers, prefferably one that matches your new ball size and CAREFULLY ream ( When i say Ream, i actually mean gently remove some metal to create a nice seat.) It may take a few trys to get a good seat out the old seat to match your new ball. Bigger diameter ball will let less oil around it, thus slow the decent of the jack. You could always try it once and if it didnt work return it for a exchange.. I mean it was faulty before you messed with it right?
Last edited by Hiball; 05-01-2009 at 07:14 PM. Reason: New Idea for fixing problem.
Hiball is offline   Reply With Quote
Old 05-01-2009, 11:53 PM   #16
vssjim
Alliance Member
My Walker, Lincoln and Millwaukee Hydraulics jacks all work good.
vssjim is offline   Reply With Quote
Old 05-02-2009, 12:31 AM   #17
Torque1st
Senior Member
Torque1st's Avatar
Many jacks use the ball bearing against a seat in order to reduce alignment problems inherent in any manufacturing operation. Many jacks have been ruined by gorillas tightening the release valve and deforming the seat etc. My own floor jack was ruined last year by a "helper" that grabbed the jack and gave the handle a twist before I could stop him. I have not looked into repairing it yet. HF and many other stores will re-box returned items and place them back on the shelf. It may be that you got someone else's gorilla tightened jack return.
Torque1st is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
