Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#1 |
Senior Member
Had a nice weekend in the shop- I got my compressor placed in it's closet, and got all the air lines piped in.
Here is a before pic: ![]() Sorry for the dark photo- the wall on the right is where ended up putting my air filters and reel. The compressor is a Devilbiss 5hp/80gal that I got from my grandfather. He got it free- it ran but had some issues, so he rebuilt it and realized that he had no use for it. Thanks Granddad! ![]() After reading about nice quality hose reels here on GJ, I bought a really nice reel from Coxreels. Made in USA, and top shelf quality. This was the most expensive part of my kit; think I paid around $100. Anyway, I also bought an Arrow filter/water separator and a coalescing filter on eBay. Total was like $50 after shipping. I also got a nice Hankison desiccant dryer for a whopping $30. I was thinking about making my own until I realized I could get it all on eBay for less than the materials would cost me. Here it all is after piping it up: ![]() Since my air compressor closet separates the two sides of my garage a bit, I knew I wanted to be able to swing my reel to either side. I spent a couple hours fab'ing up this mount: ![]() I made it out of some scrap I had- I wanted it to be pretty burly... That hose reel is heavy. It turns about 110 degrees, and suits my needs perfectly. Here is a detail shot: ![]() Now I have to take it back down to paint. The only thing I am not satisfied about is the regulator I have on the air discharge- it is home depot/Husky crap. I set the manifold up so I could valve off the desiccant dryer- I only need to use that for spraying paint... The other two filters and my iron pipe do a fantastic job eliminating moisture, so I figure I can reduce my desiccant replacement by only using it when I need really dry air. Anyway, the reg I have for the desiccant side is only good for 65 lbs, which is plenty for my HVLP gun, and is a good quality unit. Just need to find a good reg for the other line now. Made for a pretty good weekend in headquarters! |
#2 |
I really liked your swivel mount, so much so I swiped a copy for my file of computer pics to make one for myself!
#3 |
Senior Member
Make sure you use 4130 steel for the hinge parts, and grade 8 bolts... That is what I used! OK, I know that is stupid overkill, but it is what I had laying around!
#4 |
Senior Member
#5 |
Senior Member
BTW very nice, 2 thumbs up. nice fab skills. What kinda plasma you got?
#6 |
Senior Member
Looks great I think I may have to pilfer that reel hanger myself
. I will be mounting one of my reels from the ceiling and the other will be wall mounted .Rick |
#7 |
Senior Member
Looks great!
Do you think some nylon washers in the pivots would help? |
#8 |
Senior Member
Is there a specific vendor you used from ebay? I need many of those same parts, if there's a vendor you could recommend, I'm sure many of us would appreciate the advice.
#9 |
Senior Member
I'm still flip-flopping btween wall and ceiling mounting my Reelcraft. If I wall mount I'll need some sort of swivel like that. Thanks for the pics.
I'll be real anal and point out one thing though: You should install both pivot bolts "threads down" so if you lose the nut the bolt will not fall out.
#10 |
What you didn't safety wire them nylox??????
Nice fab work, I also swiped the picture for future reference. |
#11 |
Senior Member
You may look into using some thrust bearings between the two brackets to minimize friction and wear
__________________
1970 Mach 1 1970 Mustang Fastback 2003 Mustang 2005 F150 FX4 Licensed Professional Engineer, PE (Civil) Licensed Structural Engineer, SE |
#12 |
Senior Member
While we are nit picking, the top ear on the moving part should be on the top of the ear of the non-moving part.
Just like the bottom one. But I would bet his grand kids will be useing that hinge just the way it is now. |
#13 |
Senior Member
I think he got confused, someone told him to make a bracket to mount the air thingy, he thought they wanted the entire compressor mounted on the wall............
#14 |
Senior Member
Regardless of all of the "You did a good job, but" remarks, I think it looks great.
I wish I had a tig welder. |
#15 |
#16 |
Senior Member
you must have stayed at a holiday inn express!
#17 |
Nice job on the bracket! Wish I could weld.....
#18 |
Senior Member
Having a swivel bracket like you have will be very convenient. I thought I remembered seeing a swivel bracket made by Coxreels. It was nowhere near as beefy or nice as the one you made.
The other two filters and my iron pipe do a fantastic job eliminating moisture, so I figure I can reduce my desiccant replacement by only using it when I need really dry air. That desiccant can last a surprisingly long time. I’ve have a Dryaire filter system, I think I’ve had it about 3 years. I’ve renewed the desiccant 2 or 3 times already simply by putting it in shallow tin foil type trays and then putting them in the oven until the beads turn blue again. I run the system with the desiccant filter all the time. See photo for my coxreel and the air filter system. |
#19 |
Senior Member
I love this place- Lots of warm fuzzies from people who like your work, and every piece of "nit-picking" I got were exact things that I had thought about and exercised my own OCD over!
I thought about turning some nice bronze bushings, or maybe putting some nylon washers or something, but I did such a good job stress-relieving while welding that the two parts fit perfectly. Don't need no stinking thrust bearings or nylon washer! It has a VERY smooth pivot to it- doesn't take any effort, but isn't too loose either. As far as equipment, I cut the parts with my Thermal Dynamics Pak Master 75 XL Plus. Say that three times fast! I was going to put the root pass down tig, and follow up stick, but it looked so pretty, and I was all set up so I just tig'd the whole thing. Machine is a Thermal Arc 250 GTS. Oh, and I bought all the stuff from different vendors... None of them were particularly stellar, but not too bad either. The filter was supposed to have a sight glass and didn't, and the coalescing filter was supposed to be 3/4" NPT but was 1/2". My rule of thumb on ebay: don't buy from anyone who's feedback is below body temperature. I seem to do ok. I would suggest Arrow products- not a famous enough name to command a lot of searches. You can get NOS for cheap. Great products too. Mine both have auto drain valves. Thanks for the kind words guys! C |
#20 | |
Senior Member
It is a nice set up. The only thing I'd add (you should have) is a filter after the dessicant dryer. The desicant leaves in the DRY air, which you'll see every time you empty it. I see you have a reg, but you need a filter for sure.
My dessicant dryer is also 3 feet long! Wonder what the efficeincy is of big vs. small (I should ask Mrs E-tek!!)
__________________
VISIT me at www.E-TekRestorations.com OR, read the blog: www.E-TekRestorations.blogspot.com Quote:
| Thread Tools | |
| Display Modes | |
