Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 03-09-2009, 08:56 AM   #1
alkemyst
Senior Member
alkemyst's Avatar
Default Low cost alternatives to T1-11 for siding?
My workshop needs to be resided soon. Is there alternatives to T1-11 that are low cost? I will be doing this myself so labor intensive costs will be free
Its 14x16 if it matters.
Thanks
alkemyst is offline   Reply With Quote
Old 03-09-2009, 09:20 AM   #2
global72
Senior Member
global72's Avatar
Send a message via Yahoo to global72
Default Re: Low cost alternatives to T1-11 for siding?
I used the hardi board that looks like T1-11. About the same money but seems to hold up better than T1-11
__________________
Shannon Flesner
www.StrictlyToolBoxes.com
888-289-1952
global72 is offline   Reply With Quote
Old 03-09-2009, 11:06 AM   #3
PAToyota
Senior Member
PAToyota's Avatar
Send a message via AIM to PAToyota
I thought that T1-11 was the low cost alternative...
PAToyota is offline   Reply With Quote
Old 03-09-2009, 11:54 AM   #4
alkemyst
Senior Member
alkemyst's Avatar
Quote:
Looking for something a bit nicer/longer lasting than T1-11 but still on a budget.
Old 03-09-2009, 12:57 PM   #5
PAToyota
Senior Member
PAToyota's Avatar
As global suggests, take a look at Hardi-board: http://www.jameshardie.com/homeowner...l_sierra.shtml
It will definitely last longer than T1-11 and holds paint a lot better too.
Old 03-09-2009, 01:25 PM   #6
alkemyst
Senior Member
alkemyst's Avatar
called and got pricing, the hardiboard was $31.34 and the T1-11 27.80...by the time I prime both sides of the T1-11 it's a wash.
I am going to try and get the stucco look board.
Old 03-10-2009, 02:08 AM   #7
Steve in Mi
Senior Member
Steve in Mi's Avatar
I wonder WHICH T1-11 you got a price on?
__________________
Work safe, have fun, enjoy the sport.
Remember that a guy never has to come down out of the clouds if he keeps filling the valleys with peaks. Steve
Steve in Mi is offline   Reply With Quote
Old 03-10-2009, 07:25 AM   #8
alkemyst
Senior Member
alkemyst's Avatar
5/8" 4x8" sheets
Old 03-10-2009, 12:07 PM   #9
burger
Senior Member
burger's Avatar
I have Hardi-Siding on my garage and love it. Note that this is the plank siding, not the 4x8 sheets. It was a PITA to install, but it looks great. I would definitely do it again. And in your specific situation, I would pay $4 more per sheet without thinking twice. Ever notice how most T1-11 is rotted at the bottom?
burger is offline   Reply With Quote
Old 03-10-2009, 12:13 PM   #10
Sundowner
Senior Member
I have hardit siding, both the T1-11 style with battens over top and the lap siding style. It's good stuff and worth the extra coin. LP alsl makes a treated OSB variant of T1-11 called "smartside". It comes preprimed, which is cool, and last time I looked it was $20/sheet and HomeyD. You see it used for utility sheds alot.
Sundowner is offline   Reply With Quote
Old 03-10-2009, 01:22 PM   #11
Steve in Mi
Senior Member
Quote:
Originally Posted by alkemyst View Post
5/8" 4x8" sheets
I think you'll find T1-11 referrs to style. I do know that there are different materials given that name at vastly different prices. Pine T1-11 is available in 3/8" and 5/8", Fir is available in 5/8" (the product I used for my shop) and maybe others. Pine 5/8" T1-11 cost was ~65% of Fir 5/8" T1-11 etc.. Then there are the other products named above that are T1-11 - thus my question. Thanks.
__________________
Old 03-10-2009, 01:38 PM   #12
alkemyst
Senior Member
alkemyst's Avatar
It's the one that is the one that supposed to last the longest here in S. Florida...about 5-6 years with good luck. I have been talking to more about it and most will say the only drawback to hardiboard is wieght and if you need to saw it, it takes a special blade and is VERY dusty.
I only have straight shots and a couple angles for the roof.
Old 03-10-2009, 01:42 PM   #13
alkemyst
Senior Member
alkemyst's Avatar
Quote:
I just have to walk out to my workshop
Old 03-10-2009, 03:06 PM   #14
PAToyota
Senior Member
PAToyota's Avatar
When I did mine, they said you could just use a carbide blade. After wearing out two I went for a diamond blade at slightly over the cost of two carbide blades - it is still going strong.
If you're going to do any serious amount of it, spring for the shears made to cut it. No dust.
Old 03-17-2009, 10:54 AM   #15
burger
Senior Member
burger's Avatar
Sorry to dig up an old post, but had some more information the original poster might want:
I used this shear attachment that fits onto any corded drill. Worked perfect and was half the cost of the Makita shears. No dust and clean, fast cuts.
Again, I highly recommend Hardi Siding -- looks great and will outlast you.
Old 03-17-2009, 12:35 PM   #16
Tman
Senior Member
The shear makes it a dream to work with. You will like how it holds up also.
__________________
Race, Hot Rod and performance parts.
www.compulsionrodandcustom.com
Tman is offline   Reply With Quote
Old 03-18-2009, 12:38 AM   #17
2level
The siding contractor that installed my hardiplank lap siding (8 1/4") said the diamond blade method is faster then using shears. His sawblade only had a few cutting teeth. For what it's worth, all those guys do is exterior siding and trim. They have installed cement board on hundreds of houses.
2level is offline   Reply With Quote
Old 03-18-2009, 09:06 AM   #18
PAToyota
Senior Member
PAToyota's Avatar
The diamond blade is definitely quicker. But the shears definitely get rid of the dust.
Old 03-18-2009, 06:54 PM   #19
Tman
Senior Member
Quote:
Thats fine but his mexicans probably do not care about silicosis. I have done it both for myself and professionally and prefer the shears. with a straight cut we are talking the difference of 2 seconds per cut, if that. The saw throws too much nasty dust into the air.
__________________
Old 03-19-2009, 02:26 AM   #20
2level
Not that it really matters, but no hispanics on that particular crew. They had one guy cutting and two hanging the siding. He is aware of the dust risk and wears a mask if working inside a building.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
