Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 03-16-2009, 08:01 PM   #1
1320stang
Senior Member
1320stang's Avatar
Default So I picked up the Snap On YA642 jack for $50 I posted about last week
http://www.garagejournal.com/forum/s...ad.php?t=32004
And since
All I did was put it into the garage so far. I'm going to clean it up, change the oil in it. I think it'll need a kit in it though and I'm having a hard time finding one on the 'net.
The serial number is 6642V26088. Model number YA642, series A. 2 ton with a range of 3 3/4" to 20".
You have to put some pressure down on the jack for it to go up, as well as pressure for it to go down.
Once I get it working, should I leave it alone just cleaned up or should I restore it?
__________________
_________________________________________________
Larry Hampton
1963 Fairlane 2 door post
1965 Mustang Coupe
1973 F-100 longbed
2002 Pontiac Grand Prix
2003 Explorer SportTrac
2005 Honda Accord
2008 Mercury Mountaineer
2015 F-150 Screw 5.0 2wd
Quote:
Originally Posted by raccoon View Post
PS: I'm a girl..
1320stang is offline   Reply With Quote
Old 03-16-2009, 08:02 PM   #2
GrantMLS
Senior Member
GrantMLS's Avatar
Default Re: So I picked up the Snap On YA642 jack for $50 I posted about last week
wow nice find!
GrantMLS is offline   Reply With Quote
Old 03-16-2009, 08:05 PM   #3
bmwpower
bmwpower's Avatar
Send a message via AIM to bmwpower Send a message via Yahoo to bmwpower
Hmmm....hard to say. Get the grime off and you may have a new finish underneath.
How do you lower the arm?? I don't see a mechanism at the bottom of the handle.
__________________
bmwcca 147895 | 99 m3 | 90 535i | 89 325is | 04 sienna le awd | 88 f250 4x4
my garage build | my wanted list
bmwpower is offline   Reply With Quote
Old 03-16-2009, 08:05 PM   #4
billymade
Senior Member
billymade's Avatar
I'm sure it is a standard Lincoln jack rebadged oem for snapon; once the cylinder is out, you probably can id it from there or call Snapon for tech support. The parts on Snapon's website are here:http://buy1.snapon.com/catalog/parts...group_id=21744
Aside from the plunger; the parts seem relatively inexpensive through Snapon.
Standard Lincoln parts maybe cheaper elsewhere. I'm sure Elroy can chime in and help as well....
Here is a place that sells Lincoln rebuild kits/parts:
http://lincolnjackparts.com/
__________________
"I can't stop buying those $1 Snap-On 1/2 wrenches!" Don't Worry Its OK, your NOT alone; tool addicts of the world UNITE!
Being able to reach into your rollaway and finding the right tool for any given situation/repair; is the ultimate power trip!
billymade is offline   Reply With Quote
Old 03-16-2009, 08:35 PM   #5
jimmycrackcorn
Senior Member
jimmycrackcorn's Avatar
Gold!
jimmycrackcorn is offline   Reply With Quote
Old 03-16-2009, 09:36 PM   #6
1320stang
Senior Member
1320stang's Avatar
When you rotate the handle, there's a small u-joint, much like a steering u-joint. You can barely see it in the second pic, this is opposed to the daisy gear like to my old jack to the left in the first pic.
I did do a search before I posted, but the closest I came up with was a model number 93642, which I'm guessing is the same thing. I also found label kits, which I took to be replacement stickers for the two on top of the arm.
The handle was a little bent, but I put it in the top end of my cherry picker and coerced it back close to it's original straightness. It still has a slight bend to it, but I think it's only noticable if you sight down it.
__________________
Larry Hampton
1965 Mustang Coupe
1973 F-100 longbed
2005 Honda Accord
PS: I'm a girl..
Old 03-16-2009, 09:42 PM   #7
bmwpower
bmwpower's Avatar
Cool....you should rebuild it.
__________________
Old 03-16-2009, 10:10 PM   #8
Speed-Racer
Senior Member
You may want to degrease it and try putting grease in the zerk fittings. The greased fittings could help with lowering. Really nice Jack, I would have purchased it at that price. It is well worth the effort to paint and rebuild if necessary. That is a really good find!
Speed-Racer is offline   Reply With Quote
Old 03-16-2009, 10:12 PM   #9
vssjim
Alliance Member
Its a Lincoln/Walker Jack Blackhawk Jack Parts co. http://www.blackhawkparts.com/ why hastle with Snap on when you can have these in a day or two and always have a outside source for jack parts that don't care who made it.
vssjim is offline   Reply With Quote
Old 03-16-2009, 10:46 PM   #10
Mezzanine
Senior Member
Wow, $50? The idiots around here list clapped out no-name jacks without handles for $65!!!
Good find!
Mezzanine is offline   Reply With Quote
Old 03-17-2009, 06:25 PM   #11
1320stang
Senior Member
1320stang's Avatar
My research has shown that my jack is a Series E and requires a 248949 repair kit. This kit is good for both D & E series jacks. The current jack is a C series and takes a 240530 kit. Blackhawk parts has it for $29.77 + shipping, and Ground is $9.25 to me for a total of $39.02. I'm gonna look local first as I'm not in a hurry, still trying to finish the house addition.
Here's a page on the history of where jacks are made as of 2005.
http://www.hyjacks.com/H2.HTM
I'm thinking of having most of it powder coated. It looks like the label kits are for Hein Warner models and not the Snap On model. If I don't do the labels, I may go for a color change. Hein Warner are blue and yellow.
I'm guessing Lincoln's were red with maybe a white handle like this Norco.
I don't care for the powder blue OTC.
I could go hammer tone or a veined finish. Maybe go with a chrome powder coat?
Any suggestions as far as color combos? (Not big into the color orange BTW.)
__________________
Larry Hampton
1965 Mustang Coupe
1973 F-100 longbed
2005 Honda Accord
PS: I'm a girl..
Old 03-17-2009, 07:47 PM   #12
vssjim
Alliance Member
No the lincoln/Walkrs were Blue and yellow H/W were orange and white, SFA has changed the colors on the new ones.
Old 03-17-2009, 08:16 PM   #13
1320stang
Senior Member
1320stang's Avatar
Well, the Hein Warners are now Blue and Yellow.
__________________
Larry Hampton
1965 Mustang Coupe
1973 F-100 longbed
2005 Honda Accord
PS: I'm a girl..
Old 03-17-2009, 10:18 PM   #14
1320stang
Senior Member
1320stang's Avatar
Well, I did some light cleanup on it, but it's further gone, finishwise.
(after and before)
(after and before)
And the U-joint in question.
__________________
Larry Hampton
1965 Mustang Coupe
1973 F-100 longbed
2005 Honda Accord
PS: I'm a girl..
Old 03-18-2009, 05:28 AM   #15
Vinko
Senior Member
Quote:
Good find!
Yes. I've noticed this too. Everybody's trying to sell all the old crap they've got. Is anybody buying it? If not, why continue to list it at the same price? I guess if it just sits in the garage, and you've got the space, why not?
Vinko is offline   Reply With Quote
Old 03-18-2009, 09:18 AM   #16
64merc
Senior Member
Cool jack you found there. From memory, it looks very much like the Lincoln jack I found the other day for $50 also. I plan on rebuilding it sometime. Are you sure you have the right kit in mind? I'll check the one that I bought locally this evening if I remember.
64merc is offline   Reply With Quote
Old 12-30-2009, 10:35 PM   #17
cronic
Senior Member
any luck on the rebuild?
cronic is offline   Reply With Quote
Old 12-30-2009, 11:14 PM   #18
Paul_NJ
Where in New Mexico do you live? Years ago I lived in Hobbs. New Mexico is my all time favorite state.
Paul_NJ is offline   Reply With Quote
Old 12-30-2009, 11:41 PM   #19
billymade
Senior Member
billymade's Avatar
Las Cruces, near El Paso, Tx!
__________________
Old 12-31-2009, 06:23 AM   #20
Paul_NJ
I lived in Hobbs in the 80's for 3 years, working on a project with El Paso Natural Gas Company. I remember driving from Jal, NM across west to Las Cruces through some pretty remote areas. As I recall, there was a range of beautiful mountains in Las Cruces. I really loved it out there.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
