Go Back   The Garage Journal Board > The Tools > Fabrication & Techniques
Reply
Thread Tools Display Modes
Old 03-16-2016, 04:16 PM   #1
ovrrdrive
Senior Member
Default CNC Plasma Table Build - Precision, CandCNC etc
I've been working on this for a few months now and am finally getting around to a build thread. I posted this on pirate too but I also wanted to post it here for more feedback. Hope you guys don't mind.
A little history on me first... I got my first welder (MM180) about 8 months ago and before that my experience with working with metal were a hf 4" grinder with cutoff wheels and a drill. I always wanted to do it though and finally got around to it and love it. I got an Eastwood Versa Cut60 at the end of October and loved that even more. About the time I realized I didn't really have much hand/eye coordination and even less raw talent I saw my first cnc plasma vid and figured what the hell, even I could do that. I read for a few months and studied, put the non-cnc capable Eastwood up on CL and sold it, and started ordering parts at the end of December. Parts started showing up in January and I got started around the end of the month, working mostly a few hours after work and a little bit on the weekends.
It's been a great experience so far. Most of my welds are ok, some borderline and a few look great. Overall I think it ended up looking pretty damned good. I'm sure my methods and skill level isn't up to what most you are doing but it really feels like it turned out pretty good. From what I can figure out the CRS rails are the only thing that needs to be almost perfect and I ended up pretty happy with them.
Enough bs and on to the build. I'll try to add to the pics but they will do most of the talking for me.
This is the order from Precision Plasma:
Magnum HD II Gantry kit in 5x10
Velox Z breakaway mount
From Velox:
ZA-650P
From CandCNC:
Dragon Cut Linux 620-4 Bundle with Linux Computer
HyT Advanced Connection Kit B (without Hub)
SheetCAM for Linux
I decided to go with Precision Plasma LLC for the gantry kit. After emailing back and forth with Ron a few times I decided on the Magnum HD II kit because my goal is to build a versatile machine that can do several different tasks because right now I'm not really sure what I'll be doing with it. If something looks like it will generate more revenue I'll change directions mid stream. According to Ron if I want to do any routing the Magnum is the better gantry and 70% of the kits he sells to people go that route. I bought the kit in 5x10 even though I am only building a 5x5 kit right now because it's cheaper to order it up front and if the table makes money for me I'll do the expansion asap. For now the 5x5 kit will be plenty.
The kit from PPllc is very complete and well laid out. Everything is in bags and is separated by section with a bag sealer and labeled. Very nice stuff...
Steel was a bitch for me here. I ended up buying from the local scrap yard as they had the most in town and were easy to work with. The first order was just the 3x3's. The second got almost all of the rest except for the CRS rails that I had to drive to Orlando to get from another supplier as they couldn't even order it here. I spent about $600 at the scrap yard and $250 more for the CRS. Only have a pic of the first pickup but you've all seen steel before anyway...
Next to show up was the order from CandCNC and the PM65 from Weldersupply.com.
Construction started with the legs. I chose to use 1/8" wall tube to make it easier for me to weld. I figured I didn't want to spend half my time stitching holes up and the extra strength wouldn't hurt either. I drilled and tapped the 1/2" plate for the legs and welded them on. I modified them a little from Ron's plans as I never plan to bolt it to the floor anyway. The feet came from Amazon and at the time these were over half of the cost of the bigger feet so I figured I'd give them a shot.
I also modified the table a little. I lowered the bottom support to make enough room to mount the plasma and possibly a toolbox under the table in the future if I ever get ambitious. It worked out like I planned but it was really a bitch painting the underside of them. I welded the side on the floor... Not exactly straight and I paid for that later on but in the end they turned out OK.
On to the cross beams with a little help from a few straps...
Then the box from velox showed up... Very pretty.
When I bought steel, I had to buy whole sticks if it was new which most of it was so I had a lot left over. I would have used smaller tube for the cross beams but this was already paid for so I stuck a few pieces of 3x3 in there for extra support under the water table.
After learning I couldn't drill straight by hand for shit I picked up this drill-press from cl for $50. It made things a lot easier.
After thinking about drilling the CRS rails and the support for them I made this little stand for it to make it possible to drill them with the press. It worked well. I measured where the rails would be and built it to that height. Then I just wheeled it over and jacked up the table until it was tight under the bottom rail and did all the drilling.
Drilling and tapping the 46 holes in the gantry cross member... First time ever using taps for me too. The ratcheting tap handle from hf really made this easy... My first attempt at using transfer punches was a miserable failure. On my second attempt (thank goodness I had extra steel...) after a few YouTube videos it was almost perfect.
Gantry tacked and mocked up...
About this time the hf air dryer showed up. I had the issue with the manual wiring where nothing happened on first plug in until I switched the wires. I had a small cooling manifold on the wall I made out of copper tube so with a lack of proper hardware to install it I just hard plumbed it in for now. If I see a need in the future I'll cut it out and use some flexible hose to hook it in. It seems to work pretty well. We'll see if it lasts.
I still laugh about this... When I was hooking it up this fell out of it somewhere. It's funny that someone was not only smoking in the plant but felt it necessary to hide the butt inside of the machine...
Once everything was pretty much built I hit it with some self etching primer and sanded the piss out of it. I decided on going two tone on the gantry and using regal red on the rest of it. Yes I painted in the garage and didn't use drop cloths. It cleans up fairly easy with some paint thinner, acetone and elbow grease but I'm going to put a fresh coat of epoxy on it when I'm done building the table anyway. next time I will probably go ahead and put some plastic down though... Live and learn. lol
That pretty much gets this caught up to where I am now. This week I'll probably work on getting the motors and wires hooked up and try to get it moving by the end of next week hopefully. Then I'll probably get some sheet bent up and work on the water table.
More to follow as I come up with anything noteworthy. I don't have a timeline for the build. It's a no pressure - work on it as I have time kind of thing. I'm trying hard not to rush it but it's getting to the point where I'm ready to fire it up.
So, How am I doing so far?
ovrrdrive is offline   Reply With Quote
Old 03-16-2016, 04:38 PM   #2
LXCam
Senior Member
LXCam's Avatar
Default Re: CNC Plasma Table Build - Precision, CandCNC etc
"How am I doing so far?"
Damn dude, you're a rockstar in my book. That's a very nice set up and I'm most impressed that you've only been doing metal for a short time, it really doesn't show. I can't wait to see how this works out for you and if you don't mind appx how much is a kit like that?
Thanks, Cam
LXCam is offline   Reply With Quote
Old 03-16-2016, 05:17 PM   #3
kazlx
Senior Member
Looking good. If you need any help, just shout. Running older versions of all the same stuff.
__________________
Instagram: randomfabrication
My Random Project Thread
Precision Plasma CNC Table Build
Fab Table Build
kazlx is offline   Reply With Quote
Old 03-16-2016, 05:54 PM   #4
bullnerd
Senior Member
bullnerd's Avatar
Nice! Carriage looks really rigid.
Nice score on the drill press, but dang how hard did someone have to turn the vari speed handle to bend it!
bullnerd is offline   Reply With Quote
Old 03-16-2016, 07:18 PM   #5
steel 35
Senior Member
steel 35's Avatar
Good times
Wait till yer stuffing wires in that bladerunner
__________________
My welder is like ZT's
4X8 CNC Plaz / Router
steel 35 is offline   Reply With Quote
Old 03-16-2016, 07:57 PM   #6
ovrrdrive
Senior Member
Thanks, Cam
Not including the PM65 I'm somewhere between $7-7500. I'll have to add everything up to be sure but it hasn't been too bad considering the options I went with. The PM65 was almost $3k by itself. That really hurt but I didn't want to spend all of this and end up with something that didn't work.
And I've only been working with metal a short time but I watched tons of shows on TV for as long as I can remember about it. Xtreme 4x4, all of Jesse James, OCC you name it. I like to think all of that helped out a lot but I can assure you the only pictures I shared don't show the blunders in it. lol
Quote:
You've already helped me out a ton. More than you realize in fact. I'm sure that color even looks familiar. lol
I'll probably take you up on that offer though. I'm going to give myself some time to learn the basics first.
Yeah no doubt. It was pretty neglected when I got it and completely rusted over. The variable speed mechanism was missing a washer under the clip holding it together so the bushing kept riding up making some terrible noises and binding it all up. Once I figured that out and put a washer in there and lubed it all up it works pretty well. This wasn't a really popular model and I understand why after playing with it. I thought I was going to kill it when I started drilling the rails when it was up on high.
It's pretty solid though and other than a new belt I think it will serve me just fine.
Quote:
Originally Posted by steel 35 View Post
Good times
Thanks for the head's up... I'll do that on a weekend day so I won't be stressed out from work. It sounds like something I probably shouldn't play with when I have a short fuse. lol
Old 03-16-2016, 08:37 PM   #7
landlord30
Senior Member
If its not too painful, a parts list would be great when you are all done.
Thanks
landlord30 is offline   Reply With Quote
Old 03-16-2016, 09:24 PM   #8
ovrrdrive
Senior Member
Quote:
Thanks
This is pretty close...
Just add a new monitor. I bought a new one for my desk and moved my old 24" Dell out into the garage. I'm sure there are more misc things too that I didn't keep track of.
Steel is a little high here too. If I had a better steel yard I'm sure I could have done better and I could also have saved some if I went with lighter gauge steel but like I mentioned above I figured the 1/8" wall would be easier for me to weld - which it was.
Also I see Ron is selling all of his kits now with the Velox Z included. That will save you some money right there even if just in shipping charges.
Old 03-16-2016, 09:39 PM   #9
LORDDiESEL
Senior Member
LORDDiESEL's Avatar
Watching with interest. I will be building a table like this soon enough.
LORDDiESEL is online now   Reply With Quote
Old 04-08-2016, 06:01 PM   #10
600SL
Senior Member
600SL's Avatar
Subscribed
__________________
48' x30' x10' build.
http://www.garagejournal.com/forum/s...d.php?t=230835
600SL is offline   Reply With Quote
Old 04-09-2016, 03:35 AM   #11
Basher
Senior Member
Lightbulb Re: CNC Plasma Table Build - Precision, CandCNC etc
A fascinating project & excellently documented
Thanks for taking the time to post
I'm in for this one -
subscribed!
Basher is offline   Reply With Quote
Old 04-09-2016, 11:03 AM   #12
ovrrdrive
Senior Member
Thanks guys. Progress has been a little slow. When I was building the table I knew basically how it went together and what to do. Since I've started installing the motors, belt reductions and bearings it's been a learning process. Ron at Precision Plasma has been great and responds to my questions quickly no matter how dumb they are. lol
At one point I thought my frame was really out of square because the gantry was touching the stop one side but was almost an inch off on the other but it turns out the gantry was just tweaked a little from when I welded it together. I used a strap and pulled it to the stops on both sides and then tightened all of the bearings and it feels rock solid now. The x motor seems to be acting a little weird in that sometimes when I hit the jog on the keyboard it goes the wrong way until I let up and press it a few more times then it goes correctly. Tom thinks I just need to apply the updates to Command CNC but I'm thinking it might be a bad motor. I'm going to do all of the updates and finish tuning the gantry and go from there.
The water table is proving to be a bear too but that mostly due to my indecision about how I wanted to build it and also from not reading the parts list closely. I can't find a 6' wide piece of sheet around here so I bought a 5' piece and cut it off int he truck to around 68" so I could move it into the garage. I also got 10' of 3"x2" angle to use for 2 of the sides. My plan was to bend up 3" on 2 of the sides and then weld the angle to it for the other 2 but then after I read the cut sheet again the angle is cut to 66" long so everything I have is too short. lol
Due to the lack of a good fab shop around here I'm just going to buy some more angle and build it the way Ron indicated in the plans. Everyone that's done it that way has complained about it but it may be my last option without spending a mint on it. I'm not above getting it as close as possible and then either using silicone or fiberglass to seal it. Not at all. I'll update when I figure out what I'm doing.
A little more tuning and I have to finish hooking up the rest of the stuff from CandCNC for the plasma and I'll be ready to run a few test files on it.
Old 04-09-2016, 12:21 PM   #13
steel 35
Senior Member
steel 35's Avatar
While your struggling with the water table think about raising your edges 1/4" above the slats! I went 1/8 and sure wish it was more.
__________________
Old 04-09-2016, 06:41 PM   #14
ovrrdrive
Senior Member
Is that just to keep the splashing down?
If I was getting it custom bent I could probably set it like that but I'll probably be stuck at whatever angle I can get. I'm going to cut the slats though. I guess I could always just make them shorter. Hmm...
Thanks for the tip.
Old 04-09-2016, 08:16 PM   #15
steel 35
Senior Member
steel 35's Avatar
Quote:
Yep! it can be horrible
__________________
Old 04-09-2016, 11:06 PM   #16
kkroger
Senior Member
I'd go half inch if I did my water table again, Or maybe even more, so I could do submerged cutting on thicker materials... not worried about splashing so much... but submerged yes...
kkroger is offline   Reply With Quote
Old 04-10-2016, 12:43 AM   #17
kazlx
Senior Member
I paid a sheetmetal shop to cut and brake up my water table. I think it was like $250 with the material if I remember right. They even welded the corners, so the whole thing is one piece minus the four corner welds. Best extra money I spent on the project. When I build another water table, the edges will definitely be taller than the cutting surface. The splashing drives me crazy.
Either that or make some sort of drip rails that go into the pan to basically contain all of the water.
__________________
Fab Table Build
Old 04-21-2016, 09:54 PM   #18
600SL
Senior Member
600SL's Avatar
It was great getting to see this project in person last week. It gave me quite a bit to think it out.
I'm still on schedule to purchase the Hypertherm 65 by the end of the month.
__________________
Old 04-21-2016, 11:17 PM   #19
ovrrdrive
Senior Member
Man I'm even having trouble getting an estimate to bend me a table around here. You'd think I lived in total BFE or something. I'm going to try the one last fab shop left in town and see if they'll call me back. If that fails I guess I'm doing the perimeter welding thing. I hate to though because I know it will leak like crazy.
Thanks for stopping by and I hope I was able to help. I don't get to show off my handy work very often. It was my pleasure.
My wife really enjoyed playing in your friends car too. It made her day. Tell him I said thanks.
By the way, do you have a build thread for your Mercedes?
Old 04-23-2016, 06:37 AM   #20
mike13u
Senior Member
mike13u's Avatar
Awesome build! Congrats. You are going to love running that beast. Hypertherm was the way to go. Settings out of the book are dialed 100%
Joe always finding the deals...You went mild steel on yours?
OP - I'm probably way South of you, but if you are having trouble sourcing material/fab shops for something specific let me know.
__________________
Owner - Metal Supermarkets Miami
& Dade Made Fabrication, Llc
Facebook:https://www.facebook.com/metalmiami/
Instagram: https://www.instagram.com/dade_made_fabrication/ And https://www.instagram.com/metal_supermarkets_miami/
mike13u is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
