Go Back   The Garage Journal Board > The Garage > Free Parking
Reply
Thread Tools Search this Thread Display Modes
Old 03-22-2009, 11:30 AM   #1
Art From De Leon
Senior Member
Art From De Leon's Avatar
Default Easiest Way To REMOVE Deck Screws
Each year I wind up having to replace a few deck boards that have become 'cupped' on the end, or is starting to split.
Because the screw head is sunken beneath the surface of the wood, and the crap that has filled up the hole, it is impossible to see the head of the screw, and most of them are not installed vertically, so using a Phillips head bit only works about 10 percent of the time.
I have used the "Grab-it" screw extractors, with SOME success, but I would really like to find a faster, less frustrating way of going about this job.
Art From De Leon is offline   Reply With Quote
Old 03-22-2009, 12:01 PM   #2
IDASHO
Senior Member
Default Re: Easiest Way To REMOVE Deck Screws
For starters, ditch the philips head screws. That is 90% of your problem. Most of them are partially stripped by the time they get sunk into the wood.
Use square-drive deck screws.
And prior to removing them, just hit the hole with compressed are and a blow gun. Be sure to use a NEW square drive bit when removing. Good to go.
__________________
See my garage build here:
http://www.bonnefinstudios.com/kwb/paradise/garage/
IDASHO is offline   Reply With Quote
Old 03-22-2009, 12:54 PM   #3
e-tek
Senior Member
e-tek's Avatar
IDASHO is correct. Square-hole (Robertson #2) screws are best. To keep from stripping them, you also HAVE to change bits every 10 or so screws - depending on how hard they are to get out. I found if I used the bit too long it wore and slipped, stripping more screws. Now I buy them in 10 packs.
e-tek is offline   Reply With Quote
Old 03-22-2009, 01:13 PM   #4
rsanter
Senior Member
rsanter's Avatar
yup
square drive stainless for decks
do not run them in so hard that they sink, the should be flush
use an air gun to blow the heads out before starting to remove
bob
__________________
my wife says that I have never met a tool I havent liked. people on the other hand......
rsanter is offline   Reply With Quote
Old 03-22-2009, 01:21 PM   #5
LoneGunman
Senior Member
LoneGunman's Avatar
As everyone has said Robertson tips, also the small impacts like my Bosch is great for getting things out without stripping them.
LoneGunman is offline   Reply With Quote
Old 03-22-2009, 05:44 PM   #6
russlaferrera
Senior Member
I used a hammer drill to remove them.
russlaferrera is offline   Reply With Quote
Old 03-22-2009, 10:47 PM   #7
Torque1st
Senior Member
Torque1st's Avatar
+1 on using square drive screws. Do not sink them. I have used a sheet rock screw gun to install them since there is a clutch unit that disengages at a pre-set depth.
+1 on the impact or hammer drill to remove them.
Remember to use STAINLESS STEEL screws on the ACQ pressure treated lumber that is all there is commonly available nowadays. The ACQ stuff is crap but it is all we can obtain from most lumberyards. There is a product called TimberSil available in some areas that is far superior to ACQ treated lumber. There are coated deck screws that are supposed to work with ACQ treated lumber but I personally do not recommend them.
Torque1st is offline   Reply With Quote
Old 03-22-2009, 11:41 PM   #8
e-tek
Senior Member
e-tek's Avatar
I offered some info and I gained some as well!! I "countersunk" all my deck screws and was unhappy with the results, as many of them splintered the wood. Also, I used coated screws, but already had to replace some. Thanks for the tips on SS screws and flush profile!
Old 03-22-2009, 11:53 PM   #9
bmwpower
bmwpower's Avatar
Send a message via AIM to bmwpower Send a message via Yahoo to bmwpower
Also, crown the flat sides of the new boards with the grain "cupped" downward.
__________________
bmwcca 147895 | 99 m3 | 90 535i | 89 325is | 04 sienna le awd | 88 f250 4x4
my garage build | my wanted list
bmwpower is offline   Reply With Quote
Old 03-23-2009, 03:39 AM   #10
Kevin54
Senior Member
Kevin54's Avatar
If the head is stripped, get a drill bit the same size as the body of the screw, and drill the head off. That way the board should come up off of the shank of the screw. I'm assuming that the boards are trashed anyways as you are replacing them. And ditto on the square head screw. Just make sure you use the proper size bit as some are very close in size. A good fit will not let the screw fall off.
Kevin54 is offline   Reply With Quote
Old 03-23-2009, 08:13 PM   #11
BoydS
Senior Member
They make a screw extractor just for that purpose. Sears has them, check your locale store. Otherwise, take Kevin's suggestion.
BoydS is offline   Reply With Quote
Old 03-23-2009, 09:51 PM   #12
mulepackin
Senior Member
mulepackin's Avatar
I remembered seeing this item in the Rockler catalog:http://www.rockler.com/product.cfm?O...s&cookietest=1
It sounded good in theory, but clearly the reviews don't sound very encouraging.
__________________
There's nothing heat and pressure can't overcome.
mulepackin is offline   Reply With Quote
Old 03-25-2009, 11:50 AM   #13
kbs2244
Senior Member
If the floor board is going to be trashed anyway, just bust it up and use a vise grips to remove the screw.
Then use the sqr drive/SS on the replacments.
Do check the grain on the end of the boards.
You want the arch to be up.
(High in the middle.)
kbs2244 is offline   Reply With Quote
Old 03-25-2009, 12:12 PM   #14
Mr. Welsh
Senior Member
Although this isn't bad advice, I personally wouldn't worry about using stainless steel on treated lumber. If you're using redwood or some other more exotic species, then I'd spend the extra money.
Mr. Welsh is offline   Reply With Quote
Old 03-25-2009, 01:08 PM   #15
kartracer23
Senior Member
kartracer23's Avatar
If you have a really nasty one that won't come up, drill holes around it with a 1/2 spade bit and just grab the SOB with vice grips and twist. I've had to do that before.
kartracer23 is offline   Reply With Quote
Old 03-25-2009, 03:07 PM   #16
Frank Elson
Senior Member
Frank Elson's Avatar
D'you know, I just keep on learning on this site.
I'm an auto man, never done much woodworking, apart from walking sticks and crooks, so had never heard of square drive screws.
However, I have a bit of a job to do outside and square drive will be perfect.
Thanks guys, and to the OP for a subject line I looked at.
__________________
Best Cheers
Frank
I !__[_]|\___
I ____|"_|"__|/ Range Rover Vogue SE
"(o)======(o)" Beluga Black LPG "TAZ"
Frank Elson is offline   Reply With Quote
Old 03-25-2009, 03:25 PM   #17
Torque1st
Senior Member
Torque1st's Avatar
Quote:
A person does not NEED the SS screws on redwood or exotic species. A person NEEDS to use SS on the ACQ treated lumber because it will quickly corrode or rust a standard screw and many of the coated variety.
Old 03-25-2009, 04:22 PM   #18
walrus
Senior Member
walrus's Avatar
Quote:
Isn't the technical term Robertson
walrus is offline   Reply With Quote
Old 03-25-2009, 04:22 PM   #19
StingRay
Senior Member
Funny how we Canadians have been extolling the virtues of Robertson square drive screws for many decades to no avial. But no the all mighty Phillips must prevail. I have to say that for drywall screws Phillips is probably the right choice. Instead of using good old Robertsons some dipshit had to come up with torx. You can put a good Robertson on a quality bit and install it in the tightest of places. The shame of it all is that the Roberson spec's are not what they used to be and quality control for all of the offshore crap is not what it should be. I frequently find myself frustrated by poor quality Robertson screws and bits that plain just don't work they were designed. One neat thing is that I see alot of combo heads now that will work square, Phillips and even slot all in one screw.
StingRay is offline   Reply With Quote
Old 03-25-2009, 04:34 PM   #20
Torque1st
Senior Member
Torque1st's Avatar
I have no idea why Phillips was so popular and so piss-poor at the same time. I have drivers for clutch head screws, called a clutch head type A, that were on an old 57 Chevy I had that are much better than Phillips. There are also variations on the Phillips head that I occasionally run into. Look about half way down on the following link for many types:
http://en.wikipedia.org/wiki/Screw
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
