Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 03-25-2009, 10:13 AM   #1
Engine-Ear
Engine-Ear's Avatar
Default building a mezzanine
Hi everyone,
I would like to share with you my garage build and follow-up with a couple of questions.
By way of introduction, I bought a 30' x 40' steel building kit from Miracle Truss. Eaves are 18' and peak height is 24'. Spent 6 months last year building it to the point shown.
Anyway the 1200 sf area will be divided into to main areas: half for cars and parts storage, half for working on stuff.
Regarding the cars/parts storage:
One pic shows 3 garage doors leading to this area. I plan to have 4-post storage lifts at each of those bays, as well as a mezzanine above that area. The mezzanine would be self supporting and not dependent on the building's trusses.
What I am trying to do is design a mezzanine and a staircase.
I originally wanted to build the support structure out of steel (I-beams, etc) but a couple of people recommended lumber for better fireproofing (comments?).
As for load calculations vs. material usage, I am not sure what to specify. My goal is to have pallet racking up there with the potential to store LOTS of stuff. ...Not talking engines but certainly sheetmetal, brackets, tires, wheels, seats, glass, etc.
I really need to get moving on this NOW because I have 3 cars to part out sitting in the driveway and a couple of my neighbors are already calling the fuzz to complain.
Engine-Ear is offline   Reply With Quote
Old 03-25-2009, 08:53 PM   #2
AGBill
Default Re: building a mezzanine
There are companies that sell steel mezzanine kits that you can assemble.
http://www.sourceequipment.com/mezza...ms-pricing.htm
They are quick and easy, well engineered but like anything that is convenient, they are a bit pricey....
AGBill is offline   Reply With Quote
Old 03-25-2009, 09:47 PM   #3
Engine-Ear
Engine-Ear's Avatar
Thanks, AGBill, at least this gives me a start...I will contact them and see how much it'll hurt for one of their systems.
Other input is also most welcome. Thanks in advance!!
Old 03-25-2009, 09:57 PM   #4
skeletonizer
Senior Member
skeletonizer's Avatar
Grainger has a bunch.
http://www.grainger.com/Grainger/wwg...lResultsSearch
skeletonizer is offline   Reply With Quote
Old 03-25-2009, 10:07 PM   #5
Stuart in MN
Senior Member
Stuart in MN's Avatar
Matt - keep an eye on Craigslist, search for mezzanine or pallet racking. On the Minneapolis list there are always people selling used mezzanine components out of factories or warehouses, I just checked Milwaukee and there are a couple on there now.
Stuart
Edit: I'd want to talk to a structural engineer about it, but if you're going to have four post lifts lined up along that end of the garage, I wonder if you could extend the vertical members of the posts up to support the mezzanine?
Stuart in MN is offline   Reply With Quote
Old 03-26-2009, 08:28 AM   #6
Mezzanine
Senior Member
Here I am.
Mezzanine is offline   Reply With Quote
Old 03-26-2009, 08:43 AM   #7
Engine-Ear
Engine-Ear's Avatar
Quote:
Originally Posted by Mezzanine View Post
Here I am.
well, my work is done!
Old 03-26-2009, 08:47 AM   #8
Engine-Ear
Engine-Ear's Avatar
Stuart, thanks.
Adding the mezzanine to the lifts is a clever notion and helps minimize crowding along the part of the floor where the vertical posts will reside.
The used pallet rack and used lifts sound like a wise move.
Old 03-26-2009, 03:29 PM   #9
KMR Construction
Senior Member
how big of a mezzanine do you want?
KMR Construction is offline   Reply With Quote
Old 03-26-2009, 09:11 PM   #10
Engine-Ear
Engine-Ear's Avatar
roughly 20 X 30, hovering over three, four-post lifts.
Old 03-27-2009, 06:07 PM   #11
KMR Construction
Senior Member
thats gonna be too big to span without a post in the middle. Otherwise consult your local lumber yard about doing some engeneering.
Old 03-29-2009, 11:20 AM   #12
Engine-Ear
Engine-Ear's Avatar
Default more on building a mezzanine
KMR, I agree...
so, here is a scan of a sketch...the 19kB PDF limit makes it pretty difficult so here's a .jpg file.
The illegible legend says:
[] = 1 sq ft
[//] = Truss 'keepout' area
== = Horizontal Support
---- = 2-by-X Joists
(blue)
I am suggesting staggered joists because they are shorter (more manageable, esp. at 13 feet UP) and the system will still 'interlock' all the vertical supports, in my opinion.
Your feedback is most welcome!
Old 03-29-2009, 01:19 PM   #13
KMR Construction
Senior Member
ok, A 2x8 will span that but go 2x10 joist 16"o.c. for the beams 2- 1 7/8" x 12" LVL with the 3 colums (steel or 4x4 pt) will give you a very strong floor. Use 3/4" T&G plywood
Old 05-09-2009, 10:01 AM   #14
Engine-Ear
Engine-Ear's Avatar
Thanks again.
I am going with wood instead of steel...btw, Stuart, "engineer9" (aka Gary) from the PY board is helping me with some structural details for this.
I will keep this thread up to date with progress.
Old 05-09-2009, 12:08 PM   #15
akdiesel
Senior Member
akdiesel's Avatar
Let me start by saying the shop looks great.
I would think strongly about extending the post of the 4-post lifts since they are designed to support the loads they were origianly set up for. Any additional weight may cause them to fail, and warrenties will be voided.
I would offset the supports, for your type of beams, so that you have the option to move your lifts if need be. Plus extend them at least 3' further out past the lifts so you can have access to get between the lifts as well.
I would do this front and back to give you the correct structural support needed and then tie them into the shop frame work to keep things from shifting.
Now the size needed for the span and weight is up to an engineer to figure out.
Good luck and keep us posted.
akdiesel is offline   Reply With Quote
Old 05-09-2009, 07:48 PM   #16
shocksystems
Senior Member
shocksystems's Avatar
Send a message via MSN to shocksystems
I love the look of the garage. Nice choice.
Jim
shocksystems is offline   Reply With Quote
Old 05-10-2009, 03:46 AM   #17
Vinko
Senior Member
A friend of mine just bought Unistrut stuff. And I like how it all went up.
Vinko is offline   Reply With Quote
Old 05-10-2009, 09:32 PM   #18
Engine-Ear
Engine-Ear's Avatar
Thanks for the feedback, guys. As for the look, I wanted to go a little more Jetsons/unusual but the cost of the kit went crazy when my creative drawings were evaluated.
Based on your (and others') recommendations, the lifts will be independent of the mezzanine, and the mezzanine will be independent of the building.
Old 09-29-2009, 10:10 PM   #19
Engine-Ear
Engine-Ear's Avatar
Back again after a long hiatus... the mezzanine has taken a dramatic turn for the better.
I ended up going with steel structure with a concrete floor. Roughly 21 x 29 with a floor that's 12 feet up so I can put 6 cars (on back yeard buddy type lifts) under it. No support posts in the middle, either.
More images coming after I get the stair case stuff in.
Old 09-30-2009, 12:15 AM   #20
Iron-Iceberg
Senior Member
Iron-Iceberg's Avatar
WOW need more details.
Iron-Iceberg is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
