Go Back   The Garage Journal Board > The Garage > Heating and A/C
Reply
Thread Tools Display Modes
Old 03-29-2009, 10:20 AM   #1
theracedude
Junior Member
theracedude's Avatar
Default Blaze King wood stove
I am going to need to buy a wood stove and was looking at the "blaze king". I like the catalytic converter type because it is more efficient. (less wood). does any one have a catalytic converter type stove and what do you think of it? thanks, randy
theracedude is offline   Reply With Quote
Old 03-29-2009, 04:02 PM   #2
fasteddie24
Senior Member
Default Re: Blaze King wood stove
Vermont Castings. I have a non-catalytic Resolute model in my basement and it burns pretty clean as soon as it heats up. There's nothing like wood heat, but you have to be careful, especially wear there may be chemicals.
fasteddie24 is offline   Reply With Quote
Old 03-29-2009, 04:08 PM   #3
walrus
Senior Member
walrus's Avatar
They still make catalytic stoves? I thought most were going with air injection. I'd go with Jotul
walrus is online now   Reply With Quote
Old 03-29-2009, 04:32 PM   #4
PurdueSD
Senior Member
PurdueSD's Avatar
I had a a nice wood stove with a catalyst at my last house before we moved. That thing was the cats meow.... It would choke the fire down and burn you out of the basment.... Ive got plans to put one in this house...
__________________
My Truck Shop Build thread...
http://www.garagejournal.com/forum/s...ead.php?t=9671
PurdueSD is offline   Reply With Quote
Old 03-29-2009, 05:12 PM   #5
sewerzuk
Senior Member
I grew up in a house heated by 2 different blaze king wood stoves (my grandfather used to sell them). We also had hot water circulator coils in ours. While I can't compare them to other brands, I can say that they lasted for at least 20 years of heavy usage and never had a problem. And they were certainly more efficient than a stove without a catalyst.
One thing I do remember however, is the frequent chimney cleanings. Our catalysts had a lever to bypass them for starting the fire. Once the fire was going, you close the lever to force the smoke through the catalyst. Because of its design, creosote tended to collect on top of the catalyst and eventually prevented the lever from fully closing. We had to open up the chimney and remove the creosote 3 or 4 times each winter. Not terribly inconvenient, but more frequent than the annual cleaning I do on my current wood furnace.
sewerzuk is offline   Reply With Quote
Old 03-29-2009, 05:44 PM   #6
chaingang
Senior Member
chaingang's Avatar
I heat our upstairs throughout the winter with a Vermont Casting with a catalytic converter. Really puts out the heat and uses very little wood once the convertor gets hot. It will easily run you out of 1800sqf if you pour the wood to it.
__________________
Chaingang
chaingang is offline   Reply With Quote
Old 04-26-2009, 07:08 PM   #7
skinanbones
Junior Member
While catalytic stove we're great very few companys use them as they can break down easily i.e. burning coloured paper or wood with stain or paint. Also catalytic conveters are expensive. I currently heat my house with a pacific energy stove and it's great. P.E. uses a upper baffle with air injection and are all steel construction. Jotuls are also a realy good stove as well but are cast iron and more of a decorative stove, but still a great heater
skinanbones is offline   Reply With Quote
Old 04-27-2009, 12:08 AM   #8
Bigrhamr
Senior Member
I'm on my second Blaze King which is 20 years old. Somebody liked the first one well enough to steal it out of my house when I was gone for a weekend. This one is a King model, the bigger one and easily gives a 12 hour burn with decent wood. The only downside as was mentioned is that they will load up the chimney a little faster. I've found if you leave the door open and let it rip for 15 minutes a day that's not much of a problem either. When it has a good fire going and the catalyst is active you can't see any smoke out the chimney. They do tell you not to burn any glossy colored paper or treated materials or it will poison the cat. I've never had to replace mine and after 20 years it still does the job.
Bigrhamr is offline   Reply With Quote
Old 05-16-2009, 07:45 PM   #9
Phuckin' Jim
Senior Member
Click on the link below for the mother of all wood stove sites:
http://www.hearth.com/econtent/index...s/viewforum/2/
Type "Blaze King" into the search box and go nuts.
Also remember that having a wood stove in the garage might have an impact on your insurance rates.
Most areas have rules to follow in regards to "bump protection" and minimum height from floor to bottom of fire-door.
It would be best for you to check with your local fire dept., as well as whomever you have your fire insurance with.
Phuckin' Jim is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
