Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 03-14-2006, 07:22 AM   #1
cw_racefan
Senior Member
Default Condensation on Epoxy coated floor?
Built my detached garage last summer/fall, and epoxy coated the floor in the fall. I noticed yesterday that underneath the vehicles, there was condensation on the floor. Right now the garage interior is unfinished, no insulation, no heat, nothing. It was very warm yesterday, and the slab was still very cold. I assume this is just due to the weather and the cold slab? I never noticed it in my attached garage, also unfinished, but the floor in that is bare concrete, so it may just get absorbed by the floor.
Thanks!
Craig
cw_racefan is offline   Reply With Quote
Old 03-14-2006, 07:39 AM   #2
camarojoe
Senior Member
Default
Yep... its simply warm air vs. cold concrete=condensation on floor... my garage was doing the same thing this weekend. I have VCT tile, but it doesn't really matter, even a bare concrete floor can show signs of dampness/condensation. Don't worry, it will be back down to freezing by wednesday and the condensation will go away again until the next warm day.
camarojoe is offline   Reply With Quote
Old 03-14-2006, 02:43 PM   #3
shopking68
Senior Member
shopking68's Avatar
Send a message via Yahoo to shopking68
Default
yup, mine did that too a few times, kinda makes the floor slippery.
__________________
40x70x12 Custom Shop
1966 Caprice
1967 Impala SS (Sold)
1968 Impala (Frame Off Project)
2001 Tahoe LT (Wifes Ride)
1972 Chevy C10
shopking68 is offline   Reply With Quote
Old 03-14-2006, 07:36 PM   #4
imported_banzaitoyota
Senior Member
Default
Did your Floor Application Specialist properly test you floor before that Coating was applied? Sounds like your slab was not properly prepared with underlayment/insulation.
Be prepared for theat wonderfull epoxy to lift in a couple years
__________________
No CARBON FIBER has been used or bought in the creation of MY GARAGE
imported_banzaitoyota is offline   Reply With Quote
Old 03-14-2006, 11:33 PM   #5
Craig Balzer
JagNut
Craig Balzer's Avatar
Default
Here's an easy way to tell cendensation from seepage:
1. Find 2x2 foot area of floor that you will not walk on (maybe 2 or 3 areas for complete test)
2. Clean and dry it
3. Place a plastic garbage bag over the clean, dry area
4. Tape it/them securely to the floor on four sides
5. Wait 7-10 days
6. Remove platic bags
A. If still clean and dry = you have condensation; no problem
B. If mositure is under bag = you have problems and the epxoy will lift eventually
Craig
Craig Balzer is offline   Reply With Quote
Old 03-15-2006, 05:21 AM   #6
jeeperjoe
Monkey Wrench
Default
I've had my floor epoxied for the last 7 yrs. I have the same condition every spring with the warm humid air.
Crank the heat.
jeeperjoe is offline   Reply With Quote
Old 03-15-2006, 07:05 AM   #7
cw_racefan
Senior Member
Default
Nope, definitely condensation on top, not from below, already checked. Just never noticed condensation like that in my other garage. Cranking the heat would be great if I had any! Hopefully will have the $$ to do the insulation/heating/cooling/etc over the summer.
Thanks!
Craig
BTW- I've become addicted to this forum. Tons of great info.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Using a floor leveler over epoxy????? SteveL Flooring 1 12-14-2005 03:26 PM
Any experience with the floor epoxy "epoxy-coat" ringer Flooring 11 08-31-2005 08:38 AM
Actual part number needed for the good epoxy floor paint muddy General Tool Discussion 4 08-21-2005 09:01 AM
Black epoxy floor...any thoughts? bmwpower Flooring 10 07-30-2005 03:38 PM
Garage floor Epoxy tkellytn Flooring 1 07-15-2005 09:19 AM
