Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 04-14-2009, 09:03 AM   #1
bimmer1980
Senior Member
bimmer1980's Avatar
Default Stud Walls--16" on center or 24"?????
Hey guys,
I'm working on designing my own garage. I have sourced a truss package thru a lumber yard that has the trusses at 24" centers. However on the walls, is it advised to use 24" centers or 16" centers? I'm using the 104 5/8" studs with double bottom plates and top plates to get a little over 9' ceilings. The trusses are a 28' attic truss. The way I have it designed right now is that the studs are located directly under each truss. This should give the best load transfer.
Thoughts?
Also, the one wall is longer than 34' so I included a 4' brace wall.
I attached a snapshot of the garage from ProEngineer Wildfire.
bimmer1980 is offline   Reply With Quote
Old 04-14-2009, 09:07 AM   #2
JohnK007
Senior Member
JohnK007's Avatar
Default Re: Stud Walls--16" on center or 24"?????
Go with 16" OC. Total load bearing capacity of the wall will be greater than with 24 OC. Very nice drawing!
JohnK007 is offline   Reply With Quote
Old 04-14-2009, 09:21 AM   #3
38 Special
Senior Member
Go 16", don't scrimp on studs.
38 Special is offline   Reply With Quote
Old 04-14-2009, 09:34 AM   #4
KMR Construction
Senior Member
I would advise against 2' o.c. with a wall over 8'. They tend to get alittle flimsy. Your design looks good.
KMR Construction is offline   Reply With Quote
Old 04-14-2009, 10:07 AM   #5
bimmer1980
Senior Member
bimmer1980's Avatar
thanks for the replys
and just to verify, 2x4's should be ok? I would prefer not to use the 2x6 for all of the walls......
Old 04-14-2009, 10:16 AM   #6
38 Special
Senior Member
I think that would depend on your climate and your insulation requirements, here, in Alabama, 2x4 is all we use.
Old 04-14-2009, 10:29 AM   #7
PAToyota
Senior Member
PAToyota's Avatar
Send a message via AIM to PAToyota
I'd consider 2x6 for the extra insulation it would afford you up here in PA. The 24" spacing will save you on materials, but especially with a garage or shop I'd go 16" because of the extra stability that it will afford you considering that you're likely to be mounting shelving, cabinets, and such to the walls instead of just hanging some pictures like you would in a house.
PAToyota is offline   Reply With Quote
Old 04-14-2009, 10:58 AM   #8
sammerdog
+1 on 16" oc's. When we were building, our finances dictated a number of compromises. To get the house we wanted, we shortened up on the garage. One of those areas was going 24" oc walls under 24" oc trusses. We are only at 8'. Our contractor said if we wanted to go higher, he would encourage the tighter 16" stud spacing on the walls.
Someone else mentioned it also, but finding studs to hang cabinets etc is a little more of a chore with 24" spacing.
sammerdog is offline   Reply With Quote
Old 04-14-2009, 01:03 PM   #9
bimmer1980
Senior Member
bimmer1980's Avatar
good points! I was debating on the 16" on centers and had thought about doing it initially. The cost is really marginal to add a few more 2x4's. Since that wall is over 9 feet, I was thinking I might put blocking in at the 4' height and the 8' height for the 4x8 sheets to run horizontally. I know I've seen some discussions on this before, but I think it will be a benefit. I was thinking that on the inside, it would be nice to run the electrical wire along the 4' horizontal run. and on the 8' horizontal run, I would put a wedge shape 1x4 to provide infinite placement of hanging cabinet. I think they call that a french mounting bracket?
Am I over building for planning on that much blocking?
Old 04-14-2009, 01:09 PM   #10
carcruse
Senior Member
I highly recommend you go with 16" for all of the reasons others have stated. The slight cost increase is more than offset by the plus's.
carcruse is offline   Reply With Quote
Old 04-14-2009, 01:13 PM   #11
Torque1st
Senior Member
Torque1st's Avatar
For cabinet hanging use French cleats mounted on the wall and cabinet backs.
Torque1st is offline   Reply With Quote
Old 04-14-2009, 01:52 PM   #12
nate379
16" for sure, I would go with at least a 2x6 and even would lean toward a 2x8.
nate379 is offline   Reply With Quote
Old 04-14-2009, 05:24 PM   #13
JMURiz
Senior Member
JMURiz's Avatar
I agree with the statement above, I wish I would have used 2x6 boards for extra strength on mine...I ended up spending about the same money as they would have cost to make it as rigid, and lost the benefit of extra space for insulation.
__________________
Nathan
22'x24' detached garage *Outside complete, working on interior*
Various cars and motorcycles to be stored inside.
JMURiz is offline   Reply With Quote
Old 04-14-2009, 06:08 PM   #14
Kevin54
Senior Member
Kevin54's Avatar
Quote:
Ditto on the 16" centers and double ditto for the 2x6 walls. What you spend for studs, you will save in utilities in no time. The extra insulation will definately help with heat and cold.
Kevin54 is offline   Reply With Quote
Old 04-15-2009, 12:31 AM   #15
Shocker
Senior Member
I would go 16" as well. Do you have any kind of building code to reference?
Shocker is offline   Reply With Quote
Old 04-15-2009, 03:16 AM   #16
oldgoat
Senior Member
I know of a couple of guys, one a contractor, that built their house using 2 x 6's. The contractor said that the cost difference between the two was relativel minor, but with the extra insulation it more than made up for it in the long run. With 2 x 6's though you can use 24" centers without a problem. If you go with 2 x 4's I'd go with 16" centers though.
oldgoat is offline   Reply With Quote
Old 04-15-2009, 07:39 AM   #17
jbarila
Junior Member
jbarila's Avatar
What are your local building codes?
Here in Mass 16"oc is required. Granted there is snow loading and wind to account for.
jbarila is offline   Reply With Quote
Old 04-15-2009, 08:52 PM   #18
327-365hp
Why a 104 5/8" stud?
327-365hp is offline   Reply With Quote
Old 02-09-2017, 02:39 PM   #19
StuO63
Junior Member
We are also designing new garage. Drawings are for 24 O.C., but we are most likely going to do 16. Especially after reading this post.
StuO63 is offline   Reply With Quote
Old 02-09-2017, 02:46 PM   #20
Milton Shaw
Senior Member
Go with 16" for the roof also. You will notice a big difference walking on the roof and the amount of sag you get between trusses will show eventually, I have see it on many roofs. The ceiling if you eventually use one will be a lot stronger also. At least go to 5 trusses (19.5) spacing per sheet of plywood as they are stronger than 24" center and just an extra truss or so for a small building.
Milton Shaw is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
