Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 10-20-2016, 05:12 PM   #1
iagsxr
Senior Member
iagsxr's Avatar
Default Circular saw blade for cutting butcher block
Need to trim up a Menards butcher block top for a work bench I'm building. What circular saw blade would work the best?
iagsxr is offline   Reply With Quote
Old 10-20-2016, 05:22 PM   #2
gdocktor3
Senior Member
gdocktor3's Avatar
Location: Seymour, Connecticut - poorest man from the richest state.
Default Re: Circular saw blade for cutting butcher block
If it were me I'd just use a 60 tooth Diablo blade or something similar. I don't think you need anything special to cut it if that's what you're asking.
__________________
I don't make money with tools. I save money with tools.
gdocktor3 is offline   Reply With Quote
Old 10-20-2016, 05:30 PM   #3
iagsxr
Senior Member
iagsxr's Avatar
Quote:
That's what I've came up with so far. 60t blade, cut halfway through first pass so the blade doesn't get hot.
Just looking for advice from anyone who's actually done it or is just more knowledgeable in general than me.
Old 10-20-2016, 06:02 PM   #4
amorrow
Senior Member
amorrow's Avatar
I'm actually in the same boat. A Freud blade is already in my miter saw ready to cut my Menards Mastercraft butcher block top for a bathroom vanity I'm going to make. I likely won't get to it for another week since I have to mock everything up to determine exact size I want, but can post my experience if by chance you haven't cut yours yet.
amorrow is offline   Reply With Quote
Old 10-20-2016, 06:15 PM   #5
Voi
Senior Member
Quote:
Are you doing a rip or a crosscut? Or both?
Is the top solid wood or is it particle board with a veneer?
Will the cut edges be hidden?
The upshot of all these questions is that if it's solid wood and you're only doing a rip cut with the grain then I'd go with a lower tooth count blade. If yes to any of the other questions then I'd probably stick with the higher tooth count blade.
Voi is offline   Reply With Quote
Old 10-22-2016, 08:31 PM   #6
Empty Pockets
Senior Member
Empty Pockets's Avatar
When I ran the foimica shop, whenever we had to cut maple butcher block, we used the highest toioth countr blade we had, in the table saw, one man cutting, very slowly,. We always sprayed the blade down with dry silicon lube before starting.
__________________
Go on raise the flag. Ive got stars in my eyes. Im in love with Her and I wont apologize.
- Jon David
Predictions are always hard, especially about the future.
-Yogi Berra
Empty Pockets is offline   Reply With Quote
Old 10-22-2016, 09:21 PM   #7
Git
Senior Member
^^^^^^ This
Git is offline   Reply With Quote
Old 10-22-2016, 11:08 PM   #8
dumper
Senior Member
Its just a workbench top! Use any sharp blade with a good quality saw. Good grief...
dumper is online now   Reply With Quote
Old 10-22-2016, 11:12 PM   #9
PoorOwner
Senior Member
In my experience maybe it's the glue or something when I use something like a 60t just lots of smoke and the glue muck up the teeth.
Using a 32t cuts much better. I usually finish it with a router 1/4 arbor 2" long.
PoorOwner is offline   Reply With Quote
Old 10-23-2016, 12:04 AM   #10
Toolfool
Senior Member
Toolfool's Avatar
I do crosscuts with a 60T blade in my skilsaw, making passes of 1/3 depth at a time.
Toolfool is offline   Reply With Quote
Old 10-23-2016, 12:31 AM   #11
cgrutt
Senior Member
cgrutt's Avatar
You can always cut 1/16+ of the line and finish with a router. I use Forest blades on my table saw and don't think a butcher block would be a problem though. Band saw is another option, finished with a hand plane...
__________________
www.AvidArms.com
cgrutt is offline   Reply With Quote
Old 10-23-2016, 12:42 AM   #12
turbowoodworker
Senior Member
turbowoodworker's Avatar
^^^This
If you want a really nice face with no tearout, cut near the line then finish with light router cut.
__________________
"I was the Valedictorian of my summer school class"
- Dennis Miller
turbowoodworker is offline   Reply With Quote
Old 10-23-2016, 12:51 AM   #13
flyingblind
Senior Member
flyingblind's Avatar
No one has mentioned taping the cut line to lessen tear out. Good regular masking tape is what I use and remove it pulling toward the cut edge when you remove after the cut.
__________________
I parallel park by feel.
flyingblind is offline   Reply With Quote
Old 10-23-2016, 09:45 AM   #14
cheechi
Senior Member
cheechi's Avatar
I have found 3M painter's tape works very well for tearout also.
I like the 40 & 60 tooth Diablo blades. Haven't used another on my circ saw for years.
__________________
Thank you to every current and former military and public safety person.
Quote:
Originally Posted by countryroad82 View Post
I'm left handed so there are a lot of things that just don't seem right to me
I'm a shopaholic; I like to drink in my shop.
cheechi is offline   Reply With Quote
Old 10-23-2016, 03:33 PM   #15
tarbellb
Senior Member
I cut a bunch of the solid 2" Ikea butcher block they use to sell. Both cross and Rip cuts w/ a sidewinder circular saw.
I found less teeth (40-60) to be the best for single pass full depth cuts +tape and a good sharp blade.
tarbellb is offline   Reply With Quote
Old 10-23-2016, 03:38 PM   #16
Autonomous
Put some painters tape on your cut line on both sides to reduce possible tear-out.
Sent from my XT1254 using Tapatalk
Autonomous is offline   Reply With Quote
Old 10-23-2016, 07:21 PM   #17
FullRaceMerc
Senior Member
FullRaceMerc's Avatar
Another trick for a clean cut is to clamp down a guide on the keeper side of the work, make a very shallow first pass to reduce tearout, add a single thickness of tape to the face of the guide to offset the next cut slightly, then go back & make the final cut through.
__________________
Don't find fault, find a remedy. -Henry Ford
FullRaceMerc is offline   Reply With Quote
Old 10-23-2016, 10:00 PM   #18
tarbellb
Senior Member
Quote:
Thats a cool trick! ^^^
Old 10-23-2016, 11:14 PM   #19
Wamsutta
Senior Member
I could cut that butcher block with a 24 tooth Diablo carbide blade and you'd think it was cut with a 60 tooth...
Wamsutta is offline   Reply With Quote
Old 10-24-2016, 01:34 AM   #20
Sh40674
Senior Member
ditto on making a half cut so you don't burn the wood. use a 60 tooth carbide tip blade, clamp a straight edge to get an accurate cut, cut halfway through, drop your blade depth and do a 2nd pass to finish.
also, use tape like said above on the butcher block where the saw will glide over, will help keep from scratching the surface of the butcher block
Sh40674 is offline   Reply With Quote
Old 10-24-2016, 01:58 AM   #21
lbhsbz
Senior Member
Finer teeth are better, cut from the backside so the blade is pulling away from the "top" rather than pushing it towards the top. Run masking tape around the cut line. Any good framing blade will work fine.
lbhsbz is offline   Reply With Quote
Old 10-24-2016, 04:01 AM   #22
oldldh
Senior Member
oldldh's Avatar
My Dad had some saw blades from Sweden...
16" Diameter...
160 alternate top bevel, carbide teeth...
We used them to cut post formed formica counter tops...
As fast as we could push them through the blade...without chipping the plastic...
You could also cut 6 sheets of 3/4" plywood, at once...
Got about three hundred cuts before resharpening the blade...
My memory isn't what it was, but I remember 5 speeds (7,200 rpm was as fast as it would go!!!), 7 1/2 hp, 440/3ph, 100 amp circuit breaker...
Helluva a saw (Cost $8,995.00 in the late 60's)...
If the OP cut come up with a 60 tooth, 12" blade, and a table saw, with an extension...He should be in business...That'll cut 4+" stock with one pass...
__________________
It's my fantasy...I can make it as big as I want...
Young men have fantasies...Old men have delusions...
I speak three languages fluently---English, Sarcasm, and Profanity...
oldldh is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
