Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 10-28-2016, 11:19 AM   #1
Ryan
Administrator
Ryan's Avatar
Default Compressor Enclosure
I was farting around on the internet the other day and ran into a pretty smart outdoor compressor enclosure that utilizes a smart muffler of sorts.
You can see the details ...
Ryan is offline   Reply With Quote
Old 10-28-2016, 11:25 AM   #2
Farmall450
Senior Member
Farmall450's Avatar
Default Re: Compressor Enclosure
That's a pretty elaborate set up for that baby compressor. Nice though. Hopefully no water ever gets in there and he drains it frequently.
__________________
Why Farm Half When You Can Farmall?
1959 1/4 HP Craftsman Pre-Block Restoration
Prentiss Model 22 Vise Restoration - To Be Continued
Quote:
Originally Posted by countryroad82 View Post
I'm left handed so there are a lot of things that just don't seem right to me
Farmall450 is offline   Reply With Quote
Old 10-28-2016, 11:31 AM   #3
krcoomer
Senior Member
krcoomer's Avatar
Quote:
That is what I was thinking too. Would not work for me for sure with our humidity. I don't think that is a pancake. Seeing how deep he dug it it is probably a vertical 30 gallon or so. Makes more sense about the size and noise he described. I would hate to lift that in and out, especially with about 10 gallons of water in the tank.
__________________
Kenny
If you're "on time", you're late.
krcoomer is offline   Reply With Quote
Old 10-28-2016, 11:37 AM   #4
LS6 Tommy
Senior Member
LS6 Tommy's Avatar
That oiless compressor is doomed to death by overheating. That is if the light switch he's feeding it from doesn't burn the house down first. If he lives in a climate that has winter, the filter dehydrator will burst the bowl the frost time it freezes, too. I also can't believe he spent all that money and time for that little compressor.
Tommy
__________________
The older I get, the faster I was...
LS6 Tommy is offline   Reply With Quote
Old 10-28-2016, 12:20 PM   #5
nh_yota
Senior Member
He forgot to include a fire alarm circuit for when that thing overheats.
nh_yota is offline   Reply With Quote
Old 10-28-2016, 12:27 PM   #6
dodgepolara500
Senior Member
dodgepolara500's Avatar
What about one of these off the shelf cabinets? Anyone have experience with these?
http://www.sears.com/california-air-...B&gclsrc=aw.ds
__________________
_________________________________
1964 Dodge Polara 500 Convertible 383
dodgepolara500 is offline   Reply With Quote
Old 10-28-2016, 12:51 PM   #7
Trey T
Senior Member
Trey T's Avatar
very cool. I want to see a GJ replicate it ... that might be even cooler
Trey T is offline   Reply With Quote
Old 10-28-2016, 02:10 PM   #8
Farmall450
Senior Member
Farmall450's Avatar
Quote:
I think it is like 30 but oilless 30 still isn't much air!
__________________
Old 10-28-2016, 02:25 PM   #9
ZipSnafu
Senior Member
ZipSnafu's Avatar
Quote:
Tommy
Overheating may be a problem, he's in Arizona, Freezing not so much I would think.
ZipSnafu is offline   Reply With Quote
Old 10-28-2016, 02:54 PM   #10
kinigitt
kinigitt's Avatar
Where is the inlet getting it's air from? The pit looks sealed...
kinigitt is offline   Reply With Quote
Old 10-28-2016, 03:05 PM   #11
dave*99
Senior Member
Tommy
Yup, nice coffin for a dead compressor
dave*99 is offline   Reply With Quote
Old 10-28-2016, 03:14 PM   #12
bochnak
Senior Member
For the amount spent on that hole, he could have bought a 2 stage with a low RPM pump that puuuurs.
Here is mine that function as a pegboard:
https://youtu.be/nV7A-rbtXK4?t=9m16s
bochnak is offline   Reply With Quote
Old 10-28-2016, 03:17 PM   #13
bullnerd
Senior Member
bullnerd's Avatar
Pretty neat.
Compressor is under ground
Ground cools the block
Block cools the air
Air cools the compressor
It says in the article its been running that way for 12 yrs, that's pretty good.
bullnerd is offline   Reply With Quote
Old 10-28-2016, 03:21 PM   #14
bullnerd
Senior Member
bullnerd's Avatar
I worked in a shop that had a compressor in an un-ventilated closet! I mean 4 by 4 closet! Took about ten yrs for it to finally have an issue. And it could have more from neglected oil changes than heat.
Did you look at your compressor? On my antique craftsman the main sheave has a fan built into the spokes. I don't think you'll have a problem, plenty of air circulating around it.
Old 10-28-2016, 03:31 PM   #15
Senior Member
theoldwizard1's Avatar
Needs a remote tank drain.
theoldwizard1 is offline   Reply With Quote
Old 10-28-2016, 03:33 PM   #16
bochnak
Senior Member
The top to my enclosure is open. Given my low duty cycle, the thing barely gets warm, so I think I am OK. I could always install an aux fan somehow.
Old 10-28-2016, 04:29 PM   #17
LS6 Tommy
Senior Member
LS6 Tommy's Avatar
Quote:
Well, at least when the receiver lets go, all the energy will be channelled straight up.
Tommy
__________________
Old 10-28-2016, 09:27 PM   #18
ford33
Senior Member
Excellent construction skills but i don't know if I would spend that much money and time on a pancake compressor.
ford33 is offline   Reply With Quote
Old 10-29-2016, 01:57 AM   #19
W0rLDWaR4
Senior Member
Excellent skills as mentioned earlier! I would probably modify his approach slightly though.
W0rLDWaR4 is offline   Reply With Quote
Old 10-29-2016, 10:39 AM   #20
ThrifyGarage
ThrifyGarage's Avatar
Love the concept. As mentioned there is definitely room for improvement. I'd also be concerned with ground water issues with drainage. But overall I think it was a great idea and it hides the size of the compressor well. Looks to be about a 30 gallon compressor.
ThrifyGarage is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
