Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 04-19-2009, 08:50 AM   #1
Tom R
Default Water Filter Filter Replacement..."STUCK"
Hi All...I have a whole house "Omnifilter" filtering the sediment from our well water...we live in the country. I had some plumbing work done and had them put in a new Omnifilter (brand name). This is one of the plastic sediment filters with the drop in cartridge...very common.
The new filter unit is difficult to get the plastic cover loose when you wish to change the drop in filter. Well, now I cannot get it loose at all. It comes with a plastic "wrench" which fits lugs on the unit...but even if I apply enough pressure to risk breaking something it just won't come loose.
Any ideas?
What about appying heat with a hair dryer to the outside of the unit...might that either expand the outer case and/or "break" whatever "seal" is holding?
Any other ideas on getting this loose?
Also, has anyone had this problem and found a way to not repeat each time...maybe vasaeline on the threads? I used the white plastic "seal" tape on my previous unit and it worked fine...maybe that isn't helping on this unit?
Any suggestions will be appreciated...don't want to break it...Tom in Two Harbors, MN
__________________
Tom R
Two Harbors, MN
Tom R is offline   Reply With Quote
Old 04-19-2009, 08:57 AM   #2
TheToolMan
Senior Member
TheToolMan's Avatar
Default Re: Water Filter Filter Replacement..."STUCK"
I am not familiar with the filter but we use food grade grease on stuff all the time. I would but a small tube ($5) to use for next time
TheToolMan is offline   Reply With Quote
Old 04-19-2009, 08:59 AM   #3
GeorgiaHybrid
Senior Member
GeorgiaHybrid's Avatar
Tom,
Try a LITTLE heat on the cap. Too much and it will warp. Once you get it off, use beeswax on the threads after you have cleaned them. The wax will not come off easily and will not harm anyone if a piece does break off. I have also seen guys use candle wax on these also.
You might also try tapping around the perimeter with a small dead blow to break it loose. Just don't get crazy and break it....
GeorgiaHybrid is offline   Reply With Quote
Old 04-19-2009, 09:03 AM   #4
Tom R
Quote:
Originally Posted by GeorgiaHybrid View Post
Tom,
You been talking to my wife??? You know the "just a little more will do it"! Tom R in Two Harbors, MN
__________________
Tom R
Two Harbors, MN
Old 04-19-2009, 09:03 AM   #5
robin1731
Senior Member
robin1731's Avatar
Send a message via Yahoo to robin1731
Make sure when you reinstall the housing to only hand tighten it too. I have the same set-up in my house. It is kind of like an oil filter on a car. Hand tighten and you will still need the wrench to loosen it. I use a a little plumbers grease on the threads too.
robin1731 is online now   Reply With Quote
Old 04-19-2009, 09:20 AM   #6
dxdexter
Senior Member
dxdexter's Avatar
I hate to state the obvious, but make sure you have shut off the supply line and depressurized the lines or depress the pressure relief button on top of the filter otherwise you will never move the housing.
As stated earlier; upon reinstalling use some plumbers grease on the o-ring and threads. Don't use Vaseline as its petroleum based.
__________________
Dex
I'm not young enough to know everything
dxdexter is offline   Reply With Quote
Old 04-19-2009, 09:21 AM   #7
GeorgiaHybrid
Senior Member
Tom,
Nah, I haven't been talking to yours, I have one all to myself that I have to listen to..... I think they all come pre-programmed to offer that response... It ranks right up there with "Are you sure you know what you are doing" or "Don't you have enough tools? What is THIS one for?"
Old 04-19-2009, 09:35 AM   #8
Tom R
Relatively gentle hammer assist on the plastic wrench did the trick...did not get to the heating stage. Thanks all.
Plumbers grease (along with careful hand tightening) seems like the easiest answer?? I assume most heardware stores would have "plumbers grease"? That isn't the grey stuff is it???
Thanks...Tom R
__________________
Tom R
Two Harbors, MN
Old 04-19-2009, 10:46 AM   #9
Bustawrench
Senior Member
Bustawrench's Avatar
Quote:
Thanks...Tom R
This is what you want............
http://www.herchem.com/specs/plumbers_grease.pdf
You can get it at Home Depot, Ace, True-Value, etc...........Just smear a light coat on the threads and o-ring and don't go all gorilla monsoon when you tighten it back up, the o-ring does the sealing.
__________________
It is what it is.
Bustawrench is offline   Reply With Quote
Old 04-19-2009, 11:26 AM   #10
IDASHO
Senior Member
I have a similar unit, with similar problems.
If you are doing it right, then you are lubing the O-ring with vaseline, go one step furter and lightly coat the threads of the filter housing with vaseline too.
It helps. Tremendously!
As for the stuck filter you have now, get the proper wrench. It will come off, if not by hand, with the help of a rubber mallet tapping on the end of the wrench.
__________________
See my garage build here:
http://www.bonnefinstudios.com/kwb/paradise/garage/
IDASHO is offline   Reply With Quote
Old 04-19-2009, 11:41 AM   #11
Tom R
Thanks All...got it loose by tapping on the wrench with a mallet...will add plumbers grease to threads and o-ring...and NOT "just tighten ONE more time! " Appreciate the help. Tom R in Two Harbors, MN...currently light snow!
__________________
Tom R
Two Harbors, MN
Old 04-19-2009, 11:49 AM   #12
DHS
Senior Member
DHS's Avatar
I too have been using vaseline for the last 5 years and have never had a problem with it. I also coat threads like IDASHO. Here in Florida it is currently in the 80s here.
__________________
Quote:
Originally Posted by expatriated View Post
Ethanol sucks. And I'm tired of all this whining over the environment. If they made one, I'd buy a car that ran on baby seals.
DHS is offline   Reply With Quote
Old 04-19-2009, 11:53 AM   #13
dxdexter
Senior Member
dxdexter's Avatar
Quote:
Vaseline, being a petroleum based product, has the potential to break down some types of rubber seals. Perhaps not the ones in your system. I am unsure of whether it can contribute to water toxicity or not, but I'm not taking any chances for the sake of a few bucks.
__________________
Dex
Old 04-19-2009, 11:58 AM   #14
IDASHO
Senior Member
Quote:
Vaseline is recommended for use by the manufacturer of these filter systems.
__________________
Old 04-19-2009, 01:20 PM   #15
dxdexter
Senior Member
dxdexter's Avatar
Quote:
I stand corrected if this is true for the Omnifilter, but others should be wary since not all manufacturers are the same. My Envirogard filter specifically specifies a silicone based food grade grease. Obviously the manufacturers recommendations should rule.
__________________
Dex
Old 04-19-2009, 03:22 PM   #16
IDASHO
Senior Member
AHA! Hold on there. I was wrong.
I just rechecked the user guide that comes with the filters (I use OmniFilter T01-SS)
*Lubricate O-ring with clean silicone grease. Reassemble housing and hand tighten.
Ive always used vaseline though... and Im still alive
__________________
Old 04-19-2009, 08:45 PM   #17
nate379
I just use Silglide on mine. I use it for all O rings. Napa sells it, about $5 for a tube.
nate379 is offline   Reply With Quote
Old 04-20-2009, 02:12 PM   #18
jumpyg
Junior Member
My filter housing is also very hard to remove. The plastic wrench that came with it slipped and deformed so it's useless. My 12" tongue-and-groove pliers are a little small. I was thinking of getting some 16" Channellocks that only cost about $22 at Lowes. Hopefully they would be big enough.
jumpyg is offline   Reply With Quote
Old 04-20-2009, 03:11 PM   #19
nissan_crawler
Senior Member
nissan_crawler's Avatar
I just use crisco on mine.
__________________
If guns cause crime, all mine are defective. Ted Nugent
"A man with a gun is a citizen. A man without a gun is a subject. " John Lott
"Taking my gun away because I might shoot someone is like cutting my tongue out because I might yell `Fire!' in a crowded theater." Peter Venetoklis
nissan_crawler is offline   Reply With Quote
Old 04-20-2009, 03:41 PM   #20
Jerm
Jerm's Avatar
I have the same filter and they are a pain to remove if there is any pressure on the system. I use http://cgi.ebay.com/ws/eBayISAPI.dll...&category=1267 on my housing, works well and is safe.
__________________
No Habla Jibbidy Jabber
Jerm is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
