Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 03-22-2006, 09:59 PM   #1
bob944
bob944
bob944's Avatar
Default Base trim ideas?
Anybody have any good CHEAP ideas for putting some kind of base moulding around my garage? On half my garage there is drywall that goes all the way down to the concrete floor, and on the other half there is a 12" concrete wall and then drywall above that. The floor is epoxy coated, and I'll be painting the walls soon, but I need something to clean up the lower area. I'd like something that will keep the jack, etc. from banging holes in the drywall and still give a uniform look around the garage.
I'm thinking maybe just 2x6 or 2x12 pressure treated perhaps with a round-over edge routed for looks, and then painted a contrasting color to the walls. Diamond plate would be nice, but is definitely off the budget scale. ABS plastic sheet might work well, but I'm guessing that gets pricey too. I probably need 60-80 l.f. roughly.
Ideas? Thanks.
Andy
bob944 is offline   Reply With Quote
Old 03-23-2006, 05:17 AM   #2
snorvet
Senior Member
snorvet's Avatar
Default
I would go with the treated if its going to get bumped quite a bit. you may have to wait a while to paint it. it seems that new treated lumber takes a while to dry out. After it dries out i'd primer first before paint. You could probably go with 1x6, or prerouted deck boards that would be cheaper than the 2x6 or 2x12
I'm thinking of putting up two strips of treated 1x6 on my walls to hang my wheelbarrow and garden trailer on to avoid dings in the drywall
snorvet is offline   Reply With Quote
Old 03-23-2006, 06:14 AM   #3
6t7gto
Senior Member
6t7gto's Avatar
Default
I used RFP (reinforced fiberglas panel) to trim off the bottom of mine.
david
6t7gto is offline   Reply With Quote
Old 03-23-2006, 06:16 AM   #4
bob944
bob944
bob944's Avatar
Default
I thought about 1x material, but then I started thinking that it might have a higher tendency to warp. I think it would look better with the thinner lumber, but I would have to buy descent grade boards that wouldn't cup terribly. Your post actually got me to thinking about synthetic decking boards as an option. They would definitely be more expensive, but they would not warp, and I could get a nice grey color that would complement the scheme without any need to paint. My plan is to silicone whatever I use to the epoxy floor so that I can hose the place out without worry of water getting behind the base and soaking into the drywall.
Andy
Old 03-23-2006, 06:17 AM   #5
bob944
bob944
bob944's Avatar
Default
David....how did you finish the edge of the FRP....or did you? I thought of those panels I've seen at HoPo, but I wondered about the various options for finishing the top edge.
Old 03-23-2006, 02:19 PM   #6
harnett
Junior Member
Default base
If you like the look standard industrial rubber base is available in 4" and 6" heights and is very cheap. For a little more money Johnsonite makes a thicker rubber base that looks like wood base, metal, or hundreds of color choice. All very inexpensive. Waterproof and ding and dent proof.
harnett is offline   Reply With Quote
Old 03-23-2006, 02:52 PM   #7
6t7gto
Senior Member
6t7gto's Avatar
Default
Bob,
i bought the trim pieces that are used with the RFP.
david
Old 03-23-2006, 10:09 PM   #8
rockwithjason
Union Wireman
rockwithjason's Avatar
Default
what about 1 inch plate steel? :P
rockwithjason is offline   Reply With Quote
Old 03-24-2006, 05:37 PM   #9
Bill K
Senior Member
Default
Hardie board cement board siding comes in 12 ft lengths
Bill K is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Floor Drain Ideas TonyMazz General Garage Discussion 23 06-23-2006 05:48 AM
meter base to panel brokenjack General Garage Discussion 14 03-31-2006 10:55 AM
Plumbing air compressor ideas w/pictures fatboy General Garage Discussion 4 03-24-2006 10:00 PM
My new garage, need ideas now MyMopar General Garage Discussion 14 11-11-2005 09:27 AM
Help with (humble) and dusty base. Jonno General Garage Discussion 2 08-03-2005 08:27 AM
