Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 05-15-2009, 03:55 PM   #1
Rigmaster
Senior Member
Rigmaster's Avatar
Default Stahlwille mystery tools....
I picked up a couple of mystery tools today. They are Stahlwille, marked 12617 with a "10" below the part number, and another marked 12617 with an "8" below that.
I first thought they were spark plug sockets, so I almost threw them aside. They look exactly like a normal spark plug socket, but inside the tool where you would insert the spark plug there are 3 rollers. There is a plate in the end with a hole in it, and the plate is held in with a snap ring.
I did a google search, but got nothing.
To me these look like some sort of stud remover, the 8 + 10 indicating that they are used for 8 or 10mm studs.
Pics to follow when I get home, for now just use your imagination (well, everyone except Krusty that is........)....
Rigmaster is offline   Reply With Quote
Old 05-15-2009, 03:58 PM   #2
daveblank
Senior Member
daveblank's Avatar
Default Re: Stahlwille mystery tools....
You are describing a stud remover/installer
__________________
"The anguish of low quality lingers long after the sweetness of low cost is forgotten." - Unknown, from Peter Gregory, CISSP
daveblank is offline   Reply With Quote
Old 05-15-2009, 04:00 PM   #3
Rigmaster
Senior Member
Rigmaster's Avatar
Quote:
Thanks Dave.
Kind of what I was thinking, but I could not find anything with a search.
As with most of the Stahlwille tools I've seen, these are NICE..
Old 05-15-2009, 04:01 PM   #4
kwyjibo
kwyjibo's Avatar
+1
if you search for the facom (or many other companies) version you'll probably see exactly what's in your hand
kwyjibo is offline   Reply With Quote
Old 05-15-2009, 04:04 PM   #5
Rigmaster
Senior Member
Rigmaster's Avatar
Quote:
Originally Posted by kwyjibo View Post
+1
Thanks kwyjibo.
I just found this on Amazon (searched for Facom Stud remover):
That's almost exactly what mine look like.
Here's the link to the Amazon listing for those who might be interested:
http://www.amazon.com/Facom-76014-Ex.../dp/B0002SRH7E
Old 05-15-2009, 10:00 PM   #6
Rigmaster
Senior Member
Rigmaster's Avatar
Pics as promised.
Old 05-16-2009, 03:23 PM   #7
bchee
Senior Member
bchee's Avatar
I was just wondering about these in the other thread. If these are used for both removal and installation, then how do the rollers inside move, or how do you make them switch directions?
bchee is offline   Reply With Quote
Old 05-16-2009, 03:49 PM   #8
krusty the clown
Senior Member
krusty the clown's Avatar
Quote:
they work similar to a one way clutch in an automatic trans, except of course they lock in both directions.
__________________
DEGENERATE Main Entry: 1de·gen·er·ate
Pronunciation: \di-ˈjen-rət, -ˈje-nə-, dē-\
Date: 15th century
1 a : having declined or become less specialized (as in nature, character, structure, or function) from an ancestral or former state b : having sunk to a condition below that which is normal to a type; especially : having sunk to a lower and usually corrupt and vicious state c : degraded 2
krusty the clown is offline   Reply With Quote
Old 03-22-2012, 08:44 PM   #9
dimwittedmoose51
I just found a set of 3 of these in a pawn shop in Missouri with their metal box and all. AMine have an "A" behind the part number and have "5/16", "1/4", and "3/8" under the mumber. One appears to have the rods missing internally and one may be missing just one. The other is intact. ANyone taken these things apart and can they be repaired??
Thanks
DM&FS
dimwittedmoose51 is offline   Reply With Quote
Old 03-22-2012, 08:47 PM   #10
garfunkle24
Senior Member
garfunkle24's Avatar
Send a message via MSN to garfunkle24
Quote:
Thanks
Takes yours apart and then let me know, will you?
FYI if you haven't used them yet: They work great on smooth studs but will crush the threads on anything threaded. I just use two nuts in that case.
__________________
g24
garfunkle24 is offline   Reply With Quote
Old 03-22-2012, 09:10 PM   #11
ruquik
Simple sprag design, double cam, double spring I'm guessing .
ruquik is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
