Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 05-16-2009, 01:20 AM   #1
zthomas
Junior Member
Default matco tool box key
i recently bought a matco toolbox off of a craigsist ad. it looks to be a 6 series just by comparing it to images on the matco website. the identification label has worn off. the guy i bought it from said that he had lost the key a while back but never had it replaced. what the best option for me to get some keys made, call a locksmith or call matco. my shop does not currently have a matco dealer. the box is in excellent shape, few minor scratches, its a double bay box. i got it for $1800 and a 6 month old 1/2"drive snap on tech wrench for $100. just need keys for it now.
zthomas is offline   Reply With Quote
Old 05-16-2009, 02:20 AM   #2
slimshady_2469
Senior Member
Default Re: matco tool box key
call a locksmith in your area with the number on the face of the lock or post it here and i can probably give you any key information you need.
slimshady_2469 is offline   Reply With Quote
Old 05-16-2009, 03:05 AM   #3
fatboy99
Senior Member
Matco uses a flat key with the end drilled at different depth's the lock shop's in my area couldnt make me copies .your best option is to go to matco online and get a new lock set with key's
Brad
fatboy99 is offline   Reply With Quote
Old 05-16-2009, 08:10 AM   #4
daveblank
Senior Member
daveblank's Avatar
You will need a new lock set.
__________________
"The anguish of low quality lingers long after the sweetness of low cost is forgotten." - Unknown, from Peter Gregory, CISSP
daveblank is offline   Reply With Quote
Old 05-16-2009, 10:26 AM   #5
slimshady_2469
Senior Member
ok nevermind, if it has the dimple type keys then i wont be able to help, sorry. if you have a locksmith in your area that works with "DOM" locks they mightbe able to help you but im not positive on that. call matco and they will for sure be able to solve your problem but if you can find a locksmith it may be cheaper
Old 05-16-2009, 10:53 AM   #6
zthomas
Junior Member
i pulled one lock cylinder out and the only information i could find on it was that it was a TuBAR cylinder, it had a patent pending number, and GDX stamped on the inside which i'm guessing is the key code.i checked matcos website and couldnt find anything about getting keys or lock cylinders, will i have to contact a matco dealer for these?
Old 05-16-2009, 12:14 PM   #7
daveblank
Senior Member
daveblank's Avatar
New lock with keys will cost roughly the same a shaving 2 keys made.
__________________
Old 05-16-2009, 12:52 PM   #8
zthomas
Junior Member
would a lock cylnder from the local hardware store or or is it going to have to come straight from matco
Old 05-16-2009, 02:42 PM   #9
daveblank
Senior Member
daveblank's Avatar
If you can find one with the same dimentions & mounting post on the rear, then yes, it will work.
__________________
Old 05-16-2009, 05:24 PM   #10
zthomas
Junior Member
thanks for all of your help guys. i'm gonna check the hardware stores first, if no luck there i'll call matco or chase down the rep in the next county.
Old 05-17-2009, 11:42 PM   #11
Expensive Date
Junior Member
Expensive Date's Avatar
PM me I probably have some locks with 2 keys on my truck for that box.
Tim
Expensive Date is offline   Reply With Quote
Old 05-18-2009, 09:09 PM   #12
zthomas
Junior Member
i sent you a message expensive date
Old 05-18-2009, 09:21 PM   #13
Vulturej
Senior Member
Vulturej's Avatar
You can get replacements locks here.
http://www.compxnet.com/products-chavendtubar.html
Vulturej is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
