Go Back   The Garage Journal Board > The Garage > Free Parking
Reply
Thread Tools Display Modes
Old 07-01-2009, 12:24 PM   #1
OldCarGuy
Senior Member
OldCarGuy's Avatar
Default Adding a Rolling Library Ladder to storage shelving..
I built 32 running feet of 16” deep shelves 13' high for storage on one wall of my 30' by 50' motorhome garage. Getting tired of getting out a step ladder ever time I need something off the upper shelves. I finally finish a rolling ladder. Since I first built the shelving I have been scavenging around for the components to add to some OldCarGuy's gold (junk) that I have accumulated over the years for this build. And literally didn't have any out of pocket expense. My biggest find was a 14' section of discarded aluminum extension ladder. It was a wee bit bent; but didn't take too much to straighten it.
I started out with a piece of 3” diameter Nylon that was about 14” long to make four the top running rollers out of. That will run on some old 1 1/ 2” EMT conduit I had laying around.
I chucked the Nylon rod in my lathe. And used a live center on the far end for stability. I set my Monarch radius turning attachment that I purchased off Ebay a while back to fit the outside diameter of the conduit,, 7/8” radius. No need for this gadget today with CNC lathes. But it was the best way to turn a radius in my day!
With a cutoff tool, I cut 1/8" wide grooves and about 1" deep. Then turned the Nylon stock around and machined the last radius making the fourth roller.
Next I drill a 19/32” hole through the center. Leaving 1/32” for reaming to size
Then reamed the hole .005 over 5/8” diameter. Clearance for a 5/8” shoulder bolt, commonly called a stripper bolt. I'm sure that Kevin54 would know what they are.
Shoulder bolt. 5/8” diameter by 3” long body with a 1/2” -13 thread on one end and a large head on the other.
Reaming operation, taking it slow not to build up heat.
Finished cutting off the wheels. Three saw-cuts and I have four separate rollers.
Then faced off the two end to make the radius on center and making the overall length 2.938”.
Four finished Nylon rollers with shoulder bolts.
From some old angle iron I made a bracket to hold the rollers. Drilling and tapping holes for mounting the wheels. And two mounting holes to attach it to the top of the ladder. A lock nut was added to the shoulder bolt as a safety from it unscrewing..
This is how the rollers will ride on the top rail.
The top rail was made from 10 foot lengths of 1 1/2” EMT conduit that I had stashed away for years. I made a setup in my mill to drill 3/8” diameter mounting holes 24” centers, starting and ending 12” from each end. I held the conduit in the machine vice. And rested the conduit on two parallel made of 1x2x3 blocks set on top of 2x4x6 blocks. After the first 3/8” hole was drilled 12” from the end. I installed a 3/8” bolt in one of the parallels that was exactly 24” from the spindle. Drilled that hole and moved to the right. Until I had five mounting holes aligned and precisely positioned.
Cut an old piece of 4” by 4” angle iron into twenty 1 1/2” widths for top rail support bracket. For the repetitive saw cuts, I clamped a piece of steel for a stop. The saw came with a swing away stop attachment. But it gets in the way more often than not. And it's more bother to put it on than just clamping a metal stop.
Drill mounting holes in brackets in Bridgeport.
Power tapping 3/8-16 NC holes for screws that mount top rail. Beats doing it by hand.
From an old section of 3/8” black pipe, I cut 20 spacers for top rail support
Assembly view. A 3/8”-16NC by 5” long hex bolt through a cut off section of 1 1/2” EMT conduit. With spacer between angle bracket and conduit.
I bolted two old stationary caster wheels to the bottom of the ladder..
Bolted the top rail to the shelving. Installed ladder section on the top rail. And we're in business...
__________________
Read About:
My "Class Act" Car Hauler's===> Structural Failure
OldCarGuy's New Toy Shop Complex
OldCarGuy is offline   Reply With Quote
Old 07-01-2009, 12:34 PM   #2
Art From De Leon
Senior Member
Art From De Leon's Avatar
Default Re: Adding a Rolling Library Ladder to storage shelving..
From OCG "My biggest find was a 14' section of discarded aluminum extension ladder. It was a wee bit bent; but didn't take too much to straighten it."
Was it made by the same company that made the ramp for your car hauler?
Art From De Leon is offline   Reply With Quote
Old 07-01-2009, 12:39 PM   #3
Tantara
Senior Member
Tantara's Avatar
Very cool
Brad
Tantara is offline   Reply With Quote
Old 07-01-2009, 12:58 PM   #4
sammerdog
Senior Member
sammerdog's Avatar
You do very good work Sir!
Very very inspiring to see you sharing your skills and abilities!
sammerdog is offline   Reply With Quote
Old 07-01-2009, 07:13 PM   #5
R1chy
Senior Member
R1chy's Avatar
Really nice and thanks for posting the steps used to make it. I just need to figure out a way to talk you into making me a set of those rollers....
R1chy
R1chy is offline   Reply With Quote
Old 07-02-2009, 04:02 AM   #6
Brad54
Senior Member
Brad54's Avatar
That's slick as hell!
-Brad
__________________
There is no such thing as a stupid question.
But there sure are a lot of stupid people asking questions.
Parting out Reed and Columbia vises
http://garagejournal.com/forum/showthread.php?t=139072
Brad54 is offline   Reply With Quote
Old 07-02-2009, 07:38 AM   #7
chrislehr
Senior Member
chrislehr's Avatar
Send a message via AIM to chrislehr Send a message via MSN to chrislehr
Very slick - does it feel safe and sturdy though?
chrislehr is offline   Reply With Quote
Old 07-02-2009, 07:58 AM   #8
porschedude996TT
Senior Member
porschedude996TT's Avatar
First I have to say "Well Done", second you have more stuff than the law allows!
porschedude996TT is offline   Reply With Quote
Old 07-02-2009, 09:44 AM   #9
OldCarGuy
Senior Member
OldCarGuy's Avatar
Now that remark surely gave me a laugh!
Quote:
R1chy
We can talk about arranging something..
Quote:
I find it to be more than sturdy. Having soft wheels on the ground. The ladder doesn't roll and stays put with my weight. Though I have to pick things up one-handed and hold onto the ladder with the other...
Quote:
That's what 50 years of uncontrolled collecting will do for you! But I didn't know that I was breaking any kind of law though.
__________________
Read About:
Old 07-02-2009, 10:17 AM   #10
Art From De Leon
Senior Member
Congratulations on being able to put your dreams into reality. (NOT meant to be sarcastic).
I collected about 10 pieces of old farm machinery, because the small machines from the 1950's not only represented what I grew up around, but because the small machines were usually the first to be scrapped, buried in a ditch, or shoved up into a pile, as equipment got bigger, and more modern.
It turned out that the hunt became more enjoyable that the thought of actually restoring them.
The companies making some of these have been out of business for 40 years or so, parts are obviously NLA, even from John Deere, because they are long obsolete, and the machines I brought home have the correct mounting brackets and attachments that were specific to that model to allow it to be mounted on the tractor that I have.
Now that I am having to sell my house, the scrapper is coming next week, and there will be even fewer of what were hard to find when I went looking.
I built, and equipped a shop to do this, and am having to face the fact that there was absolutely NO point in doing what I did.
Old 07-02-2009, 10:30 AM   #11
nadogail
Senior Member
Beautiful Rolling Ladder, and the collection of materials and equipment that went into making it. I too would be more of a collector if i had space to keep it. Great posting.
Just because I can not tell you today what I will eventually use it for, does not diminish the value of the item (other guys junk).
nadogail is offline   Reply With Quote
Old 07-02-2009, 01:38 PM   #12
Jaguar Fan
Senior Member
Jaguar Fan's Avatar
Location: Park City for Ski Season; Las Vegas for Poker Season
Super job!
__________________
"A woman drove me to drink & I never had the decency to thank her." -- W.C. Fields
Marriage is like a phone call in the middle of the night. It starts with a ring -- and eventually you wake up.
Jaguar Fan is offline   Reply With Quote
Old 07-02-2009, 04:04 PM   #13
Ramblur
Senior Member
My what a timely thread. Currently putting up my wall-o-shelves with the
stuff I drug home from the Crane Cams auction. Just so happens I also
have some nylon laying around too,where should I send it?
Ramblur is offline   Reply With Quote
Old 08-08-2009, 09:25 AM   #14
JOHNMAN
Senior Member
Quote:
R1chy
I too would like to talk to you about making me a set of the rollers as well. That is my missing link for my ladder.
Thanks for the inspiration.
John
JOHNMAN is offline   Reply With Quote
Old 08-08-2009, 11:47 AM   #15
ghnl
Senior Member
ghnl's Avatar
Very nice.
How about mounting the bottom casters on spring loaded brackets? If you size the springs right they'd support the weight of the ladder until you step on, then ladder's feet would bear on the floor.
__________________
Eric
Mebane, NC
'61 MGA, '84 Alfa Romeo Spider
'81 Alfa Romeo GTV-6, '91 Honda ST1100,
'99 F250 diesel, '06 Toyota Solara
My home page
ghnl is offline   Reply With Quote
Old 08-08-2009, 06:32 PM   #16
rsanter
Senior Member
rsanter's Avatar
OCG
you have good ideas and the tallent to pull it off
love to see your posts
bob
__________________
my wife says that I have never met a tool I havent liked. people on the other hand......
rsanter is offline   Reply With Quote
Old 08-08-2009, 09:19 PM   #17
OldCarGuy
Senior Member
OldCarGuy's Avatar
Quote:
Originally Posted by ghnl View Post
Very nice.
I chose not to spring load the ladder wheel for two reasons. First it involved a lot more work installing the wheels. And I would also have to make the top rollers slide. Rather than stationary. The ladder works just fine the way I put it together...
John
Send me a PM and we’ll see what we can work out.
__________________
Read About:
Old 08-08-2009, 10:49 PM   #18
e-tek
Senior Member
e-tek's Avatar
Another beauty. I wondered how you were going to get at all those empty Tupperware containers!!!
The best part for us non-machinist types is to see how and what some of those tools are for. I've asked before, but have you considered trying to sell some of your content (writing, videos, how-to) to anyone? There are so many online sites begging for content: Popular Mechanics-types, DIY-types, etc.... Food for thought, especially since you like doing it and as you said in your post in the Retirement Dream thread, we could all use a little top up!!
__________________
VISIT me at www.E-TekRestorations.com
OR, read the blog: www.E-TekRestorations.blogspot.com
Quote:
We have to recognize that paying more for quality products made in countries that support the quality of life we want for ourselves and our children, is critical to protecting our own quality of life.
e-tek is offline   Reply With Quote
Old 08-09-2009, 03:06 PM   #19
kbs2244
Senior Member
I am definitely jealous.
But it seems like a case of using thousands of dollars worth of equipment to make tens of dollars worth of parts.
Library ladders are pretty common on the DIY sites.
But if I was in your shoes, I would do the same thing.
kbs2244 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
