Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 07-01-2009, 01:20 PM   #1
rinny_tin_tin
Senior Member
Default Garage Apron w/ACO Zipper Drain System
Tomorrow we pour about three trucks. Just finished tying up all the steel
Will upload the *AFTER* after
File Type: jpg Apron_Drain_Before_House Looking to Street.jpg (152.4 KB, 178 views)
File Type: jpg Apron_Drain_Before_Street Looking to House.jpg (149.9 KB, 170 views)
__________________
rinny_tin_tin is offline   Reply With Quote
Old 07-02-2009, 11:58 AM   #2
fotoflojoe
Senior Member
Default Re: Garage Apron w/ACO Zipper Drain System
We installed an apron drain three years ago when we had the driveway repaved. It's been really nice to have, but you you'll need to keep an eye on clogging. Depending on the type of grill that you use, it can get fouled pretty easily. The grills on our drain have 1/4" x 3" slots, all kinds of crap gets into the trough and ends up covering the drain hole. I usually have to clean it out every three months or so.
I'm thinking about backing the grills with some screen, in hopes that will keep out all but fine sand/silt.
fotoflojoe is offline   Reply With Quote
Old 07-02-2009, 12:08 PM   #3
Bevis
Senior Member
Bevis's Avatar
where is it draining to? To me it looks like both ends are capped.
Bevis is offline   Reply With Quote
Old 07-02-2009, 02:12 PM   #4
rinny_tin_tin
Senior Member
Quote:
End box in one pic is deep catch basin embedded in concrete. A 4 inch corrugated ABS Plastic drain pipe is connected and takes it down hill for discharge. They poured today: 2 1/2 trucks 3500 psi 4-inch slump. Looks great. Tomorrow I pull off forms, install grates and will upload pics.
__________________
Old 07-02-2009, 02:14 PM   #5
rinny_tin_tin
Senior Member
I'm using ADA compliant cast iron grates. I don't have a leaf problem given
that I hacked down every nearby tree.
__________________
Old 07-02-2009, 03:46 PM   #6
JMURiz
Senior Member
JMURiz's Avatar
7 car garage! Where in NoVa is this?
__________________
Nathan
22'x24' detached garage *Outside complete, working on interior*
Various cars and motorcycles to be stored inside.
JMURiz is offline   Reply With Quote
Old 07-03-2009, 09:35 AM   #7
rinny_tin_tin
Senior Member
Quote:
The other three bays in the existing home will be closed off to make additional living space..so...its only an attached 4 car garage.
__________________
Old 07-03-2009, 10:21 AM   #8
Art From De Leon
Senior Member
Art From De Leon's Avatar
I like your style, trees have their place, but not where the leaves and branches can get on your house.
Art From De Leon is offline   Reply With Quote
Old 07-03-2009, 11:44 AM   #9
rinny_tin_tin
Senior Member
Quote:
Thanks. I love trees and with over 5 acres of treed property of 100 year old + red and white oak, Hickory, Beech, Ironwood, Poplar, Maple and Dogwoods, I don't feel bad at all about knocking down the trees close to the house. However, I do practice good silverculture and try and promote strong growth of our hinterland trees. The environment here is very healthy as evidenced by the diverse colorful bird population comprised of not only the conventional mid-east expected species (Chickadee, Tufted Titmouse, House Wren, Cardinal, Oriole, but tons of buntings, woodpeckers (pileated, eastern, etc) finches, etc etc. We do not use any pesticides and try and provide the habitats that allow the aforementioned, and others, to thrive.
__________________
Old 07-03-2009, 11:46 AM   #10
rinny_tin_tin
Senior Member
Poured yesterday. All went smoothly.
__________________
Old 07-04-2009, 02:29 AM   #11
Bevis
Senior Member
Bevis's Avatar
Ok, gotcha now...
Old 07-04-2009, 06:14 AM   #12
larry4406
Senior Member
Corrugated pipe tends to clog due to build up in the corrugations. The builder I worked for always used smooth pipe and fittings for day-light drains for downspouts, surface catch drains, etc.
larry4406 is offline   Reply With Quote
Old 07-04-2009, 08:33 AM   #13
rinny_tin_tin
Senior Member
Quote:
I was concerned of that too, and I'm not a big fan of corrugated plastic pipe - however, the catch basin has a deep sump with the discharge elevated about 8 inches off the bottom, so sediment/sludge collects on the bottom and permits periodic cleaning - while the catch basin also has a basket to collect larger debris. In this case, the corrugated pipe was the best decision - particularly in light of the flexibility need to bring down hill. But -- as you, I prefer PVC pipe whenever possible. Besides...too late now
Another item - if you look closely you will see white 3-inch PVC pipe risers peeking through the cement. These pipes are intended for the gutter system and is ALL PVC pipe to discharge into a 10,000 gal poured cement rain collection tank to be situated behind garage.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
