Go Back   The Garage Journal Board > The Garage > Flooring
Reply
Thread Tools Display Modes
Old 07-03-2009, 07:34 AM   #1
Spaggs
Default 4000 psi concrete - different floor prep?
I'm building a garage with a workshop in it and Mohawk recommends 4000 psi concrete for the lift. Is the prep any different? And, do I tell the concrete guy not to lay any sealer on the top?
Thanks ahead of time.
Spaggs
Spaggs is offline   Reply With Quote
Old 07-03-2009, 10:05 AM   #2
AlphaGarage
Senior Member
AlphaGarage's Avatar
Default Re: 4000 psi concrete - different floor prep?
If you plan on an epoxy coating , then you want to spec a light broom finish and no sealer.
Prep for our epoxy or epoxy/urethane system would be the same as for any other new concrete floor.
__________________
Contact AlphaGarage.com for DIY Wolverine Coatings floor epoxies.
Do It Yourself Professional Results.
Fred@AlphaGarage.com 877-333-GARAGE (4272)
<br><br>
AlphaGarage is offline   Reply With Quote
Old 07-03-2009, 11:02 AM   #3
FlameOut
Senior Member
Wow, I didn't know you needed a light broom finish if you plan on epoxy. I'm glad you mentioned that as I'm getting ready to do my floor and was going to go with a smooth trowel finish
FlameOut is offline   Reply With Quote
Old 07-05-2009, 11:40 PM   #4
WolverineCoatings
Senior Member
WolverineCoatings's Avatar
Quote:
This is somewhat of a preference depending on how you intend to prep the floor for coating. Either way the floor will need to be prepped prior to coatings. The theory is that a broom finish (as opposed to a smooth troweled floor) gives more surface area for bonding after acid etching. If you are grinding then a smooth troweled floor might be better. If you are shot blasting then it probably doesn't matter either way.
__________________
www.WolverineCoatings.com
Wolverine Coatings Corporation's products are sold exclusively through AlphaGarage.com for Residential or DIY applications. Please contact Bert@AlphaGarage.com for your DIY project.
WolverineCoatings is offline   Reply With Quote
Old 07-17-2009, 10:36 PM   #5
FlameOut
Senior Member
Just finished pouring concrete today. Went with a trowel finish. Now I just need to decide on what type of finish to go with. I guess I should wait at least a month before doing any epoxy? I have about 900 sf
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
