Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 07-15-2009, 06:58 AM   #1
onecheck
Senior Member
Default Impact Gun Lubrication?
I am buying a 1/2" Ingersoll Rand impact gun today either new or used. How do you lubricate it and what oil do you use? What do you think about this device?
In-Line Automatic 1/4" NPT Air Tool Oiler
http://www.tooltopia.com/index.asp?P...OD&ProdID=4954
onecheck is offline   Reply With Quote
Old 07-15-2009, 07:19 AM   #2
nate379
Default Re: Impact Gun Lubrication?
Couple drops in the air inlet ever once in a while.
nate379 is offline   Reply With Quote
Old 07-15-2009, 07:23 AM   #3
onecheck
Senior Member
Quote:
What type of lub. My first air gun I dont know
Old 07-15-2009, 07:42 AM   #4
alex71
Senior Member
alex71's Avatar
just about any kind of oil works. motor oil, three in one oil, anything is better than nothing. I have a bottle of marvel mystery air tool oil that I've been using for a few years. seems to work as well as anything, but certainly not a necessity.
__________________
ASMC Industrial / WWW.ASMC.NET / 888-660-0334
Fastener distributor featuring USA made Grade 9, 8, 5, Bolts/Nuts/Washers
F
ree shipping on all website orders.
PM me for a coupon code!
alex71 is offline   Reply With Quote
Old 07-15-2009, 07:51 AM   #5
daveblank
Senior Member
daveblank's Avatar
PB Blaster Air Tool Conditioner works great.
__________________
"The anguish of low quality lingers long after the sweetness of low cost is forgotten." - Unknown, from Peter Gregory, CISSP
daveblank is offline   Reply With Quote
Old 07-15-2009, 09:00 AM   #6
benjamming
Senior Member
Renewable Lube Air Tool Oil This quart will last forever. Typically you can get 10% off if your employer has an account with them & sometimes no tax that way too.
I have that oiler from Tru-Flo. It works fine for me so far.
benjamming is offline   Reply With Quote
Old 07-15-2009, 09:10 AM   #7
GTO
Senior Member
GTO's Avatar
HF has CRC lube IIRC it's around $2 for a jug.It comes in the clear plastic container.
GTO is offline   Reply With Quote
Old 07-15-2009, 09:21 AM   #8
billymade
Senior Member
billymade's Avatar
I got this the other day from a local tool store; it has a special type of flip up dispenser that works perfect for the air tool inlet. This size should last a long time!
Militon TOOL OIL Part # 1001-16 16 OZ Extends life and performance of air tools, lubricators, valves and cylinders. Prevents seizure of air tools and pneumatic equipment. Recommended for tools requiring a 10 weight non-detergent lubricant.
http://www.ecrater.com/product.php?pid=2641482
If you have a local NAPA; they sell theirs as well...
Napa Air tool oil; Part # BK 7651400
Product Features:Keeps Tools Running Smoothly
Use w/ Air Tools
Cylinders & Lubrication
http://www.napaonline.com/MasterPage...+Oil&VehCode=N
__________________
"I can't stop buying those $1 Snap-On 1/2 wrenches!" Don't Worry Its OK, your NOT alone; tool addicts of the world UNITE!
Being able to reach into your rollaway and finding the right tool for any given situation/repair; is the ultimate power trip!
billymade is offline   Reply With Quote
Old 07-15-2009, 10:01 AM   #9
scottmlew
Senior Member
I used to do a drop or 2 before I started work, but I got this oiler back in January at the recommendation of some guys on here. I'm very happy with it. I keep it on a short (I think 12") lead hose so that it's close enough to the tool so that the oil is still suspended in the airstream by the time it gets to the tool, but I still have a flexible hose coming off of the tool.
scottmlew is offline   Reply With Quote
Old 07-15-2009, 10:10 AM   #10
ImportTuner
Moderator
ImportTuner's Avatar
Marvel air tool oil has worked really well for me ..
ImportTuner is offline   Reply With Quote
Old 07-15-2009, 11:31 AM   #11
benjamming
Senior Member
Quote:
Why not just screw it directly into the impact (fitting actually & then impact) & then start the flex hose?
Old 07-15-2009, 01:54 PM   #12
scottmlew
Senior Member
Quote:
Two reasons:
1. This lets me use it for multiple tools very easily.
2. I find the extra length it adds to the tool, especially being rigid, to be quite the nuisance. Sometimes, those few inches of clearance are critical, especially on an air ratchet. Admittedly it's not as much of an issue on an impact wrench, but I have run into situations where it's still an inconvenience. For example, when working on a lower lugnut, the "higher" the wrench is overall, including any fittings, oilers, etc., the more of an angle need to hold the wrench at to get it to clear the ground.
Old 07-15-2009, 02:28 PM   #13
48548
Senior Member
48548's Avatar
Quote:
Worked well for me also on my da sanders and other air tools.
__________________
WTB: Plomb Pebble, 4766 breaker bar.
48548 is offline   Reply With Quote
Old 07-15-2009, 09:11 PM   #14
msrfrog
msrfrog's Avatar
trans fluid. cheap or free. I have used it for like 10 yrs and still going strong.
msrfrog is offline   Reply With Quote
Old 07-15-2009, 10:30 PM   #15
Snappy
Senior Member
Snappy's Avatar
Post Re: Impact Gun Lubrication?
I started using Schrader-Bridgeport / Amflo air tool oil. ( #1220-1 ). It comes in a 16 oz flip squirt bottle.
....For piston & rotary type air tools. Claims to dissolve gums and sludges that rob tools of speed and power. Directions : Squirt a few drops in air inlet before start of day & several times a day for frequent and prolonged use.
__________________
"We're all here,cause were not all there..."
Seller feedback:
http://garagejournal.com/forum/showthread.php?t=121849
Snappy is offline   Reply With Quote
Old 07-15-2009, 10:33 PM   #16
kartracer55
Senior Member
kartracer55's Avatar
husky/cambell hausfeld oil is my favorite.
Why? Convenient bottle that doesn't make a big mess! Its like 2$, the bottle lasts forever. The Husky bottle is black, the CH bottle is white.
__________________
Add yourself to the official Garage Junkies map!
http://www.frappr.com/garagejunkies
kartracer55 is offline   Reply With Quote
Old 07-15-2009, 11:34 PM   #17
spazzer
Senior Member
Quote:
Been using this in my IR-2131 for 10+ years. Still going strong!
spazzer is offline   Reply With Quote
Old 07-16-2009, 04:23 AM   #18
holden26
Morey's heavy duty oil stabilizer. Its like honey and it doesn't go away
holden26 is offline   Reply With Quote
Old 07-16-2009, 06:56 AM   #19
Marlin
Senior Member
I would not recommend anything with the consistency of honey being put into an air tool. Most air tool oil is a light oil like #10. Thicker oils can cause vane to stick. Best practice if you do not have an auto oiler is to put a couple drops of oil in the inlet of the tools and run for a second at the end of each day.
Marlin is offline   Reply With Quote
Old 07-16-2009, 06:57 AM   #20
ozzy214
Senior Member
Once every 6 months I run a lil brake clean through my guns to clean the crap out of it. Then 6 drops of the universal syntec trans fluid we use at work about 3x a week. Works fine for me and my top of the line $350 snap on air rachet I bought in 2001 is still going strong and will rip your fingers off or smash ya hands if you aint careful....
ozzy214 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
