Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 07-18-2009, 08:10 PM   #1
TimbrSS
Junior Member
Default Help wiring in new TIG welder
Hey guys, just picked up a used Lincoln Squarewave 255. I need to figure out how to get it powered up.
I have 200 amp service going to a box in my basement, and need to run power 40ft thru a crawl space to get to my garage.
Instruction manual calls for a 100 amp breaker, then says use 4 AWG copper wire with 8AWG ground. The welder has a 10' cord with 3 4awg wires coming out of it, no plug.
First question is can I use 2AWG aluminium wire, as it's less than half the cost of copper? Does the wire need to be in conduit?
Second question is what kind of recepticle/box should I put in the garage? I figured I'd just hardwire the welder into some sort of box. I wouldn't mind adding a 50a 220v outlet for a MIG while I'm at it, if it's convienient. I don't know, but it may be better to put in a subpanel at this time?
Any advice is appreciated.
TimbrSS is offline   Reply With Quote
Old 07-18-2009, 08:40 PM   #2
35mastr
Senior Member
35mastr's Avatar
Default Re: Help wiring in new TIG welder
I would use the copper regardless of cost. The aluminum is just not as good IMO. Alot of homes around here have been rewired due to poor aluminum wire.Conduit will be your choice. I personally dont use it in areas not to be seen. Just nail to the wood.
You could hardwire it.But I would not. If you need to move it or weld outdoors you are going to be SOL. I woulld get a weldor plug and add it to the weldor and put a couple outlets in the shop for it also.Any advice is appreciated.
Lots of people have there way of doing things. I just prefer do do it right the first time despite any costs involved. last thing you want is a fire.
Make sure you get at least 2 good fire bottles too. For those unsuspected fires that will happen.
__________________
If I could only remember what I have already forgotton.
Mac tools For Sale Here
George
35mastr is offline   Reply With Quote
Old 07-18-2009, 09:15 PM   #3
rodm1
Senior Member
More then likely you will be just fine with a 50amp breaker. I have a Precision Tig 275 on a 50amp breaker threw a 60amp service and rarely pop the service and only when stick welding never with Tig.
If you go over 60amp hardwire is the only real option or spend several hundred dollars on plugs.
rodm1 is offline   Reply With Quote
Old 07-18-2009, 09:20 PM   #4
LoneGunman
Senior Member
LoneGunman's Avatar
I prefer copper BUT if I was buying the wire ( I am an electrician so I rarely have to buy my own stuff) I'd buy the aluminum. Aluminum has a bad rap, every power company I have dealt with runs aluminum to your meter, as long as the aluminum is tightened properly and properly prepared (no ox, deox ) you will have no problems. I would never run my whole house with al but a feed for a welder or a subpanel, you betcha. Being that you are only feeding a welder or a subpanel it is nothing to check the connections yearly for heat or corrosion.
LoneGunman is offline   Reply With Quote
Old 07-18-2009, 09:34 PM   #5
LoneGunman
Senior Member
LoneGunman's Avatar
"More then likely you will be just fine with a 50amp breaker. I have a Precision Tig 275 on a 50amp breaker threw a 60amp service and rarely pop the service and only when stick welding never with Tig."
When a breaker trips it's life expectancy is shortened, if it happens enough it will trip before an overload condition, so you reset it again, it trips , you reset again ETC ETC. Usually it's not a problem but it's not unheard of for the breaker to get to a point where it stops tripping and remains closed in an overload condition. The best case scenario is you burn up some wire or your equipment, you can imagine what the worst case scenario is.
This is not theory, this is fact that I have witnessed first hand more than once.
Old 07-19-2009, 01:27 AM   #6
TimbrSS
Junior Member
I'm thinking about just running copper to a 100A subpanel, hard wire the welder to the panel, and add a 50A breaker with a nearby outlet (for other 220 machines) while I'm at it. I always live by the theory that the most expensive way upfront (within reason), will be cheaper in the long run.
If I put in a sub panel, what wire size, and how many wires should I run?
Also, this is an attatched garage, and the walls are finished, so I would like to install this as neatly as possible. If anyone has pics of how they installed there subpanel, etc, it'd be very helpful.
With a 10' power cord and a 25' lead on the torch, I can touch all 4 corners of my 2 car garage. The welder weigh 300lbs, and won't roll too well on my gravel driveway, so I doub't I'll do much welding outside, out of my 25' reach anyways. Hard wiring will also make a good excuse when someone asks if they can borrow it.
Thanks for all the info, you guys are great.
Old 07-19-2009, 10:12 AM   #7
Blown71X
Senior Member
Quote:
While I am doing something similar, Just be careful the 255 can draw 93 amps in unbalanced AC...even at moderate output (>100 Amp) in DC will tax a 50 Amp outlet, I also have a PT 255
I knew this going into it and am very watchful of the connection and ran a short run (under 3 feet) in conduit just for this reason,Trust me it DOES get warm.
Yep a disconnect capable of the required current is in excess of 400 dollars by the time it is all said and done, plus you are stuck to that dedicated location, I plan on it because what little aluminum I do just pushes my "comfort zone" on a 50 amp outlet.
This dude is probably too much for home use but It sure is nice not having to go to other peoples shops every time I needed a TIG
Rick
__________________
I started with nothing and have 99% of it left
Blown71X is offline   Reply With Quote
Old 07-30-2009, 11:45 AM   #8
TimbrSS
Junior Member
Just an update. Went with 2-2-2 Al wire. Working on putting in a 12 breaker flush mount sub panel. I am going to wire the welder into a seperate box, to make it easy to remove if I ever need to. Also Doing a 50A outlet while I'm at it. I got almost everthing done except making the terminations. If all goes well, I'll be melting something this weeking. Thanks for all the advice.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
