Go Back   The Garage Journal Board > The Garage > Lighting & Electrical
Reply
Thread Tools Display Modes
Old 08-04-2009, 04:20 PM   #1
Stucazz63
Junior Member
Stucazz63's Avatar
Default Fluorescent light fixtures troffer to surface mount
Can 4 bulb 4' T8 troffer style fluorescent fixtures (the ones that are used in drop ceilings) be used as surface mounted? I was thinking of installing them and then dressing them up with wood around the edges to give them a more finished look. I can get these for a good deal but am not sure this idea will work. Any suggestions would be appreciated.
Stucazz63 is offline   Reply With Quote
Old 08-04-2009, 04:46 PM   #2
Tscott
Senior Member
Tscott's Avatar
Default Re: Fluorescent light fixtures troffer to surface mount
Don't see why not? You may have to drill a few holes in the back for mounting, but there is no reason why they should not function as normal.
Tom
Tscott is offline   Reply With Quote
Old 08-05-2009, 12:57 PM   #3
kbs2244
Senior Member
They will work.
Keep them spaced at least 1/2 inch from the drywall to provide some cooling space.
They expect a lot of space above them to release their ballast heat into.
kbs2244 is offline   Reply With Quote
Old 08-05-2009, 04:16 PM   #4
Docklobster
Junior Member
I recessed 4 of them into my garage ceiling, built a frame that they rest on, the frame screws into the cross joists, works great no issues over the last few years.
Docklobster is offline   Reply With Quote
Old 12-28-2009, 10:55 PM   #5
fuchster
Junior Member
i just installed four of them on my garage. I made a box or frame while I was doing the frame work. I attached them by screwing the inner lip to the wood frame. I will install trim around the edges for a cleaner finished.
fuchster is offline   Reply With Quote
Old 01-01-2010, 06:51 AM   #6
HIRISC
Senior Member
HIRISC's Avatar
Troffer's work fine like you've described.
We framed out 2xT8 fixtures on 16" center joists, but your 4 bulbers will work the same.
If you buy the ones from HD, make sure you measure the troffer's little lip just above the trim frame. Will save you some time (cough, cough) with a roto tool during install.
HIRISC is offline   Reply With Quote
Old 01-01-2010, 04:20 PM   #7
tfi racing
Senior Member
tfi racing's Avatar
Yep,if they are a great deal-go ahead and surface mount them and trim them out as you are planning.If they are used,double check the ballasts and make sure they are 120V!
tfi racing is offline   Reply With Quote
Old 10-08-2010, 06:07 PM   #8
vfdfs2
Junior Member
Great JOB. That look so nice. Thanks for sharing, now i also can go ahead and install recessed troffers in my basement. At first i could not think how i was going to mount those drywall-mount troffer, but now i know.
vfdfs2 is offline   Reply With Quote
Old 02-02-2014, 04:35 PM   #9
tmlanz
Junior Member
Quote:
Nice job, were your joists spaced wide enough? 24" centers seem to close for standard troffers.
tmlanz is offline   Reply With Quote
Old 02-02-2014, 04:39 PM   #10
CoopVA
Senior Member
CoopVA's Avatar
That looks great HIRISC!
__________________
My Garage Build Thread
1980 Scout II - Diesel SD33T (In Progress)
1984 HD FXSB Shovelhead (Needs a bottom end)
1979 HD XLCH Ironhead (Needs a carb)
2005 HD FXDI Fathead (Needs to be ridden more)
2003 Cheby Silverado 4x2 (Trash Truck)
2013 Subaru Legacy (107,000 miles on it already)
CoopVA is online now   Reply With Quote
Old 02-02-2014, 05:10 PM   #11
jmiller_2308
Senior Member
I'd check the manufactures information before attaching them directly to the ceiling. Many troffers require a certain amount of clearance around them for cooling so you want to make sure these are rated for direct contact before you mount them that way.
Jeff
jmiller_2308 is offline   Reply With Quote
Old 02-02-2014, 05:12 PM   #12
CoopVA
Senior Member
CoopVA's Avatar
Quote:
Jeff
Good point.
__________________
Old 02-02-2014, 05:31 PM   #13
JoeFin
Senior Member
JoeFin's Avatar
Jeff
What your looking for is the IC rating - which most troffers have
JoeFin is offline   Reply With Quote
Old 02-02-2014, 05:33 PM   #14
Norcal
Senior Member
It can be argued that they cannot be used for anything other then in a suspended ceiling grid or a frame intended for the purpose, as that is what they were listed as. That being said, there has been a lot of them used "improperly" without incident. I personally think they look goofy surface mounted but there are a lot of them being pulled & disposed of in remodels, & can be bought cheaply compared to other fixtures, I understand.
Norcal is offline   Reply With Quote
Old 02-10-2014, 11:14 AM   #15
HIRISC
Senior Member
HIRISC's Avatar
Quote:
Thanks
Jeff
No joist insulation in my install, but it's a valid point.
AFAI remember, our particular Troffer was/is IC rated (see Q&A)
http://www.homedepot.com/p/Lithonia-...specifications
Old 02-11-2014, 12:49 AM   #16
Aquamoose
Senior Member
Aquamoose's Avatar
Done it in my shop on ceiling mounted OSB's. I put 4 holes in the corner of each 3-lamp fixture (still a 2x4), used lag screws to temporarily mount them up, then followed through by replacing them with 1/4 - 20 bolts and fender washers on top & bottom. I wired them up in banks of two on 20a switches (20a circuit on 12g wiring, total max of 14 lights on each)
After all, it's a shop. Quick, easy, and provided a lot of lighting.
Aquamoose is offline   Reply With Quote
Old 03-26-2016, 03:46 AM   #17
NewShockerGuy
Senior Member
NewShockerGuy's Avatar
Arrow Re: Fluorescent light fixtures troffer to surface mount
Old thread, but I believe I am headed this way... I would MUCH prefer the look of this over ones that you attach to the surface of the ceiling. The flush mount looks sooo much cleaner!
Any update from a few years later on how they are holding up?
Thanks,
-Nigel
__________________
________
-....-> ~ NSG ~ <-....-
NewShockerGuy is offline   Reply With Quote
Old 03-26-2016, 10:22 AM   #18
ctfjr
Senior Member
ctfjr's Avatar
Quote:
That's exactly what I did. My company was converting to T8 fixtures & were throwing out a load of 4 bulbers. I took about 15 of them for my garage in the basement. It has no finished ceiling. I used wire to all four corners to hang them snug to the joists.
ctfjr is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
