Go Back   The Garage Journal Board > The Tools > Fabrication & Techniques
Reply
Thread Tools Display Modes
Old 08-13-2009, 12:43 AM   #1
ossaguy
Senior Member
Default How to fix distortion after welding steel???
I cut 4 sections of 2 inch angle steel,and welded them in the shape of a picture frame,to make a shelf for a grinder.After I gas welded the corners,it's warped so it doesn't sit flat.I wish I had a picture,but I don't.It's still square,but it's not sitting flat.Any tips on how to correct it?
Thanks for any help,
Steve
ossaguy is offline   Reply With Quote
Old 08-13-2009, 11:28 AM   #2
MXtras
Senior Member
MXtras's Avatar
Default Re: How to fix distortion after welding steel???
Block the low corners up off a firm table and use clamps to pull down the high spots. Over-bending will likely be necessary to compensate for spring.
I straighten Aluminum weldments almost daily using this method.
Scott
__________________
Haul your MX bike without straps - visit www.mxtras.com to see how
Custom Storage Cabinets with FREE plans - http://www.garagejournal.com/forum/s...ead.php?t=1773
Link to workstation plans for download (FREE) - http://reference.toolandfab.com/writ...nets/index.htm
MXtras is offline   Reply With Quote
Old 08-13-2009, 02:14 PM   #3
bimmer1980
Senior Member
bimmer1980's Avatar
Do what Scott is say, but you might also have to apply a bit of heat to allow the steel to "normalize". As the steel is heated, it expands and then it contracts as it cools off. That is what caused your distortion. It usually helps to tack it all together and then weld a little bit on each corner. Some times you have to weld on the opposite side of the current weld to help it straighten out.
Stainless steel is even more prone to warpage!!! don't ask how I know......
bimmer1980 is offline   Reply With Quote
Old 08-13-2009, 02:23 PM   #4
MXtras
Senior Member
MXtras's Avatar
Stainless can be an absolute nightmare to straighten. It makes even aluminum look easy!
Scott
__________________
Old 08-17-2009, 02:20 AM   #5
55dude
that is the truth. i work with stainless and "its purdy but stubborn!"
55dude is offline   Reply With Quote
Old 08-17-2009, 02:35 AM   #6
rsanter
Senior Member
rsanter's Avatar
if you have a torch you can reheat the areas to 'relax' the stress out of the metal
bob
__________________
my wife says that I have never met a tool I havent liked. people on the other hand......
rsanter is offline   Reply With Quote
Old 08-23-2009, 07:28 AM   #7
Vinko
Senior Member
Quote:
+1 for this method. You've got to get it straight from the beginning.
Vinko is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
