Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 08-20-2009, 09:14 PM   #1
evil16v
Senior Member
evil16v's Avatar
Default Show me Your NICE small tubing benders
Trying to bend up a rear brake line for my chevy tonight... typical 1/4 inch stuff. I don't like the results of my my first attempt... and really i can'tdo much better with my Junk ass plastic MATCO tubing bender. I want one with a roller follower that doesn't egg the tubing.
What do you guys have? pictures? brands? I am going to order one ASAP.
__________________
Rob
'70 Buick GS 455
Stage1
evil16v is offline   Reply With Quote
Old 08-20-2009, 10:05 PM   #2
bgott
Senior Member
Default Re: Show me Your NICE small tubing benders
http://www.matcotools.com/Catalog/to...&page=5&#65707
I want to get a set of these, they look like they would be really handy.
bgott is offline   Reply With Quote
Old 08-20-2009, 10:19 PM   #3
nate379
Senior Member
I have one like this:
http://www.amazon.com/gp/product/B00...WZB5E30KFX7T8A
And a little one like that, but it does 1/8-1/4"
Sometimes I just hand bend them as well. Use a piece of pipe, tubing, etc to avoid kinking it.
nate379 is offline   Reply With Quote
Old 08-20-2009, 10:24 PM   #4
JOHNMAN
Senior Member
These are pricey, but they work amazingly well.
Rigid 404 tubing bender for 1/4" OD tubing
JOHNMAN is offline   Reply With Quote
Old 08-20-2009, 11:04 PM   #5
wantedabiggergarage
Senior Member
http://www.youtube.com/watch?v=TMKWgkApkts
I bought these, and the brake tubing pliers from Eastwood via Ebay, then found the Imperial bender at Sears. It is similar to the Ridgid above, but I don't know if the Ridgids handle is adjustible, and several people recommended the Imperial.
__________________
Tools DON'T make the mechanic, they make the mechanics job, EASIER!
wantedabiggergarage is offline   Reply With Quote
Old 08-20-2009, 11:26 PM   #6
akdiesel
Senior Member
akdiesel's Avatar
That Eastwood is nice alot like the Swagelok benders in that it has the roller wheels to help reduce the friction and somtimes damage to the pipe that the standard benders can create.
I have the Rigid benders from the 1/4" to 3/4". They work fine but for a nicer and easier bend I am going to upgrade to the Swagelok.
akdiesel is offline   Reply With Quote
Old 08-20-2009, 11:39 PM   #7
Stick Figure
Senior Member
Stick Figure's Avatar
Quote:
Originally Posted by bgott View Post
http://www.matcotools.com/Catalog/to...page=5𐂫
I've been wanting one as well, most likely i'll spend the $2 or whatever for the one that pretty much identical at harbor freight though.
Stick Figure is offline   Reply With Quote
Old 08-21-2009, 12:35 AM   #8
A_Pmech
Senior Member
A_Pmech's Avatar
I like Parker 2829S style hand benders.
If you really want a nice bender, buy a Parker Exactol.
Very nice.
VERY expensive.
A_Pmech is offline   Reply With Quote
Old 08-21-2009, 10:57 AM   #9
fatrhino
Senior Member
fatrhino's Avatar
I have one of these - http://www.sjdiscounttools.com/kd2517.html
It does not work well so I am also in the market for a better one. I have used it for transmission cooler and brake lines. It is difficult to use and it deforms the shape of the tube
fatrhino is offline   Reply With Quote
Old 08-21-2009, 03:55 PM   #10
volvo
Senior Member
Best and easiest deal , use the bendable by hand lines.
volvo is offline   Reply With Quote
Old 08-21-2009, 09:38 PM   #11
Spencer Was Here
no he wasn't
Imperial Triple-Head Tube Bender with Roto-Lok™ Indexing Handle
I've had excellent results with these, and you can pick them up at your local Sears store.
Spencer Was Here is offline   Reply With Quote
Old 08-21-2009, 09:51 PM   #12
e-tek
Senior Member
e-tek's Avatar
Any of these that aen't plastic would be better than what you're using. I've found the best way is to do it on the bench, use the bender to get it 'close', then tweak it by hand to match the one replaced.
I haven't tried the super-bendy stuff yet, but if it didn't need to be ridgid, it sounds easy enough. Of course I can see quite a few applications that need some ridgitity.
__________________
Gentlemen, please!
Check out my Web-page: http://edanneberg.googlepages.com/home
e-tek is offline   Reply With Quote
Old 08-21-2009, 09:59 PM   #13
70ss
http://www.garagejournal.com/forum/s...light=swagelok
This is what I used.
70ss is offline   Reply With Quote
Old 08-22-2009, 01:17 AM   #14
Markgyver
There is a pretty cool bender that I have seen at the Goodguys and NSRA shows. It does some pretty nice tight bends. I dont have there name with me right now maybe someone else does. There name is like Metal Tech and they are out of TX. Its like a Hosfeld bender just a smaller scale.
Markgyver is offline   Reply With Quote
Old 08-22-2009, 08:39 AM   #15
jsaw
Senior Member
I have a pair similar to these, they are quick & easy. They make tighter bends than any others I own
jsaw is offline   Reply With Quote
Old 08-22-2009, 01:26 PM   #16
Markgyver
I found the name its the Mighty Mite Bender.
http://www.metalbendingtool.com/
Old 08-22-2009, 10:29 PM   #17
evil16v
Senior Member
evil16v's Avatar
Thanks for all the replies! I have a few to look at now. I am seeing this and the flare tools as something that I would not use on a regular basis, but when you need it... you need it. I rented a double flare tool from oriellies.... It didn't work well. it did the job though... took a couple tries to get the flare straight and not off set. This was a KD from O'reilly's. I wouldn't buy one. the hole for the 1/4" was not perpendicluar to the tool. How hard is it to get that right?
I went ahead with my project and got it done better with some coated tubing from NAPA. It worked way better with my shitty little Matco bender.
then came the next problem... I found another portion that need replaced. so basically I had to pull the gas tank and am in the process of removing the line up to the factory splice on the fram under the master cylinder.
while I have the gas tank down.... I'm doing a fuel pump too while I was on GM Parts direct for the fuel pump...I ordered new trim for the tailgate handle, clips for the latch rods,new hose set for the A/C, new blinker stock.... this all started with a low pedal
__________________
Rob
'70 Buick GS 455
Stage1
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
