Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 08-29-2009, 09:33 PM   #1
rwhite692
Senior Member
rwhite692's Avatar
Default My New Compressor Project
I figured I would post a couple of photos of my latest "side project" which is keeping me distracted from other projects that I SHOULD be working on...you all probably know how that goes...
Anyway, In my new shop I plan to have an abrasive blast cabinet, and I know that my existing compressor (Which is a Craftsman Pro "6.5 HP" Oil-less 60 gallon upright) would not be able to keep up with the demand. It puts out around 10 CFM @90 PSI. It has been performing well, but I have never gotten used to the really loud and annoying racket it makes.
I remembered that at our plant (semiconductor fab) we have a back room filled to the rafters with all kinds of plant equipment. I got to talking with our facilities manager, and he remembered that they had a compressor pump with not much time on it which had been removed from service when one of the wafer fab areas was shut down. (That's a nice way of saying, wafer fabrication was outsourced, to China).
He scrounged around for a while, and came up with this:
It's a Curtis D96A, Two-Stage, 190 pounds of American-made, cast-iron goodness.
According to Curtis literature, it puts out 18.2 CFM at 175 PSI when run at a nice, slow 755 RPM, with a (True) 5HP motor. It has a centrifugal unloader, and is pressure-lubricated, as well.
I parked a beer in the pics for scale
A call to a friend of a friend, then netted me a really nice 120 gallon vertical tank, for $100:
The tank is a compressor tank, has cert plate, etc, but never has been used for that purpose; It's never had a pump mounted on it. It was used as a storage/surge tank.
I already have a near-new Dayton 5HP 1725 RPM 220V single phase motor that I will use to drive it. I need to find a mag starter, I'm not too keen on the full 32 Amp draw being switched by the pressure switch alone.
I will have to fabricate a belt guard for it...I have some expanded metal screening around...somewhere...
All I have done to the pump thusfar is to give it a bath with some gunk engine cleaner. I will definately change the oil.
I will post some more pics here as things move along and I start putting it all together! -Rob
Oh and my wife asked me, "So, what color are you going to paint this thing when it's all done?"
Any ideas?
__________________
My 24x36 detached garage project:
http://www.garagejournal.com/forum/s...ad.php?t=16310
rwhite692 is offline   Reply With Quote
Old 08-29-2009, 09:50 PM   #2
A_Pmech
A_Pmech's Avatar
Default Re: My New Compressor Project
Looks like the makings of a very nice compressor. Should last your lifetime, at least.
I'm kinda partial to gray. Though, several people are setting trends with brightly colored Monarch 10EE's, so maybe bright neon green?
A_Pmech is offline   Reply With Quote
Old 08-29-2009, 10:19 PM   #3
wrigh003
Senior Member
wrigh003's Avatar
Send a message via MSN to wrigh003
That will be a hoss when you get it done.
wrigh003 is offline   Reply With Quote
Old 08-29-2009, 10:27 PM   #4
Mr_fixit
Senior Member
Mr_fixit's Avatar
I'm working on a Frankenpressor myself. 7.5 hp eaton pump, Baldor 5hp motor. Mounted on a scrap yard dental compressor tank. I've got most of my parts that I couldn't find used on e-bay. I got a square d starter & check valve from these guys....
http://stores.shop.ebay.com/Universa...4?_nkw=starter
My old one won't keep up to the sandblast cabinet and snow making ..
A true 5 hp motor wouldn't draw 32 amps, more like high 20's...
Mr_fixit is offline   Reply With Quote
Old 08-29-2009, 11:47 PM   #5
rwhite692
Senior Member
rwhite692's Avatar
Quote:
Originally Posted by Mr_fixit View Post
.....A true 5 hp motor wouldn't draw 32 amps, more like high 20's...
You are correct, dyslexia on my part, motor plate says 23 peak, not 32.
__________________
Old 08-30-2009, 11:03 AM   #6
79firebird
Senior Member
Nice score. Should give you plenty of air if you need more could allways plumb both compressors to each other
79firebird is offline   Reply With Quote
Old 08-30-2009, 03:12 PM   #7
hypnotoad
Senior Member
hypnotoad's Avatar
Looks like a fun project.
__________________
Uh Huh, and?
hypnotoad is offline   Reply With Quote
Old 08-30-2009, 03:38 PM   #8
krooser
Senior Member
krooser's Avatar
Great start to a very nice set-up.
This post shows you that you don't need to go to a big box store and whip out the plastic to get what you need. You just need to be inventive and patient and you can get more for less... IMHO.
Keep us posted...
krooser is offline   Reply With Quote
Old 08-30-2009, 09:09 PM   #9
rwhite692
Senior Member
rwhite692's Avatar
Mr.Fixit thanks for the link to the ebay guy with the mag starters. If I can't scrounge one up, I will probably get one from him, pricing looks good.
Krooser I just checked out the link to the Symco shakedown in your sig, great photos!
__________________
Old 09-28-2009, 09:45 PM   #10
rwhite692
Senior Member
rwhite692's Avatar
I have the compressor mostly together now, I was able to scrounge a perforated metal door panel for $10...originally used on a piece of network server rack mount equipment..I just cut it in half and with some angle stock I had laying around made a belt guard out of it:
__________________
Old 09-28-2009, 09:53 PM   #11
rwhite692
Senior Member
rwhite692's Avatar
The rest of the stuff cleaned up pretty good. I gave the tank a quick once-over with the orbital sander and a quick coat of red to match my lift.
__________________
Old 09-28-2009, 09:54 PM   #12
307WYLD
Damn...that looks good.
Quote:
307WYLD is offline   Reply With Quote
Old 09-28-2009, 09:58 PM   #13
rwhite692
Senior Member
rwhite692's Avatar
I bolted a set of heavy duty casters onto the feet on the base, eventually when the garage is done maybe I will bolt it down...Actually maybe not...it loafs along at 750RPM and it certainly doesn't move when it's running. The motor was a $50 Craigslist find and seems to be in real good shape.
__________________
Old 09-28-2009, 10:03 PM   #14
307WYLD
Where did you get those casters? I haven't ever found any with that large of a stem, or that wide of a wheel....
Old 09-28-2009, 10:05 PM   #15
rwhite692
Senior Member
rwhite692's Avatar
Next I have to buy / install a mag starter and install the pressure switch, then she will be all done...The only things I have bought new for it so far are some spray paint, compressor oil, air filter element, a pair of v-belts, a few nuts and bolts, and the Parker 3/4" ID hose to connect it to up my black pipe air lines. I had a local hose shop make it up for me since they have the machine that "bands" the ends.
__________________
Old 09-28-2009, 10:08 PM   #16
rwhite692
Senior Member
rwhite692's Avatar
And here is a link to a short video of it running...Obviously this is just a test run, with the tank open...still have to install the pressure switch, mag starter, and safety pop-off valve.
DSCF2340.AVI
__________________
Old 09-28-2009, 10:14 PM   #17
rwhite692
Senior Member
rwhite692's Avatar
307, I actually stole those casters from a car body dolly I have (made by Autotwirler)...I am planning to just give them a call and order up another four of them when I get around to it...they are very nice people. Also, you can just barely see it in the pic but they have thumbscrews on the side so that they can be "locked".
__________________
Old 09-28-2009, 10:20 PM   #18
tatra
Senior Member
tatra's Avatar
nice...........and quiet........
tatra is offline   Reply With Quote
Old 09-28-2009, 10:23 PM   #19
irisservice
Senior Member
very nice job...
irisservice is offline   Reply With Quote
Old 09-28-2009, 10:28 PM   #20
larryv
Senior Member
larryv's Avatar
Damn! That came out nice.
larryv is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
