Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 08-30-2009, 07:12 PM   #1
zfrank07
Default tips on finishing inside of garage
im getting vinyl siding on the outside so i have osb board on outside....what is the best insulation to use? where can i get it? and then i will probably put up insulation and then osb the inside walls. lighting? i dont want to spend a whole lot but i was some good bright lighting. where could i get them ?
zfrank07 is offline   Reply With Quote
Old 08-30-2009, 08:31 PM   #2
merlin
Default Re: tips on finishing inside of garage
Quote:
Frank,
I used regular old pink glass on a roll from the big orange box store. R-13 for 2x4 studs, and R-19 for 2x6 studs. A lot of guys have used osb but it may not meet code due to fire resistance. I went with 5/8" sheetrock walls and ceiling.
This would be a good time to do any electrical upgrades before you cover the walls. So much easier, or you could surface mount wiring later, if you wanted.
Good luck,
Billy
merlin is offline   Reply With Quote
Old 08-30-2009, 08:49 PM   #3
Stuart in MN
Senior Member
Stuart in MN's Avatar
You may want to mention where you're located...insulation requirements in San Diego are going to be different than in Fairbanks.
Also, make use of the search function - insulation and lighting are two of the most discussed subjects around here.
Stuart in MN is offline   Reply With Quote
Old 08-31-2009, 05:41 PM   #4
zfrank07
what would it cost to sheetrock a 24x28 with 8 foot walls
Old 08-31-2009, 07:52 PM   #5
brownbagg
Senior Member
more than if you just nail plywood up
brownbagg is offline   Reply With Quote
Old 08-31-2009, 08:17 PM   #6
usmc_noma
Senior Member
just put osb up and paint it with an exterior grade paint.
usmc_noma is offline   Reply With Quote
Old 09-01-2009, 12:37 AM   #7
Shocker
Senior Member
Thats what I am doing
Shocker is offline   Reply With Quote
Old 09-01-2009, 06:34 AM   #8
hetkind
I just put up something like 37 sheets of OSB inside my shop...just the 34x40 bay to the 8" level. Two walls got 6" insulation, the wall with the bay doors and the wall facing the open bay got 1.5" styrofoam. It got caulked over the weekend, and today I have a five gallon bucket of primer sealer for a first coat.
Looking forward to building workbenches this weekend.
Howard
hetkind is offline   Reply With Quote
Old 09-01-2009, 12:32 PM   #9
AP300C
Junior Member
I just got two quotes to finish off my 24 x 22 garage (8 foot walls) with one wall already completed (fire wall). For a paint ready finish the pricing was between $950 - $1,200.
I am going to do plywood myself.
AP300C is offline   Reply With Quote
Old 09-01-2009, 06:17 PM   #10
zfrank07
what exactly is sheetrock? 4x8 sheets of drywall? what all would i have to have to sheetrock a 24x28 garage? im just wanting a nice interior finish....
Old 09-02-2009, 05:25 AM   #11
Kevin54
Senior Member
Kevin54's Avatar
Quote:
For the drywall alone, it would cost approx. $375 and take 54 sheets of drywall (5/8") I doubt if you could put plywood up for that.
Kevin54 is offline   Reply With Quote
Old 09-02-2009, 07:34 AM   #12
white64
Junior Member
I have a 24x24. Used OSB on floors and ceilings (that way I don't have to worry about hitting studs if I want to hang "stuff" on the walls), primed and painted with exterior off-white I got at a outlet for $5 a gallon. I also went with surface mount wiring in case I want to add, change or fix something later. Kept the outlets 3 feet off the floor, because garages collect stuff around the walls and I didn't want to have to move stuff to plug other stuff in. 8 flourescent fixtures for lighting. Pink insulation, 2 inch thick insulated doors. Mounted eyebolts to the rafters to hang stuff from. (had my 38 Plymouth coupe body hanging from the rafters for 6 months).
white64 is offline   Reply With Quote
Old 09-02-2009, 08:08 AM   #13
Matt M, PA
Senior Member
Matt M, PA's Avatar
We used Smartpanel in our garage. It looks similar to T1-11, but smoother and with a better woodgrain pattern. It also comes pre-primed and in 10' high sheets should you have higher ceilings. It goes together similar to T1-11 as well as the seams are hidden.
Matt M, PA is online now   Reply With Quote
Old 09-02-2009, 08:27 AM   #14
brownbagg
Senior Member
buy you have to finish and sand the drywall so it be $375 material plus $1000 labor
Old 09-02-2009, 02:37 PM   #15
bowanna03
Senior Member
bowanna03's Avatar
just take your time and mud and tape it yourslef not that hard just takes time.
bowanna03 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
