Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 09-02-2009, 02:09 PM   #1
Cubby
Senior Member
Cubby's Avatar
Default Gravel for parking pad
I have 3 utility trailers (4x4, 4x6, 4x8) and a canoe to store in my yard (yard is 75' x 180' fenced). I have decided to store therm on the south side between my house and neighbour. Right now its sod but with all the rain this year its been under water and the grass has died. I am planning on installing a french drain for the first 3 feet (to dry things up) from the fence and want to the use the rest to store the equipment. What type and size of gravel should I put down? The area is approx 12' by 20'.
Thanks.
Cubby is offline   Reply With Quote
Old 09-02-2009, 02:37 PM   #2
DirtyWhiteBoy
Senior Member
DirtyWhiteBoy's Avatar
Default Re: Gravel for parking pad
I like to put down a layer of #2's then a layer of crushed with dust (not washed) on top of that. a little rain and driving on it and it will make a solid parking spot. The quarry can help with the amount needed.
DirtyWhiteBoy is offline   Reply With Quote
Old 09-02-2009, 02:38 PM   #3
Bull
Bull's Avatar
I'd look into what needs to be done to keep weeds at bay, if possible. I have gravel for the area around my barn, put down two years ago. Weeds grow like crazy in that gravel, and I hate it.
__________________
EUDAIMONIA
"It Pays to Stay in the USA!"
Bull is offline   Reply With Quote
Old 09-02-2009, 04:21 PM   #4
CraigFL
Senior Member
Whatever you do, don't put down anything with rounded stones -- either underneath or on top. The stone should have sharp edges so it packs down well and solidifies.
CraigFL is offline   Reply With Quote
Old 09-02-2009, 06:36 PM   #5
Uncle Buck
If it is a distance from the entrances to the house you might consider asphalt millings, stuff packs good and solid and does act as a good weed barrier, the downside is it can almost have a bit of a muddy way about it at first. To the plus though, it is considerably cheaper than any rock if cost is a factor.
Uncle Buck is offline   Reply With Quote
Old 09-02-2009, 07:54 PM   #6
Chris Adams
Senior Member
Some thoughts.
I have 6000 square foot of gravel in my front yard, and about 5000 in my rear yard.
Gravel is lousy stuff, but it beats dirt/mud/sand.
Trailers HATE gravel. The wheels dig, when you turn you get divots, your truck will try to bury itself every chance it gets.
Walking across sharp gravel barefoot is not fun.
Dogs hate sharp gravel, except to dump on.
They will go a good distance to dump on gravel over sand, I don't know why.
It will settle.
It will take time to settle, and until it does it will be a pain to drive over.
Weeds do come up through gravel, but no more than anywhere else. You just see them more in gravel...
Putting a sheet of plastic down just means you have weeds coming through plastic. It doesn't seem to stop them, despite all the 'experts' suggesting it.
Dark gravel has less weeds, because it is hotter, making it harder for some seeds to germinate. That is only if you live where it is hot.
It will 'walk' into your neighbor’s yard, it will migrate to any concrete and become a pain to walk on. It will seem to actively seek out lawns and migrate there.
Driving on concrete with gravel on it cuts the concrete.
Spray Princep or one of the other powerful herbicides about once a year and you get no weeds, but you MUST follow directions.
If you have to walk in it, get small pea gravel. If you drive in it, get bigger chunks.
It's cheap.
It can be spread in minutes with a tractor, or you can give yourself and your friends heart attacks spreading it.
About ten bucks a ton locally, or about twice that delivered.
You can break a truck bringing it home yourself.
I've had it delivered I’ve used a 5 ton trailer and I’ve used a heavy 1 ton truck.
Cheapest? Contract with someone who owns a truck. Cheaper than having it delivered, cheaper than beating the tar out of your own truck.
Chris Adams is offline   Reply With Quote
Old 09-02-2009, 08:01 PM   #7
Cubby
Senior Member
Cubby's Avatar
Thanks for all your replies. I will not be driving on it but rather moving the trailers by hand to the spot. So ruts should not be an issue. I will put down some good landscaping cloth to keep the weeds out and the gravel from sinking into the ground.
Old 09-02-2009, 09:05 PM   #8
babzog
Senior Member
babzog's Avatar
Quote:
Hire a local with an excavator to take out the top 8-10" of soil in that area and level the area (or grade it slightly away from the house). Then, in with some base layer (pit run, 2", etc) as suggested and top with "shoulder gravel" - the stuff they spread on the shoulders of roads. The stone are about 1/2" - 5/8" or so, with the dust and pea gravel mixed in. It packs well in a relatively short amount of time and the base layer gives you solidity. The only thing that's effective against weeds is a twice yearly spraying with Roundup; plastic, cloth, as noted above, are not effective solutions.
babzog is offline   Reply With Quote
Old 09-02-2009, 09:19 PM   #9
nate379
I have D-1 for my driveway and it's almost like concrete. Wet it down, rolled it with a roller (whatever those are called) and that's it.
No weeds, no ruts, no sharp stuff
My parent's did their driveway in 1990 and haven't needed to touch it. Little bit of rutting the first 5-6 ft from the garage door and that's it.
nate379 is offline   Reply With Quote
Old 09-04-2009, 02:17 PM   #10
adams77
What the heck is D-1?
adams77 is offline   Reply With Quote
Old 09-04-2009, 03:34 PM   #11
nate379
I think it means gravel with no rocks bigger than 1", but I'm not positive. I just know that is what goes on driveways and under pavement and it's called D1.
Old 09-04-2009, 05:33 PM   #12
mdoolittle
Senior Member
mdoolittle's Avatar
I use 1" roadstone. Packs great. Almost as solid as concrete. (well kinda) As for weeds growing through, there a alot of products out there to prevent this from happening. Each product has it's good and bad. I can't recommend a do all weed preventer as each case is different.
If any of you need recommendations PM me and I will be glad to help. (I have been in the Hort/Agron business for many years.)
mdoolittle is offline   Reply With Quote
Old 09-04-2009, 11:17 PM   #13
bgott
Senior Member
Crushed concrete. If you can get it, washout. Washout is the concrete tailings washed out of the plant. With crushed concrete you have time to spread the stuff, washout has to be spread the same day or it hardens. You have to be pretty close to a plant to get washout, here in Houston they are always building and rebuilding the freeways and tollways so we have lots of plants.
bgott is offline   Reply With Quote
Old 09-05-2009, 07:16 AM   #14
kwright
Senior Member
I agree with the crushed concrete. I replaced the gravel in my two long drives with crushed concrete and couldn't be happier. Much less prone to wash out from heavy rains, and more resistant to week growth than gravel. Over time, packs down nice and firm.
kwright is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
