Go Back   The Garage Journal Board > The Garage > Garage Gallery
Reply
Thread Tools Display Modes
Old 09-07-2009, 01:51 PM   #1
ymerej
Senior Member
ymerej's Avatar
Default 24x24 Backyard Garage
Things are finally starting on my new garage. Back in March my wife and I bought our first house, and in that process I had one firm requirement. The house had to have a garage, or space to build the garage. I got space to build. The plan is for a two car 24'x24' garage, reverse gable roof, 16'x8' door, 10' ceiling height, and for me to slowly finish the inside with insulation and drywall next year.
Phase 0: Relocation of Utilities and Tree Removal
The best location for the garage is the back corner of the yard. However, a tree was at the back corner of the garage location. Also, the utility pole is also at that corner of the yard, and the power line to the house comes overhead from there. My first projects were therefore to remove the tree, and upgrade the 100A service to 200A, replace the 40+ year old panel, and move the service underground all at the same time. I worked with BGE (local utility) so that my electrician would replace the panel, I would dig the trench and lay the 4" conduit, and they would only remove the old wires/ pull the new wires and put a new meter on the back of the house to minimize the cost to me.
(yes, that is me in the picture)
Phase 1.1: Foundation
The foundation is the only part I plan on having a contractor do. I thought about doing it myself, but it would take a month or more, and I don't have the skill or time to do a professional job. Therefore I got a few quotes, and hired a contractor to do the foundation. Getting the building permit was a bit of a pain and took a month due to a "stream" behind my yard and my proximity to a flood plain. On Sept 1st I had the permit in hand, and the contractor was out on Sept 2nd.
The contractor should be back to pour the slab tomorrow, pending the possibility of rain. The lumber should be here later in the week, and then I'll get started framing.
Last edited by ymerej; 09-21-2009 at 08:06 AM. Reason: changed where photos are hosted
ymerej is offline   Reply With Quote
Old 09-07-2009, 03:09 PM   #2
custom50
Junior Member
Default Re: 24x24 Backyard Garage
Looks like you have gotten off to a good start. I started planning a pole type garage in Dec. 08. The Contractor ran off with 75% of the money for the job, 24'x32' 10' eaves, three over head doors, 6 windows, extra concrete for a patio between the old garage, and the new. August 09 I had 84 Lumber supply the material, and with their recommendation used their contractor, and concrete guys. The building is up now 40'x80'x14' 2-16'x8' roll up doors, two 4'x4' sliding windows one-3'x3' window, and one service door. I called for stone this past Friday to have it delivered mid morning to give the guy time to get the final grade in front. They sent no. 2 lime stone it looks like rip rap, I called for driveway stone, and I was discussed to say the least. Now I'm having the concrete guy push it out and put a 16-foot pad to go with the 4' apron. It has only taken 9 months plus many nights preparing for the court appearance to try to recover the money the other contractor stole form us.
custom50 is offline   Reply With Quote
Old 09-08-2009, 09:50 AM   #3
ymerej
Senior Member
ymerej's Avatar
Custom50 - Sorry to hear about your troubles. After three quotes for the foundation all within a couple hundred dollars of each other, I went with the guy that had great references. He gave me a six page handout with names, numbers and quick job descriptions of his work. I called all the ones with garage related projects, and every one of them could not speak any higher of him. Seven years ago we did a similar project at my parents house - hire a contractor to do the foundation and then used a kit from 84 Lumber.
Yesterday it rained, and they're calling for rain today, tomorrow, and maybe into Thursday. The contractor didn't want to tear up my yard trying to get a cement truck back to the garage, and as much as I want to get started on my part, I want to take my time and do it right the first time. I told them to hold off a few days until the weather cleared up, so hopefully at the end of the week they'll pour the slab.
Old 09-08-2009, 10:51 AM   #4
jkrswld
jkrswld's Avatar
Send a message via MSN to jkrswld
Looks to be moving along well. Can't wait to see how it progresses - I believe mine is 24x24 too so maybe I can snag some of your ideas for the inside
jkrswld is offline   Reply With Quote
Old 09-08-2009, 11:44 AM   #5
custom50
Junior Member
You did good checking on their work. If you need rain build a garage, every time I have had one built it has rained. In my case I guess I found out the hard way you just cannot take a persons word anymore. There was a day when a handshake was as good as any contract but not anymore. Anyway the building is up and I think it looks pretty good; at least I will have more room. I hope your garage turns out better then you are expecting.
Old 09-08-2009, 03:46 PM   #6
travisd
Senior Member
Nice to see someone local putting something nice up
travisd is offline   Reply With Quote
Old 09-08-2009, 06:31 PM   #7
Nutty 5.0
Senior Member
Nutty 5.0's Avatar
Very nice! I still wish to have those cool butterflies of it being put up. You hate it sometimes during, but you wish to have that time back; or at least I do!
__________________
24'x32'x12' Conestoga built pole building with two 10'x10' doors. 6" concrete floor 4500 psi. Bend Pak MX10-AC 2 post lift and a Pro Park 8 Plus 4 post lift with lifting jack . U-Coat it floor and Garage Pak air lines. Built in March 2005. My garage build: http://www.garagejournal.com/forum/s...ad.php?t=41534
2003 Redfire Mustang Terminator
Nutty 5.0 is offline   Reply With Quote
Old 09-15-2009, 06:57 PM   #8
ymerej
Senior Member
ymerej's Avatar
Phase 1.1: Foundation (Continued)
Last week the forecast was a 70% chance of rain for Tuesday to Thursday, so we didn't pour the concrete, but it also never rained. We then thought about pouring on Friday, so of course it rained over an inch that day.
After letting the ground dry out some, the contractor came back and poured the slab this morning. Tomorrow the wood is being delivered, and then I'll start framing!
Last edited by ymerej; 09-21-2009 at 07:53 AM. Reason: changed where photos are hosted
Old 09-16-2009, 10:35 AM   #9
dipper
Senior Member
dipper's Avatar
Send a message via AIM to dipper
Looks great so far. I did the exact process you did, contract the foundation and then do all the rest.
I ended up waiting to pour the floor until my shell was up and dried in. It wasn't really what I wanted to do, but it actually worked out good. I remember the first day he planned to do it and it was raining like a mother, It wasn't fully dried in yet and still had a few drips coming down inside. We ended up waiting another week or two which gave me more time to finish the roof shingles. The floor was poured on halloween, 2007 and it was about 70 degrees and sunny.
Framing is fun and be sure to keep up with the pictures.
__________________
-Dipper
20x22 Build Pics: http://s630.photobucket.com/albums/u...dipper/Garage/
dipper is offline   Reply With Quote
Old 09-16-2009, 12:26 PM   #10
McDowell
Junior Member
McDowell's Avatar
looking nice. keep up the good work.
McDowell is offline   Reply With Quote
Old 09-16-2009, 10:48 PM   #11
mrstang69
mrstang69's Avatar
keep the pics coming
mrstang69 is offline   Reply With Quote
Old 09-17-2009, 07:25 AM   #12
TRC51
Senior Member
TRC51's Avatar
ymerej,
Can you tell me what pitch your contractor used on the floor from back to front?
Thanks,
Travis
TRC51 is offline   Reply With Quote
Old 09-17-2009, 08:29 AM   #13
ymerej
Senior Member
ymerej's Avatar
Quote:
The total fall is about 4" over the inside length of 22' 9", so approximately 3/16" per foot. I would have preferred it to fall only about 2" over the whole length, but they notched the walls so the slab would lock into it with that slope. You can see just see the notch in the pictures of the foundation without the slab. I didn't notice that it was that much of a fall until after the walls were poured and the forms were off. That's a detail I didn't call out for in the contract, so I'll see how it works out.
My parents garage was poured with zero slope, a very shallow lip at the apron, and their driveway slopes straight down into the garage. There is a drain tile across the whole front edge, but it isn't enough. Every time it rains, some water comes under the door, and hard rains will get water to puddle over the front 1/3 of the garage, as well as find a way to puddle in the back as well due to a very slight variation in the slab elevation. I knew I wanted some slope, but I also don't want my sockets to roll out the front door.
Old 09-17-2009, 09:00 AM   #14
TRC51
Senior Member
TRC51's Avatar
Quote:
Thanks. That is what I needed. My guy is telling me that he will probably put a 4" drop over the 29'-4" run in my new garage. I was wondering how agressive that would be. I am looking for a nice compromise between flat and sloped. While I have a longer distance, maybe the 4" would be good for me too. Hmmmm.
Old 09-20-2009, 12:18 AM   #15
insane1
Junior Member
insane1's Avatar
Damn that is alot of concrete!!!!
I see this done a lot up north. Not how its done in Texas.
insane1 is offline   Reply With Quote
Old 09-20-2009, 08:44 PM   #16
ymerej
Senior Member
ymerej's Avatar
Phase 1.2: Framing
The wood was delivered on Wednesday, and I was able to piece together about a wall panel and a half in the evenings after work before it got dark during the week. On Saturday I worked the whole day, and had help on and off from family and friends: Beverly (my wife), Whit (brother), Madison, Jared, Billy, and my mom. I'd say there were about three people helping at any given time, and when we had a few extra hands we'd lift a wall panel section into place. On Saturday we assembled and raised five ~12' wall sections.
On Sunday (today) the crew was a little smaller, and we only needed to call in reinforcements to lift the one large 12' wall panel section into place, and get the header boards up. At the end of the day all four walls are standing, and I only have some sheathing and cripple studs left to do on the front wall. I plan to work on small things throughout the week, and then next weekend I'll find some help to get the rafters up and start on the roof.
Old 09-20-2009, 11:06 PM   #17
Marc Shaw
Senior Member
Marc Shaw's Avatar
Looks great so far - keep us posted.
Marc
__________________
1991 964 C4 Coupe - Black/Black not quite stock...
My current 30x32 shop build is here.
The reason I built this shop is here.
Marc Shaw is offline   Reply With Quote
Old 09-20-2009, 11:34 PM   #18
Motown 454
Senior Member
Motown 454's Avatar
Thats going to be a nice work space.
Motown 454 is offline   Reply With Quote
Old 09-23-2009, 10:07 AM   #19
ymerej
Senior Member
ymerej's Avatar
Here's a question for those reading this thread. I'm planning to put up the roof trusses this weekend, and I have a pile of Simpson H1 hurricane ties. I know how to do all of the middle trusses, but since the truss will sit on the flat 2x4 tie plate, there isn't a space to nail that type of hurricane tie in place. How do I put hurricane ties on the first and last roof truss? What type of tie should I use?
Old 09-23-2009, 11:01 AM   #20
twostory
Senior Member
Use a Simpson Strong Tie H2.5 G90 Hurricane Tie, or similar tie.
twostory is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
