Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 09-08-2009, 08:48 PM   #1
Ashamsi
Senior Member
Question Weight capacity of homemade ramps made out of 2X10 lumber
Hello,
Anyone has any thoughts regarding how heavy a vehicle could homemade ramps, made out of 2X10 lumber safely support? These ramps would have a 4 foot base with 4 layers of 2X10 yellow pine, each layer 6 inches shorter than the one below it. Each layer would be attached to the layer below it with 3 inch screws.
Thanks.
Ashamsi is offline   Reply With Quote
Old 09-08-2009, 08:58 PM   #2
Uncle Buck
Default Re: Weight capacity of homemade ramps made out of 2X10 lumber
Quote:
Originally Posted by Ashamsi View Post
Hello,
Thanks.
If you are speaking of a design where you stack wood one piece laying flat upon another then you should really have no problems unless you are running a tank or something like that over it. Many guys have made them like that, including my dad. In fact, you could even get away with 2 x 8" wood for that. Good luck.
Uncle Buck is offline   Reply With Quote
Old 09-08-2009, 09:03 PM   #3
vartz04
Senior Member
vartz04's Avatar
how are you going to attach them w/ 3" screws that will come out the other end once you sink the screw head in a bit. go 2.5" screws
vartz04 is offline   Reply With Quote
Old 09-08-2009, 09:28 PM   #4
v7guy
Senior Member
I can't imagine you'd have any problem with any vehicle.
v7guy is offline   Reply With Quote
Old 09-08-2009, 09:33 PM   #5
Kev442
Senior Member
Kev442's Avatar
Lots. I used that setup to level my 6000lb. Dodge Maxivan when camping. The nails fit into predrilled holes so I could go up in increments.
Kev442 is offline   Reply With Quote
Old 09-08-2009, 09:43 PM   #6
79firebird
Senior Member
should support a fair amount. one day in a bind had to put a school bus on a set of 2x12 home made ramps front and back supported it no prob.
79firebird is offline   Reply With Quote
Old 09-08-2009, 10:05 PM   #7
logical
Senior Member
I stack 3 high loose, one each 4 ft, 3 ft and 2 ft long 2x10 every time I change the oil in my F-150. I think it's fine....but if you plan to use over and over I'd go with some pressure treated boards and maybe just drill holes and use a length of rebar or other rod the whole way through so you can break it down to carry easier. Even some 1/2 copper pipe dropped through slightly larger holes would keep them aligned good enough.
logical is offline   Reply With Quote
Old 09-08-2009, 10:10 PM   #8
jsaw
Senior Member
We have driven a 14,000 pound truck on a set of ramps like you describe, no problems.
jsaw is offline   Reply With Quote
Old 09-08-2009, 10:27 PM   #9
jamesemery728
Senior Member
Had this arrangement for years. Put it together with screws and wood glue and cut a taper on the front edge of each layer so I could drive up on it. It is all solid wood, you probably could drive a tank up on it.
__________________
Life is like a coin, you can choose to spend it anyway you wish, but you can only spend it once.
jamesemery728 is offline   Reply With Quote
Old 09-08-2009, 10:35 PM   #10
dreamingmuscle
Senior Member
Wouldn't it be easier and lighter to use 1/4 angle iron on both sides of a single 2x10?
I use 2x8's, but support them with a set of car ramps when loading something heavy.
Glen
________
Jaguar S-Type (1963) picture
dreamingmuscle is offline   Reply With Quote
Old 09-08-2009, 10:40 PM   #11
nate379
Are you talking about ramps that you'd use for loading something on a trailer or back of a pickup, or ramps that go on the ground to raise the front or rear of a vehicle?
My trailer ramps hold 12000lbs fine, they are 2x3" 1/4" thick C channel sides with 2" 1/4" thick angle iron rungs. They are about 7ft long though.
nate379 is offline   Reply With Quote
Old 09-09-2009, 06:46 AM   #12
Ashamsi
Senior Member
Thanks guys. A plan to use 2 sets of these ramps to raise the cars to work underneath. I thought they would be quite sturdy but just wanted to get some expert opinins.
Thanks.
Old 09-09-2009, 07:10 AM   #13
Shepoutside
Shepoutside's Avatar
I've used mine for years, and work in medium duty trucks and RV's.
Shepoutside is offline   Reply With Quote
Old 09-09-2009, 08:24 AM   #14
FunfDreisig
Senior Member
I've used stacked 2x12s for years on cars, SUVs, tractors. I cut a 45 degree angle and leave just enough room for a tire patch on each layer. I screw them together with 2.5" screws facing down and attach a tire stop to the far end. To get all four wheels up, I usually just jack the rear up and slide a short 'ramp' under the wheels.
Funf Dreisig
FunfDreisig is offline   Reply With Quote
Old 09-09-2009, 08:55 AM   #15
mjozefow
Senior Member
mjozefow's Avatar
If they are stacked, and assuming no span, any vehicle with inflated tires that fit on the boards should not be able to crush the boards. I would worry more about racking if it gets too high.
Heck, the dozer on the family ranch rides on pallet wood to cross roads and only beats the wood up minimally.
Wood is very strong in compression.
__________________
I do not prize the word "cheap." It is not a badge of honor...it is a symbol of despair. Cheap prices make for cheap goods; cheap goods make for cheap men; and cheap men make for a cheap country. ~ William McKinley
Lots of Vise Info
Vise restoration Tips
The Vises of GJ! (dial-up death)
A_Pmech makes replacement jaws, ask him!
My Website:
www.mitchscustomcarpentry.com
mjozefow is offline   Reply With Quote
Old 09-09-2009, 12:16 PM   #16
buening
Senior Member
So the ramp you are making will only raise the vehicle 6"? Keep in mind a 2x is only 1.5" thick, so with 4 layers you'd end up with 6".
Also, how wide are your tires? A 2x10 doesn't give much leeway when driving up them. The tires on my truck have 10" tread so if I'd get slightly off track I'd risk tipping the ramps. I suggest wider ramps if possible
__________________
1970 Mach 1
1970 Mustang Fastback
2003 Mustang
2005 F150 FX4
Licensed Professional Engineer, PE (Civil)
Licensed Structural Engineer, SE
buening is offline   Reply With Quote
Old 09-09-2009, 01:52 PM   #17
Skyline
Senior Member
Skyline's Avatar
My guess is that even the tank would be OK. When we put chains on our fire engines for heavy snowfalls, we drive the inner rear wheels up on solid blocks of wood, cut at a 45 on one end. Been doing this for 20 years without a hitch. These trucks weigh about 55,000 lbs. for the lightest one.
__________________
Click on the link below to see the used professional tools at great prices in my eBay store from Snap-on Mac, Matco etc.:
http://stores.ebay.com/ExpertTools?_rdc=1
Skyline is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
