Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 09-29-2009, 05:32 PM   #1
checkthisout
Senior Member
Default Another OSB question: Nailing Patterns
Where I am the OSB must be nailed all the way around the edges 6" on center and every 12" in the middle.
I installed my OSB vertically with blocking at 8 feet (per fire code) with the top edge of the OSB nailed to this block and bottom edge of the top piece also nailed to this block, ok?
You cannot have any edges that are not nailed to joists yet I see many people on here putting the stuff sideways with no blocking between the joists to nail to.
What gives? Is this just code for my area? If so, why do they choose to do it this way?
Take for instance flooring. You don't have to nail it around every edge but along the edges you are not nailing the stuff is joined by a tongue and groove....
checkthisout is offline   Reply With Quote
Old 09-29-2009, 08:43 PM   #2
NUTTSGT
NUTTSGT's Avatar
Default Re: Another OSB question: Nailing Patterns
I wouldn't sheet a wall and have the two sheets meet in the middle of nowhere, common sense says seam on a stud.
__________________
ERIC
Too much is.... Just enough.
My garage refurb thread.
http://www.garagejournal.com/forum/s...ad.php?t=75024
Are you military or prior military ? Please visit OUR thread and post your experience.
http://www.garagejournal.com/forum/s...ad.php?t=64422
Take a look what your USA honorable service may have done for you.
http://www.garagejournal.com/forum/s...d.php?t=100237
NUTTSGT is offline   Reply With Quote
Old 09-30-2009, 10:42 PM   #3
tcianci
Senior Member
tcianci's Avatar
Send a message via AIM to tcianci
I know some code officials like the blocking stuff but the most common application of sheets is horizontal with the short dimensions breaking over studs and no blocking along the horizontal joint. Think about it... as for as I know there is no code requiring the use of sheet goods for sidewall sheathing or sub flooring, would you put in blocking every 8 inches on a wall or a floor so you could have something to nail to on the long dimension of the board if you were using 1x8's? Of course not. Not all flooring is tongue and grooved either, many guys use standard 3/4 inch plywood for sub floors, there is no edge support on the long dimensions of the sheet other than where it crosses a joist. Typically there is no edge support on the long dimension of the sheet for drywall either. Mid-bay fire blocking may be something particular to your area, we never have to do it here in MA.
The traditional way to run sheet goods is with the long dimension (strength axis) 90 degrees to the framing whether it is boards, plywood or OSB. And, YES there is a strength axis to OSB, that' what the "O" stands for...Oriented Strand Board and just like plywood it it is not designed to be applied with the long dimension parallel to the joists.
While it is becoming more common for guys to frame with 4x9 sheets of OSB sheathing and run it vertically. It requires that your stud placement be more accurate, you need your 48" breaks to be precise and since there are twice as many 48" breaks in a given wall than there are 96" breaks, the stud placement is a little fussier. Now before everyone jumps all over me on how they would NEVER frame anything where the studs were not perfectly placed...it happens all the time. Example... you lay out a wall on 16" centers and a stud position falls about 3/8 of an inch from where you would be locating a king stud for a window opening, well you just skip the stud and let the king stud be the stud. If that stud were also a break point for the edges of 2 sheets of sheathing, you will have precious little material of that stud to nail one of your sheets onto. When you run the sheathing vertically, you double the instances where this type of situation can occur.
__________________
People are doing either what they THINK is right or what they KNOW is wrong.
tcianci is offline   Reply With Quote
Old 10-01-2009, 12:03 AM   #4
checkthisout
Senior Member
My studs are 16' tall to the top plate. I put all the studs in then drove 3 nails into the center of every third stud as my 1/8th spacers where two sheets of OSB would be nailed to.
I installed all the bottom sheets and only nailed on the vertical edges of the studs themselves. I then cut all my blocking to 14.5 inches and installed in between the studs and then went back and nailed the osb on the top and bottom edges and in the centers.
It looks like a stud did it!
Anyways, my county requires blocking every 8 feet as fire stops. According to the engineer all seams of the OSB must be nailed to prevent a flame from licking through the cavity and to stop air from being able to flow back into the cavity and feed a fire.
Sound right?
Old 10-01-2009, 12:50 AM   #5
tdkkart
Senior Member
tdkkart's Avatar
Quote:
This is a perfect example of how retarded some codes are.
Fire blocking in a wall sheathed with wood?? WTF. The entire wall is flammable, how much are they gaining, especially in a one story building?
All the glue in OSB probably makes it more flammable that the fire stops anyway.
I suppose it would slow the fire SOME, but how much??
Ever clean up after a fire?? I'd rather have the whole place burn to the ground.
Nailed every 6 inches?? Wow, it's not like the stuff is all that heavy.
tdkkart is offline   Reply With Quote
Old 10-01-2009, 01:35 AM   #6
Torque1st
Senior Member
Torque1st's Avatar
Blocking is placed in walls to slow the spread of flames not to stop it. The code is designed to allow occupants more time to escape. Sometimes even a few seconds can make the difference between life and death.
Balloon framing always required blocking in the old days.
__________________
Faster, Better, Cheaper: Pick Two
The FairTax
Follow the Money. -72chevy
Yes, I am insensitive and yes, not politically correct, and yes, Im sure I offended someone,... -Busted_Knuckles (Me too, plus I am old, tired, and grumpy!)
Read "The Marching Morons" Here
"Works" <> Safe, Good, or Right
"You can't fix stupid." -Ron White
Torque1st is offline   Reply With Quote
Old 10-01-2009, 02:24 AM   #7
ddawg16
Senior Member
ddawg16's Avatar
Actually, it's not the flame they want to stop....it's the smoke.....the smoke kills you before the flame does. So, while they call it fire block....it's really a smoke block.
Here in CA you have to block and nail the edges....it adds to the shear streangth. The SOB is the primary shear component of the wall to protect from earthquake damage. With us it's 3" on edge, 6" everywhere else.
If you do go horz you want to stagger the sheets so that the vert seam is only 4'. This will give you the greatest shear strength.
__________________
John
"Don't try to lead me to temptation, I know the shortcut."
In Progress...2-Story Addition link
2-Story Garage Complete My Garage Build Link
Home for.....
84 CJ7 - With a 'few' modifications.. My Jeep Build Link
And my wife's art Studio...
and 3 kids with more energy than we have...
ddawg16 is offline   Reply With Quote
Old 10-01-2009, 05:16 AM   #8
checkthisout
Senior Member
You can go horizontal here but then you have to put blocking every four feet instead of 8.
More work.
Old 10-01-2009, 05:35 AM   #9
checkthisout
Senior Member
Well, I can't say I have a put a great deal of thought into it but building fires are generally fed by the contents of the building. That is why you put up sheetrock that is X thickness. You are increasing the amount of time the building contents can burn before they catch the structure on fire or perhaps even giving them time to burn out before they ignite the structure. The fireblocking prevents your stud cavities from becoming chimneys. Hundreds of thousands of man hours of testing have shown that spending the extra 2 hours and 100 bucks installing the blocking is a good idea.
My county has required this since at least the early 80's because I remember me and my dad helping one of the neighbors install it in a house he built.
Nailing it around the edges prevents a flame from penetrating to the outside of the structure and traveling up the outside of the building or at least delays it. It also prevents winds from catching an edge and tearing the sheet off and of course it also gives you more nailing area thus further increasing sheer.
I bet guys in Florida or any Hurricane state have to nail theirs every 3 inches on center!
You're right, OSB is not heavy but it's a structural panel. You're not just trying to hold the OSB up onto the wall but are also making sure the OSB does it's job of transferring shear forces and keeps the building from becoming a pile of sticks if the wind blows more than 5 MPH.
When my pole building was just poles, a roof and studs you could stand on the 2nd floor and do a little dance and get that thing moving about 8 inches each way! Putting just a few sheets of OSB on 2 sides of the building made it immobile!
Old 10-01-2009, 08:42 AM   #10
OccupantRJ
Senior Member
OccupantRJ's Avatar
The garage in my back yard where I am now living was built by clueless yokels, for sure. It is 26 X 26 and there was no bracing at all. The outside had 12" masonite lap siding, nothing else, and I could shove on the corner and get the building swaying. It was also over an inch out of plumb, in a rotational twist. I removed all the siding, used a come-along diagonally to pull it into square, and added 7/16" OSB horizontally on the outside. It will later have vinyl siding. It's now solid as a rock, and will be getting either OSB or plywood on the inner walls. Absolutely well worth doing, no doubt. I'm in NC, so I nailed it every 4 inches along the edges, and every 8 inches in the inner field.
OccupantRJ is online now   Reply With Quote
Old 10-01-2009, 08:50 AM   #11
tcianci
Senior Member
tcianci's Avatar
It's really not the smoke or the flames but it is the air! Each bay acts as a chimneY that channels fresh air to more of the building so that the fire spreads because the combustion is supported. I hope in no way you got the idea from my post that fire blocking is not important. It's just that different areas of the country have different regs. And the poster who mentioned ballon framing is absolutely right. This type of framing utilized continuous studs from sill to roof and each stud bay was a perfect conduit for combustion air. These stud bays were typically blocked with brick "nogging" or other non-combustible rubble. Trust me, I have the hole saws and spade bits to prove it!
__________________
Old 10-01-2009, 08:53 AM   #12
Costner
Senior Member
Costner's Avatar
Codes vary - in my area there is no requirement for blocking for edge support of sheathing and a lot of builders don't even bother to use TNG. On the roof they do mandate clips to hold the panels in alignment but those only do so much.
However some areas require blocking for fire code reasons, others require more edge nailing for sheer reasons or high wind concerns. If you live in an area that is susceptible to earthquakes or hurricanes extra fasteners would be expected. Keep in mind the shear strength of a panel is typically determined by the fasteners themselves, so the more fasteners the stronger the panel will be (within reason).
As to fireblocking itself, a large part of what fireblocking does is reduce the amount of oxygen that is available for a fire thus slowing down the spread of flame and allowing the occupants time to get out safely. The room won't be 100% airtight, but it will prevent air from being easily sucked into the room from wall cavities etc.
__________________
~Costner (No, not the Waterworld guy)
Costner is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
