Go Back   The Garage Journal Board > The Garage > Flooring
Reply
Thread Tools Display Modes
Old 10-09-2009, 12:53 PM   #1
geo65
Junior Member
Default pro, cons for quartz floor
what do you think about the floor system below. pros and cons about using quartz? I can't see a downside or problems associated with using the quartz.
prep floor
100% solids clear
quartz 100% coverage broadcast (for the look it provides)
100% solids clear as a top coat
geo65 is offline   Reply With Quote
Old 10-09-2009, 07:56 PM   #2
thegarageguy
Senior Member
thegarageguy's Avatar
Default Re: pro, cons for quartz floor
Quote:
prep floor
100% solids clear
No downside to using quartz but what you are describing is a single broadcast or 1/8 inch quartz floor without a top coat.
First, one problem with the single broadcast quartz floor is that if the applicator isn't very good or heavy handed, he could leave waves or clumps from broadcasting. Usually single broadcast looks patchy and doesn't look as smooth as a double broadcast. Also, some patch work or concrete flaws may ghost through.
Another problem is that by your accounts, its only being top coated with epoxy and no polyurethane or polyaspartic top coat. I know some on here, that don't know any better, think that its unnecessary but unless that epoxy is aliphatic it will amber quicker and scratch easier and not have the stain power.
At the very least, see some other single broadcast floors that where done, make sure its over a year old and by all means opt for a poly top coat.
__________________
www.bodenkraft.com
Serving NY, NJ & CT
Follow us on:
Twitter: http://twitter.com/Bodenkraft
FaceBook: http://www.facebook.com/Bodenkraft
Pinterest: http://www.pinterest.com/bodenkraft/
Instagram: http://instagram.com/bodenkraft
thegarageguy is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
