Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 10-11-2009, 02:58 PM   #1
rac
Junior Member
Default Free online calculator
Does anyone know the best online calculator for ridge beam sizes and rafter lengths?Trying to see if 2 2x12 will span 32ft with no center post. And what pitch a 16 ft rafter will go 14 ft. and leave about 1ft. overhang.Thanks.
rac is offline   Reply With Quote
Old 10-11-2009, 04:25 PM   #2
Jaxrunner
Junior Member
Default Re: Free online calculator
good luck finding a 32' 2x12.
Jaxrunner is offline   Reply With Quote
Old 10-11-2009, 04:33 PM   #3
speed bump
Senior Member
speed bump's Avatar
Why don't you just call your local truss company and ask them?
__________________
Quote:
Originally Posted by NJHandyGuy View Post
Agreed that makes about as much sense as a pimp with a health plan.
speed bump is offline   Reply With Quote
Old 10-11-2009, 04:34 PM   #4
DCLXVI
Junior Member
Try http://www.southernpine.com/
Didn't see anything 32 feet long though.
DCLXVI is offline   Reply With Quote
Old 10-11-2009, 04:41 PM   #5
Jaxrunner
Junior Member
A 24' is going to be the largest 2x12 w/ grade stamp on it. You can get larger one's milled if you are lucky. Then you have get them dry and inspected. Your best bet is going to be to get an engineered beam.
Old 10-11-2009, 04:45 PM   #6
NUTTSGT
NUTTSGT's Avatar
32' is a long way for a free span.
__________________
ERIC
Too much is.... Just enough.
My garage refurb thread.
http://www.garagejournal.com/forum/s...ad.php?t=75024
Are you military or prior military ? Please visit OUR thread and post your experience.
http://www.garagejournal.com/forum/s...ad.php?t=64422
Take a look what your USA honorable service may have done for you.
http://www.garagejournal.com/forum/s...d.php?t=100237
NUTTSGT is offline   Reply With Quote
Old 10-11-2009, 06:02 PM   #7
pcmeiners
Senior Member
pcmeiners's Avatar
32 foot unsupported span, in structural wood, no way, no building department would allow it.
According to the link, seems possible but impractical/expensive in engineered wood...
Guessing you would need roughly 36-40" beam height, and your retirement savings to pay for them.
http://www.datummarketing.com/articles/lumber.pdf
pcmeiners is offline   Reply With Quote
Old 10-11-2009, 06:15 PM   #8
Jaxrunner
Junior Member
There are several variables to sizing your ridge beam. You really need to give us a better idea of your garage design. If you give me more information I do not mind doing a quick calculation to give you an idea on the size beam you will need. I have never in 9 years sized an engineered beam larger than a 24" depth. You might want to also think about using ceiling joists. That will reduce the size of the beam.
Old 10-11-2009, 07:50 PM   #9
rac
Junior Member
The garage I had was 20x28 and used 2 2x12x14 for ridge beam bolted together end to end and 2x8 for rafters with a cable across half way to hold sides for support.Was wondering if I double 2x12 would it span 32ft.without center post.
Old 10-11-2009, 07:53 PM   #10
rac
Junior Member
Forgot to put garage I'm building is 28x32
Old 10-11-2009, 08:51 PM   #11
Jaxrunner
Junior Member
I would say no. In general, when ever you have a splice in the beam you need a support directly under it. The other option in to make a connection strong enough for the loads in every direction. The cable seems like it is just holding the walls from falling out.
Old 10-11-2009, 09:42 PM   #12
White 99
Alliance Member
Could the garage be made with joists and a ridge board? Then the rafters hold the ridge board and the joist holds the walls together. You will have a ceiling then.
I am no carpenter but that is how my 24X50 garage was made. I wanted stem walls upstairs but it got too complicated getting a ridge beam so I went with conventional construction and a ridge board. Again I am no carpenter but that was how it was explained to me.
White 99 is offline   Reply With Quote
Old 10-11-2009, 11:07 PM   #13
GeorgiaHybrid
Senior Member
GeorgiaHybrid's Avatar
Go with a flitch beam (steel plate sandwiched between 2 2x12's) or a steel beam with nailers added to the top flange.
GeorgiaHybrid is offline   Reply With Quote
Old 10-11-2009, 11:58 PM   #14
ddawg16
Senior Member
ddawg16's Avatar
My ridge beam spans 27'. It's 2 6"x12 tied together with a Simpson connector and center support beam. The support sits on top of a PSL beam, 7"x16"x20'.
From what you are asking....it looks like you need to get an engineer to works things up....
__________________
John
"Don't try to lead me to temptation, I know the shortcut."
In Progress...2-Story Addition link
2-Story Garage Complete My Garage Build Link
Home for.....
84 CJ7 - With a 'few' modifications.. My Jeep Build Link
And my wife's art Studio...
and 3 kids with more energy than we have...
ddawg16 is offline   Reply With Quote
Old 10-12-2009, 04:57 AM   #15
Kevin54
Senior Member
Kevin54's Avatar
According to the Pocket Reference Guide, the maximum joist recommended is a 24' 2x12 ans max span for it is 18' give or take a couple of inches. As far as pitch you are going to roughly get 3:12 or 3.5:12 out of a 16' long board
Kevin54 is offline   Reply With Quote
Old 10-12-2009, 05:51 AM   #16
charlie_nj
Senior Member
This one won't help you with beam sizing, but it will give you rafter lengths for various pitches and overhangs. I like it a lot and best of all its free.
http://www.northbridgesoftware.com/calc.html
charlie_nj is offline   Reply With Quote
Old 10-12-2009, 09:04 AM   #17
RPH
Senior Member
Look at Lite Steel Beam.com
They have a new product for this purpose and does not need crane to place it.
Two people can install.
RPH is offline   Reply With Quote
Old 03-15-2016, 02:02 PM   #18
siram
Junior Member
Hi there , new to this site. I am building a 16' long by 12' wide workshop. I am planing to use 2"X8" roof joists @ 16" oc. Trying to figure out what size ridge be would work.
siram is offline   Reply With Quote
Old 03-15-2016, 05:18 PM   #19
Kevin54
Senior Member
Kevin54's Avatar
Quote:
What roof pitch are you planning on using?
__________________
THE ADDITION
Old 03-15-2016, 05:23 PM   #20
Senior Member
theoldwizard1's Avatar
It is called a "span table". You typically can not find SPF (spruce/pine/fir) in anything longer than about 24'. Douglas Fir (west of the Mississippi) probably a bit longer.
OP, 32' is easy with an LVL (laminated verneer lumber). Of course you will need about 6-8 guys or a crane to lift it !
theoldwizard1 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
