#1 |
Senior Member
Here are the current Jacks I own.
![]() The small one is a no-name Chaiwanese type I had to buy to get a job done.... Has done pretty well. The medium sized orange one is the STRONGARM Jack I got with a bunch of tools I bought.... This particular one was made in Canada.... Now they sell the exact copy of it at HF, now made by some Chinese company.... I had to get the handle from HF because they were the same ones Strongarm was replacing them with. ![]() The Blue one is my new pride and joy... The Lincoln (Sans Rear wheels) until Hiball hooks me up. And finally, the large Orange one is an HF model. Funny how it is almost the same size as the Lincoln but is "rated" at 2.5 T. I used this type one year of light use... Had in in storage and then it $#it the bed. Luckily I had got the extended warranty on it and they just replaced it. So my advice is that if you buy this type from HF... Get the replacement policy, you will probably need it (Same goes for their Scissor type transmission jack) ![]() -BWP
__________________
AF WDH ZCJ CJZGAUI QTAB WDH TZKJ QDD PHMT QAPJ DU WDHC TZUGB. IJQ VZMO QD QTJ IZCZIJ!!! |
#2 |
Senior Member
#3 |
Senior Member
Here is a few of mine, I have aproximately 100 floor jacks on the floor and would venture to guess around 250-300 Bottle jacks. These are just some i had on my computer. I suppose untill i sell a jack to someone, There all mine.
882 (Large).JPG Walker Model 882, 2 ton 1 of Walker first designed hydraulic jacks. Still the same similar design used in the Hein Werner badged Long frame 2 tons today. 65+ years and still a quality product. Notice all the fancy frame artwork, Back then Blackhawk was designing similar jacks, making them look like cars with headlights etc. 87lbs of USA Craftmenship. older93657 (Large).JPG Lincoln 4Ton 93657, Same jack as Blacknwhitepit's minus the cover for the pic, One of my favorites. 181lbs of Made in the USA. 93657 (Large).JPG Same jack as above but with the older double walled frame, I believe this one was badged Walker before the lincoln buy out. 181lbs of MADE IN THE USA ausco (Large).JPG BIG MOMMA, 400lbs of Good ole MADE IN THE USA Pure Iron, This 10 ton beast beggs to lift 15 ton. It was manufactured by Ausco but uses a HeinWerner Unit with a few mods. Hwx10 (Large).JPG Hein Werner X10 Ten ton Monster, tipping the scale also around 400lbs. MADE IN THE USA Weaver W75 (Large).JPG Another of my favorites, 10 ton Weaver w75. Simple design all welded Frame, Foot pump. 356lbs of MADE IN THE USA
__________________
Made in the USA? Its Wright thing, You Dual 80 boys wouldnt Understand. Check out my new Website, its not much i made it myself. Suggestions?http://www.hydraulicjackrebuild.com Last edited by Hiball; 10-12-2009 at 08:21 PM. |
#4 | |
Senior Member
Quote:
__________________
Elroy's "Rush" policy on getting things done: If you want it real bad You get it real bad The worst you want it The worst you get it. |
#5 |
Senior Member
Here is the jack I just bought off E-bay. Now to try and figure out who made it. I think I did ok for $28 and fuel to go get it $30. What do you folks think? The tag can not be read. It is about 4' long and 200#s if that helps ID it. Thanks
#6 |
Senior Member
@Hiball:
nice collection !! Now show us your other 94 jacks !
#7 |
Senior Member
I believe its a Very,very,very Early Walker Jack. Maybe The first design. I seen it on ebay but it was too far away from me. Walker made a 3 ton jack early in its history and it didnt go over well for some reason, Ive yet to see one but something told me when i seen that jack on ebay that was what i was looking at. Nice find.
__________________
Made in the USA? Its Wright thing, You Dual 80 boys wouldnt Understand. Check out my new Website, its not much i made it myself. Suggestions?http://www.hydraulicjackrebuild.com |
#8 | |
Senior Member
Quote:
#9 |
Senior Member
found this pic:
AC DK20HLQ 2 ton jack vs. standard 2 ton jack
#10 |
Senior Member
LoL, Thats not a standard jack next to your AC, thats a compact ie:"In case of emergency use me" jack.
__________________
#11 | |
Senior Member
I have one like that! Except mine is red, branded Sealey and is the cheaper version. It's a good jack though, low entry, high lift and very solid. I like the long chassis too.
![]() Best pic i have of it, holding up the gearbox in my friends W123 Mercedes-Benz:
__________________
Quote:
#12 |
Senior Member
Mine from a previous post. A China made NAPA unit, good size and works well, real solid. A blackhawk manufactured Craftsman from the early '70's. Its red now, came new as a metallic green and white, I bought it new. Had a hydraulic shop rebuild it once due to leaking down, never did quit but doesn't leak much. Might try to rebuild it my self again.
Charles |
#13 |
Senior Member
Elroy's 1978 Hein Werner Model WS is on the right
Jim's 1948 Model OS on the left
__________________
#14 |
Senior Member
Found this at a car show:
Looks like the AC and Sealey 2200HL version.... ![]() ![]() Sealey 2200HL 2 ton ![]() edit: The Sealey 1,3 ton 1301HL high lift model says made in denmark |
#15 |
Senior Member
a couple 20 ton bottle jacks and the torin big red floor jack from costco.
__________________
1972 yamaha ct-2 1997 Toyota Tacoma 4x4 3.4l |
#16 | |
Senior Member
Quote:
My reasoning on your jack being a walker.
__________________
#17 |
Senior Member
2.5 ton hf long frame, works like a champ. I've had it going on 7 years now, dad had one around 20 years old, was still going when the farm was sold. It comes with seals, so no big deal if it needs rebuilt.
__________________
If guns cause crime, all mine are defective. Ted Nugent "A man with a gun is a citizen. A man without a gun is a subject. " John Lott "Taking my gun away because I might shoot someone is like cutting my tongue out because I might yell `Fire!' in a crowded theater." Peter Venetoklis |
#18 |
Senior Member
Man, LOVING those blue and yellow 4 ton Lincoln long frames!!!
#19 | |
Senior Member
Quote:
#20 |
Senior Member
Picture didn't load on last post. Trying this again.
I have another jack that has the same 3 position adjuster for the handle. Is this Walker specific or did anyone else make them like that? I was told that other jack was a blackhawk but have no idea anymore. Thanks for your input. Last edited by ihredo4; 10-15-2009 at 11:41 AM. |
| Thread Tools | |
| Display Modes | |
